    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 25.0k Views 8 Watching
    • X
      xIExodusIx @rkorell
      @rkorell said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
      Currently - in my installation - the Info Box which is signalling the call is not a „message-box“ and disappears when call is ended.
      Did you modify this -then I would hesitate to install newest version…
      Thanks a lot for your effort!
      Hi Ralf,
      I did not change the appearance of the message-box, in the module it is an alert, I only tried to let it disappear right when you answer the incomming call, because on my MM2 the message box blurres the background and I can not clearly see all other modules and the “MMM-Current-Call” module, that also shows me if the current call is incomming or outgoing, but now the message box disappears when the incomming call is answered.
      The MMM-Current-Call" module makes only sense if you have more then one telephon-line, so you can see how many people are talking right now, and if the calls are incomming or outgoing.
      Hope that will help you to decide.
      Regards
      Carsten
        rkorell Module Developer @xIExodusIx
        @xIExodusIx Thanks again, this helps!
        Regards,
        Ralf
        X 1 Reply Last reply Reply Quote 0
        • X
          xIExodusIx @rkorell
          @rkorell
          I played a little bit around with the colors and changed also the appearance of missed calls, the missed calls now will be displayed in color “magenta” with a “star”. You can edit the colors by yourself by editing the “MMM-Fritz-Box-Callmonitor-py3.js” file, you can’t miss these entrys.
          I also edited the README.md file again.
          I will push these changes to github at my next update, but I have to test a little bit more because I have to wait for the unwanted calls that are in my blocked “phonenumber range list”, and I don’t know when these unwanted calls are incomming.
          But hopefully I got most of the annoying problems under control. :-)
          Regards
          Carsten
            @xIExodusIx It’s good practise to keep style information not in the *.js code but in the CSS file of module - than everybody can make persistent changes to style related issues in custom.css which will not been overwritten by module updates…
            Warm regards,
            Ralf
            • X
              xIExodusIx @rkorell
              @rkorell
              Yes, I know, but I don’t know how to transfer this code-lines to the .css file, the code for appaerance and color were in the module.js file before I began to try to get it work. I only modified them.
              The last two problems I have with the module is, to show the correct number in the callist, not “sip:myown number”, when an incomming call is blocket by the “number range list” and to hide the alert of these calls.
              On these problems I still work.
              Regards
              Carsten
                @xIExodusIx Dear Carsten,
                quick feedback for you: Just installed your newest version.
                And - to my big surprise - it works like I would like to have…
                I only have installed "MMM-FRITZ-Box-Callmonitor-py3 " - to be 100% clear, may there is the difference.
                But with only this module incoming calls are displayed/signalled (grey’ish / white color) and the message box disappears either when the call is taken or if the caller hangs up.
                This exactly is what I would like to have.
                You definitely have done something magical because the initial code holds the message box until call is ended.
                THANKS!!!
                You ARE a coder :-)
                Warmest greetings to Hamburg (as your git-account now reveals),
                Ralf
                For the CSS stuff - my apologies…
                I cannot guide here, as well. I’ve seen your color coding in dependency from call-type.
                I GUESS you can solve this with case-dependent CSS-attributes and so avoid the complete “switch”-clause.
                But this is far beyond my own capabilities - may Sam (@sdetweil ) can lead through this…
                  Jose1701 @rkorell
                  I`m new to magicmirror and I like the CallMonitor a lot.
                  Everthing works fine for me except the arrows and colours. I installed MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call. I put the necessary information in the conifg as ou can see:
                  		module: 'MMM-Callmonitor-Current-Call',
                  		position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
                  			showDirection: "true",
                  			colorEnabled: "true",
                  		module: 'MMM-FRITZ-Box-Callmonitor-py3',
                  		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
                  		header: "Letzte Anrufe", // This is optional
                  			showContactsStatus: "true",
                              	  fritzIP: "192.168.178.1",
                              	  maximumCallDistance: "240",
                                          maximumCalls: "4",
                                          reloadContactsInterval: "1",
                  			showOutgoing: "true",
                                          password: "******",
                  An idea what am I doing wrong?
                  Regards
                  Jose
                    rkorell Module Developer @Jose1701
                    @Jose1701 Dear Jose,
                    you are referring to my post but may I’m the wrong person.
                    You may ask the developer, @xIExodusIx, too.
                    As I’m not knowing exactly what your problem is, I just can guess what’s going on…
                    from configuration perspective I do not see an issue - mine is similar.
                    As I wrote before I only have ‘MMM-FRITZ-Box-Callmonitor-py3’ in use, NOT ‘MMM-Callmonitor-Current-Call’,
                    For ‘MMM-FRITZ-Box-Callmonitor-py3’ I’m aware of some problems, but I do not know if this aligns with your problems.
                    • do you have the right (actual) fork? in my case this was https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git
                    • I’m not sure if this is correct: In your config a username is missing. As far as I’m aware of you have to use a username/password combination - therefore I remember that I had to create a separate user for using the module.
                    • there were some requirements for the module - some python libraries as I remember correctly. - Do you have installed them in a proper version?
                    This is the “guessing” version.
                    If you could describe the “problem” more exact or concrete may we get other ideas…
                    Good luck!
                    Regards,
                    Ralf
                      Jose1701 @rkorell
                      @rkorell
                      sorry for the late response but I was ill and laying in bed.
                      I will have a look. Actually I have the following “proofed”.
                      Yes, I’m using this one, too.
                      Well, until now I didn’t need more. Everything is working fine except the arrows and colours. But I will see if sth. is needed.
                      I think I have the right ones and up to date but I will have a look, too.
                      Thanks so far.
                      Kind regards
                      Jose
                        Jose1701 @Jose1701
                        That was the reason. Don`t know it shows the calls without a password but not the arrows.
                        Now everything is working fine.
                        Thanks a greets
                        Jose
                          Mathes75
                          @xiexodusix - I set up my MagicMirror from scratch and now wanted to integrate the FRITZ-Callmonitor to it, unfortunately with no luck. No calls are displayed, the phonebook has non-stop rotating icon. In the docker logs (Yes, I’m using latest MagicMirrorOS with integrated Docker) I get the following error:
                          [2026-01-11 02:10:11.646] [ERROR] [app] Whoops! There was an uncaught exception...
                          [2026-01-11 02:10:11.684] [ERROR] [app] Error: spawn python3 ENOENT
                              at ChildProcess._handle.onexit (node:internal/child_process:285:19)
                              at onErrorNT (node:internal/child_process:483:16)
                              at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                            errno: -2,
                            code: 'ENOENT',
                            syscall: 'spawn python3',
                            path: 'python3',
                            spawnargs: [
                              '/opt/magic_mirror/modules/MMM-FRITZ-Box-Callmonitor-py3/fritz_access.py',
                              '-i',
                              '192.168.0.1',
                              '-p',
                              '-u',
                              'magicmirror'
                          [2026-01-11 02:10:11.686] [ERROR] [app] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          As you can see, I have created username and password only for MM.
                          Starting fritzconnection from (host) commandline works, incomming calls are registered and shown in Terminal.
                          • karsten13K
                            karsten13 @Mathes75
                            @Mathes75
                            probably python missing, see https://khassel.gitlab.io/magicmirror/faq/dependencies/#use-the-fat-image
                            You can change the image in the .env file.
                              Mathes75 @karsten13
                              @karsten13 to get this right: Using the fat image would have at least python on board. And to get everything to work I would need to add a script, adding the dependencies for MMM-FRITZ-Box-Callmonitor-py3:
                              Execute npm install to install the dependencies.
                              (Optional) Execute sudo apt-get install python3-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install --break-system-packages fritzconnection to allow access to your FRITZ!Box phone book and recent calls. This can take a few minutes.
                              Will definitely give it a try!
                                Mathes75 @Mathes75
                                Hello @karsten13,
                                I have changed the docker image to fat in .env file. Unfortunately, after pulling the docker image, the script stopped with error: No such container: 1b169eacdb711[~35 more numbers/letters].
                                Magic Mirror stopped working :( What did I do wrong?
                                • karsten13K
                                  karsten13 @Mathes75
                                  @Mathes75
                                  which script?
                                  show content of “the script” and output of docker compose config
                                    Mathes75 @karsten13
                                    @karsten13
                                    Sorry for being that unspecific. I changed the .env file in the “Docker image to use” section:
                                    # Docker Images to use:
                                    MM_IMAGE="karsten13/magicmirror:v2.34.0_fat"
                                    LABWC_IMAGE="karsten13/labwc:latest"
                                    MMPM_IMAGE="karsten13/mmpm:latest"
                                    WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
                                    Executed cd /opt/mm/run && docker compose up -d --force-recreate and the download started. After successfully pulling the image, Terminal stopped here:
                                     ✔ Image karsten13/magicmirror:fat Pulled                                318.2s
                                       ✔ 304150113e8d                  Pull complete                          97.1s
                                       ✔ 964f5c44c7bd                  Pull complete                           0.9s
                                       ✔ ac8996972af0                  Pull complete                           0.9s
                                       ✔ 3ee9d8e5c8b3                  Pull complete                         131.8s
                                       ✔ f9b5315e0a0e                  Pull complete                           0.8s
                                       ✔ 5e7a4985a616                  Pull complete                           0.7s
                                       ✔ 9f175b8c171e                  Pull complete                          98.7s
                                       ✔ c1be2df81e57                  Pull complete                           0.7s
                                       ✔ 4f4fb700ef54                  Pull complete                           0.0s
                                       ✔ 9dcfcb600955                  Pull complete                           1.0s
                                       ✔ 0902543587b7                  Pull complete                         212.6s
                                       ✔ 6454a8f98e11                  Pull complete                         314.9s
                                       ✔ fe8e38a18048                  Pull complete                          97.6s
                                       ✔ a4662295f62c                  Pull complete                           0.9s
                                       ✔ c5dcf86b0f8a                  Pull complete                           1.0s
                                     ✔ Network magicmirror_default     Created                                 0.4s
                                     ✘ Container 1b169eacdb71          Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b 6.8s
                                    Output of docker compose config:
                                    services:
                                      labwc:
                                        container_name: labwc
                                        environment:
                                          LAB_WC_HIDE_CURSOR: "true"
                                          RANDR_PARAMS: ""
                                          RANDR_POLL: 1m
                                          XDG_RUNTIME_DIR: /tmp/labwc
                                        image: karsten13/labwc:latest
                                        networks:
                                          default: null
                                        privileged: true
                                        restart: always
                                        volumes:
                                          - type: bind
                                            source: /tmp/labwc
                                            target: /tmp/labwc
                                            bind: {}
                                          - type: bind
                                            source: /run/udev
                                            target: /run/udev
                                            bind: {}
                                      magicmirror:
                                        container_name: mm
                                        depends_on:
                                          labwc:
                                            condition: service_healthy
                                            restart: true
                                            required: true
                                        environment:
                                          DISPLAY: unix:0.0
                                          ELECTRON_ENABLE_GPU: "0"
                                          MM_CUSTOMCSS_FILE: css/custom.css
                                          MM_MODULES_DIR: modules
                                          MM_OVERRIDE_DEFAULT_MODULES: "true"
                                          MM_SCENARIO: electron
                                          MM_SHOW_CURSOR: "false"
                                          WAYLAND_DISPLAY: wayland-0
                                        image: karsten13/magicmirror:v2.34.0_fat
                                        network_mode: host
                                        privileged: true
                                        restart: always
                                        shm_size: "268435456"
                                        volumes:
                                          - type: bind
                                            source: /tmp/.X11-unix
                                            target: /tmp/.X11-unix
                                            bind: {}
                                          - type: bind
                                            source: /home/pi/.Xauthority
                                            target: /home/node/.Xauthority
                                            bind: {}
                                          - type: bind
                                            source: /tmp/labwc
                                            target: /tmp/labwc
                                            bind: {}
                                          - type: bind
                                            source: /opt/mm/mounts/config
                                            target: /opt/magic_mirror/config
                                            bind: {}
                                          - type: bind
                                            source: /opt/mm/mounts/modules
                                            target: /opt/magic_mirror/modules
                                            bind: {}
                                          - type: bind
                                            source: /opt/mm/mounts/css/custom.css
                                            target: /opt/magic_mirror/css/custom.css
                                            bind: {}
                                        post_start:
                                          - command:
                                              - /bin/sh
                                              - -c
                                                if [ "init" = "init" ]; then
                                                  # update volume permissions
                                                  chown -R 1000:1000 config modules css/custom.css
                                                  chmod -R 777 config modules css/custom.css
                                                fi
                                                if command -v node_modules/.bin/electron > /dev/null; then
                                                  # if electron is installed then start dbus-daemon to avoid errors in the logs
                                                  dbus-daemon --system || true
                                                fi
                                            user: root
                                    networks:
                                      default:
                                    • karsten13K
                                      karsten13 @Mathes75
                                      @Mathes75
                                      looks like there is an old container but no idea why docker is unable to remove it.
                                      You can try
                                      cd /opt/mm/run
                                      docker compose down
                                      docker rm -f $(docker ps -aq)
                                        Mathes75 @karsten13
                                        @karsten13
                                        Doesn´t look good. I’m too noob about Docker to really understand what’s going on:
                                        pi@magicmirrorMB:~ $ cd /opt/mm/run/
                                        pi@magicmirrorMB:/opt/mm/run $ docker compose down
                                        [+] down 1/1
                                         ✔ Container 1b169eacdb71 Removed                                          0.0s
                                        pi@magicmirrorMB:/opt/mm/run $ docker rm -f $(docker ps -aq)
                                        pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
                                        WARN[0000] No services to build
                                        [+] up 2/2
                                         ✔ Network magicmirror_default Created                                     0.2s
                                         ✔ Container mm                Created                                     0.9s
                                        After last line just nothing happens. No prompt, no display on mirror.
                                        Can I check where the strange container is called or where the reference is?
                                        • karsten13K
                                          karsten13 @Mathes75
                                          @Mathes75
                                          show docker ps -a.
                                          From the logs it looks like the strange container was deleted but I see no labwc container.
                                            Mathes75 @karsten13
                                            @karsten13
                                            pi@magicmirrorMB:/opt/mm/run $ docker ps -a
                                            CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
                                            1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
                                            What? There must be something completely wrong…
                                            • 3 / 4
