    MMM-Globe
    119 Posts 39 Posters 233.9k Views 40 Watching
    • L Offline
      LukeCodewalker Module Developer @SvenSommer
      @SvenSommer
      Merged! Thank you
        binderth
        so great coming home from skiing and everything is already fixed and commited! Thanks, guys!
        looks awesome!
          Burner911
          This is awesome! Any chance of a view with North America centric? @LukeCodewalker
            schlachtkreuzer6 @Burner911
            @Burner911 if you find some image source :D
            • L Offline
              lolobyte
              Here are some needful sources
              http://earthdirectory.net/gsat
              http://goes.gsfc.nasa.gov/
              SvenSommerS 1 Reply Last reply Reply Quote 0
              • SvenSommerS Offline
                SvenSommer @lolobyte
                @lolobyte
                Thank you for the links.
                For central america I found the following source the most usefull. Unfortunately it’s only available in high resulution.
                http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg
                alt text
                Has anybody found more usefull sources by now?
                  Burner911
                  @SvenSommer That is the exact image I found as well. Any chance we could make this work @LukeCodewalker?
                  L SvenSommerS 2 Replies Last reply Reply Quote 0
                  • I Offline
                    in_a_days
                    Hopefully we’ll have a new feed from GOES-16 soon as well!
                    http://gizmodo.com/the-most-advanced-weather-satellite-yet-just-dropped-it-1791527000
                    • L Offline
                      LukeCodewalker Module Developer @Burner911
                      @Burner911 sure :) should be straight forward. I you know how to do it feel free to make a pull request. If not I can have a look at the weekend if I find some time.
                        SvenSommer @Burner911
                          Burner911 @LukeCodewalker
                          @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
                            SvenSommer
                            @LukeCodewalker, @Burner911
                            I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
                              Burner911 @SvenSommer
                              @SvenSommer You’re fast! Thank you!
                                Renfield
                                @LukeCodewalker
                                First, thanks for the great module!
                                I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
                                Is it possible that there’s a caching issue?
                                Thanks,
                                Renfield
                                • L Offline
                                  LukeCodewalker Module Developer @Renfield
                                  @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
                                  B D 2 Replies Last reply Reply Quote 0
                                    Renfield
                                    I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                                    ?+ new Date().getTime();
                                    to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                                    If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                                    Thanks,
                                    Renfield
                                    D 1 Reply Last reply Reply Quote -1
                                      chrisfoerg @lolobyte
                                      @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                                      S B 2 Replies Last reply Reply Quote 0
                                        schlachtkreuzer6 @chrisfoerg
                                        @chrisfoerg Niiiiiiiiiice!!!
                                          binderth @chrisfoerg
                                          @chrisfoerg Looks great! but if I understand it correctly, there’s no live-feed at the moment?
                                            schlachtkreuzer6 @binderth
                                            @binderth jep, they are testing the stuff and so on
                                            • 2 / 6
