    MMM-Globe
    119 Posts 39 Posters 239.8k Views 40 Watching
    • lolobyteL
      lolobyte @SvenSommer
      @SvenSommer
      Wrong, the picture source information was from me.
      You can read my first entry above the post from @binderth !
      • SvenSommerS
        SvenSommer
        @lolobyte
        Sorry. So, thank you for this excellente source!
        @LukeCodewalker
        readme is adjusted.
        LukeCodewalkerL 1 Reply Last reply
        • LukeCodewalkerL
          LukeCodewalker Module Developer @SvenSommer
          @SvenSommer
          Merged! Thank you
          • binderthB
            binderth
            so great coming home from skiing and everything is already fixed and commited! Thanks, guys!
            looks awesome!
              Burner911
              This is awesome! Any chance of a view with North America centric? @LukeCodewalker
              schlachtkreuzer6S 1 Reply Last reply
              • schlachtkreuzer6S
                schlachtkreuzer6 @Burner911
                @Burner911 if you find some image source :D
                • lolobyteL
                  lolobyte
                  Here are some needful sources
                  http://earthdirectory.net/gsat
                  http://goes.gsfc.nasa.gov/
                  SvenSommerS 1 Reply Last reply
                  • SvenSommerS
                    SvenSommer @lolobyte
                    @lolobyte
                    Thank you for the links.
                    For central america I found the following source the most usefull. Unfortunately it’s only available in high resulution.
                    http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg
                    alt text
                    Has anybody found more usefull sources by now?
                      Burner911
                      @SvenSommer That is the exact image I found as well. Any chance we could make this work @LukeCodewalker?
                      LukeCodewalkerL SvenSommerS 2 Replies Last reply
                      • in_a_daysI
                        in_a_days
                        Hopefully we’ll have a new feed from GOES-16 soon as well!
                        http://gizmodo.com/the-most-advanced-weather-satellite-yet-just-dropped-it-1791527000
                        • LukeCodewalkerL
                          LukeCodewalker Module Developer @Burner911
                          @Burner911 sure :) should be straight forward. I you know how to do it feel free to make a pull request. If not I can have a look at the weekend if I find some time.
                          B 1 Reply Last reply
                          • SvenSommerS
                            SvenSommer @Burner911
                              Burner911 @LukeCodewalker
                              @LukeCodewalker Thank you for helping out! I’m still stumbling along with the code, but if you have time to add the new http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg image this weekend that would be awesome.
                              • SvenSommerS
                                SvenSommer
                                @LukeCodewalker, @Burner911
                                I just integrated the ‘centralAmericaDiscNat’ option and made a pull request.
                                  Burner911 @SvenSommer
                                  @SvenSommer You’re fast! Thank you!
                                    Renfield
                                    @LukeCodewalker
                                    First, thanks for the great module!
                                    I’m having an issue with the module when I specify ‘ownImagePath’. The image is retrieved and displayed properly but does not update. I’ve tried several different external image sources with the same result.
                                    Is it possible that there’s a caching issue?
                                    Thanks,
                                    Renfield
                                    • LukeCodewalkerL
                                      LukeCodewalker Module Developer @Renfield
                                      @Renfield the module does only update the pre-defined satellite images. I did not implement that for own images. But that could be changed quickly. Do you think you can do that on your own or do you need help?
                                      B D 2 Replies Last reply
                                        Renfield
                                        I’m new to javascript but that’s what I thought I saw in the code (that the user images were purely static). I tried appending
                                        ?+ new Date().getTime();
                                        to the image pull but probably due to an error on my part still couldn’t get the user-defined images to force a refresh on each update to the DOM. I’m in the early stages of learning javascript so it’s still a bit frustrating at times.
                                        If you could add the fresh image retrieval functionality for user images to a future update that would be much appreciated but there’s no hurry. Should I put a “formal” request in the Requests forum?
                                        Thanks,
                                        Renfield
                                        D 1 Reply Last reply
                                        Reply Quote -1
                                          chrisfoerg @lolobyte
                                          @lolobyte it’s in German, maybe is this better :-) https://www.heise.de/newsticker/meldung/NASA-Satellit-GOES-16-Erste-beeindruckende-Fotos-der-Erde-3607307.html?wt_mc=rss.ho.beitrag.atom&hg=1&hgi=0&hgf=false
                                          schlachtkreuzer6S binderthB 2 Replies Last reply
                                          • schlachtkreuzer6S
                                            schlachtkreuzer6 @chrisfoerg
                                            @chrisfoerg Niiiiiiiiiice!!!
                                            • 2 / 6
