    MMM-Globe
    119 Posts 39 Posters 237.9k Views 40 Watching
      Burner911 @LukeCodewalker
      @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
      • SvenSommerS
        SvenSommer
        @LukeCodewalker, @Burner911
        I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
          Burner911 @SvenSommer
          @SvenSommer You’re fast! Thank you!
            Renfield
            @LukeCodewalker
            First, thanks for the great module!
            I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
            Is it possible that there’s a caching issue?
            Thanks,
            Renfield
            • L
              LukeCodewalker Module Developer @Renfield
              @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
              B D 2 Replies Last reply Reply Quote 0
                Renfield
                I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                ?+ new Date().getTime();
                to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                Thanks,
                Renfield
                D 1 Reply Last reply Reply Quote -1
                  chrisfoerg @lolobyte
                  @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                  S B 2 Replies Last reply Reply Quote 0
                    schlachtkreuzer6 @chrisfoerg
                    @chrisfoerg Niiiiiiiiiice!!!
                      binderth @chrisfoerg
                      @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                        schlachtkreuzer6 @binderth
                        @binderth jep, they are testing the stuff and so on
                          BatterseaBridge @LukeCodewalker
                          @LukeCodewalker
                          Love this module! Thank you. I’d also like to have ‘ownimagepath’ updated regularly. I’m also a JS newbie and have no idea where to start. The image I’m using is: https://www.nnvl.noaa.gov/images/FDC-latest.png
                          Thanks!
                          • FlatPepsiF
                            FlatPepsi
                            I will pile on the request for updating custom URL images. I’ve been going crazy trying to figure out why it doesn’t update – and now I know. :)
                            The default North America image is a synthetic one, with real cloud cover overlaid on a static daylight earth. Nighttime is just as bright as daytime, for example. I wanted to use an image accurately showing the day/night divider moving across the globe. The best one I could find is here:
                            http://www.goes.noaa.gov/goesfull.html
                            On that page the “GOES East Visible” is exactly what I want, but sadly it’s in black-and-white. I’d love to have a color version of that. I may have to wait for that new satellite (Geos 16?) start publishing data.
                              BatterseaBridge @FlatPepsi
                              @FlatPepsi
                              Would this North American image work for you? https://www.nnvl.noaa.gov/images/FDC-latest.png
                                daikaiju @Renfield
                                @Renfield Did you find out how to update the code for this? I’m looking to refresh my image as well.
                                  Desertswing
                                  Hey all i got a problem with my Globe…
                                  error: Unable to append to .git/logs/refs/remotes/origin/develop: Permission denied
                                  From https://github.com/MichMich/MagicMirror
                                  ! a6485b6…88a01d3 develop -> origin/develop (unable to update local ref)
                                  error: cannot open .git/FETCH_HEAD: Permission denied
                                  what am i doing wrong ??
                                    daikaiju @LukeCodewalker
                                    @LukeCodewalker Can you tell us how to use our own images in your module?
                                    • SvenSommerS
                                      SvenSommer
                                      I just found this source here and thought about this module.
                                      http://earth.nullschool.net/
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                      • cowboysdudeC
                                        cowboysdude Module Developer @SvenSommer
                                        @SvenSommer WOW I really like that!!!
                                        iMAGiCI 1 Reply Last reply Reply Quote 0
                                        • iMAGiCI
                                          iMAGiC @cowboysdude
                                          @cowboysdude can it shows on pi 3, I’ve tried it in iFrame, but seems color and performance not enough. http://earth.nullschool.net/
                                          Choice * Judgment * Values
                                          • iMAGiCI
                                            iMAGiC
                                            Hi all,
                                            sometimes picture “geoColor” will missing or not keep update, after check the link. the link sometimes block for access, and you will get link broken message.
                                            so now, I’ve modified the link, use high resolution to instead, so far is ok, but it need more time when it is loading.
                                            just for your reference.
                                            this.imageUrls = {
                                            			'geoColor': 'http://rammb.cira.colostate.edu/ramsdis/online/images/latest_hi_res/himawari-8/full_disk_ahi_true_color.jpg',
                                            • 3 / 6
