    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 23.7k Views 8 Watching
      rkorell Module Developer @xIExodusIx
      @xIExodusIx It’s good practise to keep style information not in the *.js code but in the CSS file of module - than everybody can make persistent changes to style related issues in custom.css which will not been overwritten by module updates…
      Warm regards,
      Ralf
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xIExodusIx @rkorell
        @rkorell
        Yes, I know, but I don’t know how to transfer this code-lines to the .css file, the code for appaerance and color were in the module.js file before I began to try to get it work. I only modified them.
        The last two problems I have with the module is, to show the correct number in the callist, not “sip:myown number”, when an incomming call is blocket by the “number range list” and to hide the alert of these calls.
        On these problems I still work.
        Regards
        Carsten
          @xIExodusIx Dear Carsten,
          quick feedback for you: Just installed your newest version.
          And - to my big surprise - it works like I would like to have…
          I only have installed "MMM-FRITZ-Box-Callmonitor-py3 " - to be 100% clear, may there is the difference.
          But with only this module incoming calls are displayed/signalled (grey’ish / white color) and the message box disappears either when the call is taken or if the caller hangs up.
          This exactly is what I would like to have.
          You definitely have done something magical because the initial code holds the message box until call is ended.
          THANKS!!!
          You ARE a coder :-)
          Warmest greetings to Hamburg (as your git-account now reveals),
          Ralf
          For the CSS stuff - my apologies…
          I cannot guide here, as well. I’ve seen your color coding in dependency from call-type.
          I GUESS you can solve this with case-dependent CSS-attributes and so avoid the complete “switch”-clause.
          But this is far beyond my own capabilities - may Sam (@sdetweil ) can lead through this…
            Jose1701 @rkorell
            I`m new to magicmirror and I like the CallMonitor a lot.
            Everthing works fine for me except the arrows and colours. I installed MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call. I put the necessary information in the conifg as ou can see:
            		module: 'MMM-Callmonitor-Current-Call',
            		position: 'top_right',	// This can be any of the regions. Best results in left or right regions.
            			showDirection: "true",
            			colorEnabled: "true",
            		module: 'MMM-FRITZ-Box-Callmonitor-py3',
            		position: 'bottom_right',	// This can be any of the regions. Best results in left or right regions.
            		header: "Letzte Anrufe", // This is optional
            			showContactsStatus: "true",
                        	  fritzIP: "192.168.178.1",
                        	  maximumCallDistance: "240",
                                    maximumCalls: "4",
                                    reloadContactsInterval: "1",
            			showOutgoing: "true",
                                    password: "******",
            An idea what am I doing wrong?
            Regards
            Jose
              rkorell Module Developer @Jose1701
              @Jose1701 Dear Jose,
              you are referring to my post but may I’m the wrong person.
              You may ask the developer, @xIExodusIx, too.
              As I’m not knowing exactly what your problem is, I just can guess what’s going on…
              from configuration perspective I do not see an issue - mine is similar.
              As I wrote before I only have ‘MMM-FRITZ-Box-Callmonitor-py3’ in use, NOT ‘MMM-Callmonitor-Current-Call’,
              For ‘MMM-FRITZ-Box-Callmonitor-py3’ I’m aware of some problems, but I do not know if this aligns with your problems.
              • do you have the right (actual) fork? in my case this was https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git
              • I’m not sure if this is correct: In your config a username is missing. As far as I’m aware of you have to use a username/password combination - therefore I remember that I had to create a separate user for using the module.
              • there were some requirements for the module - some python libraries as I remember correctly. - Do you have installed them in a proper version?
              This is the “guessing” version.
              If you could describe the “problem” more exact or concrete may we get other ideas…
              Good luck!
              Regards,
              Ralf
                Jose1701 @rkorell
                @rkorell
                sorry for the late response but I was ill and laying in bed.
                I will have a look. Actually I have the following “proofed”.
                @rkorell said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
                Yes, I’m using this one, too.
                Well, until now I didn’t need more. Everything is working fine except the arrows and colours. But I will see if sth. is needed.
                I think I have the right ones and up to date but I will have a look, too.
                Thanks so far.
                Kind regards
                Jose
                  Jose1701 @Jose1701
                  That was the reason. Don`t know it shows the calls without a password but not the arrows.
                  Now everything is working fine.
                  Thanks a greets
                  Jose
                    Mathes75
                    @xiexodusix - I set up my MagicMirror from scratch and now wanted to integrate the FRITZ-Callmonitor to it, unfortunately with no luck. No calls are displayed, the phonebook has non-stop rotating icon. In the docker logs (Yes, I’m using latest MagicMirrorOS with integrated Docker) I get the following error:
                    [2026-01-11 02:10:11.646] [ERROR] [app] Whoops! There was an uncaught exception...
                    [2026-01-11 02:10:11.684] [ERROR] [app] Error: spawn python3 ENOENT
                        at ChildProcess._handle.onexit (node:internal/child_process:285:19)
                        at onErrorNT (node:internal/child_process:483:16)
                        at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
                      errno: -2,
                      code: 'ENOENT',
                      syscall: 'spawn python3',
                      path: 'python3',
                      spawnargs: [
                        '/opt/magic_mirror/modules/MMM-FRITZ-Box-Callmonitor-py3/fritz_access.py',
                        '-i',
                        '192.168.0.1',
                        '-p',
                        '-u',
                        'magicmirror'
                    [2026-01-11 02:10:11.686] [ERROR] [app] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    As you can see, I have created username and password only for MM.
                    Starting fritzconnection from (host) commandline works, incomming calls are registered and shown in Terminal.
                    • karsten13K Offline
                      karsten13 @Mathes75
                      @Mathes75
                      probably python missing, see https://khassel.gitlab.io/magicmirror/faq/dependencies/#use-the-fat-image
                      You can change the image in the .env file.
                        Mathes75 @karsten13
                        @karsten13 to get this right: Using the fat image would have at least python on board. And to get everything to work I would need to add a script, adding the dependencies for MMM-FRITZ-Box-Callmonitor-py3:
                        Execute npm install to install the dependencies.
                        (Optional) Execute sudo apt-get install python3-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install --break-system-packages fritzconnection to allow access to your FRITZ!Box phone book and recent calls. This can take a few minutes.
                        Will definitely give it a try!
                          Mathes75 @Mathes75
                          Hello @karsten13,
                          I have changed the docker image to fat in .env file. Unfortunately, after pulling the docker image, the script stopped with error: No such container: 1b169eacdb711[~35 more numbers/letters].
                          Magic Mirror stopped working :( What did I do wrong?
                            karsten13 @Mathes75
                            @Mathes75
                            which script?
                            show content of “the script” and output of docker compose config
                              Mathes75 @karsten13
                              @karsten13
                              Sorry for being that unspecific. I changed the .env file in the “Docker image to use” section:
                              # Docker Images to use:
                              MM_IMAGE="karsten13/magicmirror:v2.34.0_fat"
                              LABWC_IMAGE="karsten13/labwc:latest"
                              MMPM_IMAGE="karsten13/mmpm:latest"
                              WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
                              Executed cd /opt/mm/run && docker compose up -d --force-recreate and the download started. After successfully pulling the image, Terminal stopped here:
                               ✔ Image karsten13/magicmirror:fat Pulled                                318.2s
                                 ✔ 304150113e8d                  Pull complete                          97.1s
                                 ✔ 964f5c44c7bd                  Pull complete                           0.9s
                                 ✔ ac8996972af0                  Pull complete                           0.9s
                                 ✔ 3ee9d8e5c8b3                  Pull complete                         131.8s
                                 ✔ f9b5315e0a0e                  Pull complete                           0.8s
                                 ✔ 5e7a4985a616                  Pull complete                           0.7s
                                 ✔ 9f175b8c171e                  Pull complete                          98.7s
                                 ✔ c1be2df81e57                  Pull complete                           0.7s
                                 ✔ 4f4fb700ef54                  Pull complete                           0.0s
                                 ✔ 9dcfcb600955                  Pull complete                           1.0s
                                 ✔ 0902543587b7                  Pull complete                         212.6s
                                 ✔ 6454a8f98e11                  Pull complete                         314.9s
                                 ✔ fe8e38a18048                  Pull complete                          97.6s
                                 ✔ a4662295f62c                  Pull complete                           0.9s
                                 ✔ c5dcf86b0f8a                  Pull complete                           1.0s
                               ✔ Network magicmirror_default     Created                                 0.4s
                               ✘ Container 1b169eacdb71          Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b 6.8s
                              Output of docker compose config:
                              services:
                                labwc:
                                  container_name: labwc
                                  environment:
                                    LAB_WC_HIDE_CURSOR: "true"
                                    RANDR_PARAMS: ""
                                    RANDR_POLL: 1m
                                    XDG_RUNTIME_DIR: /tmp/labwc
                                  image: karsten13/labwc:latest
                                  networks:
                                    default: null
                                  privileged: true
                                  restart: always
                                  volumes:
                                    - type: bind
                                      source: /tmp/labwc
                                      target: /tmp/labwc
                                      bind: {}
                                    - type: bind
                                      source: /run/udev
                                      target: /run/udev
                                      bind: {}
                                magicmirror:
                                  container_name: mm
                                  depends_on:
                                    labwc:
                                      condition: service_healthy
                                      restart: true
                                      required: true
                                  environment:
                                    DISPLAY: unix:0.0
                                    ELECTRON_ENABLE_GPU: "0"
                                    MM_CUSTOMCSS_FILE: css/custom.css
                                    MM_MODULES_DIR: modules
                                    MM_OVERRIDE_DEFAULT_MODULES: "true"
                                    MM_SCENARIO: electron
                                    MM_SHOW_CURSOR: "false"
                                    WAYLAND_DISPLAY: wayland-0
                                  image: karsten13/magicmirror:v2.34.0_fat
                                  network_mode: host
                                  privileged: true
                                  restart: always
                                  shm_size: "268435456"
                                  volumes:
                                    - type: bind
                                      source: /tmp/.X11-unix
                                      target: /tmp/.X11-unix
                                      bind: {}
                                    - type: bind
                                      source: /home/pi/.Xauthority
                                      target: /home/node/.Xauthority
                                      bind: {}
                                    - type: bind
                                      source: /tmp/labwc
                                      target: /tmp/labwc
                                      bind: {}
                                    - type: bind
                                      source: /opt/mm/mounts/config
                                      target: /opt/magic_mirror/config
                                      bind: {}
                                    - type: bind
                                      source: /opt/mm/mounts/modules
                                      target: /opt/magic_mirror/modules
                                      bind: {}
                                    - type: bind
                                      source: /opt/mm/mounts/css/custom.css
                                      target: /opt/magic_mirror/css/custom.css
                                      bind: {}
                                  post_start:
                                    - command:
                                        - /bin/sh
                                        - -c
                                          if [ "init" = "init" ]; then
                                            # update volume permissions
                                            chown -R 1000:1000 config modules css/custom.css
                                            chmod -R 777 config modules css/custom.css
                                          fi
                                          if command -v node_modules/.bin/electron > /dev/null; then
                                            # if electron is installed then start dbus-daemon to avoid errors in the logs
                                            dbus-daemon --system || true
                                          fi
                                      user: root
                              networks:
                                default:
                                karsten13 @Mathes75
                                @Mathes75
                                looks like there is an old container but no idea why docker is unable to remove it.
                                You can try
                                cd /opt/mm/run
                                docker compose down
                                docker rm -f $(docker ps -aq)
                                  Mathes75 @karsten13
                                  @karsten13
                                  Doesn´t look good. I’m too noob about Docker to really understand what’s going on:
                                  pi@magicmirrorMB:~ $ cd /opt/mm/run/
                                  pi@magicmirrorMB:/opt/mm/run $ docker compose down
                                  [+] down 1/1
                                   ✔ Container 1b169eacdb71 Removed                                          0.0s
                                  pi@magicmirrorMB:/opt/mm/run $ docker rm -f $(docker ps -aq)
                                  pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
                                  WARN[0000] No services to build
                                  [+] up 2/2
                                   ✔ Network magicmirror_default Created                                     0.2s
                                   ✔ Container mm                Created                                     0.9s
                                  After last line just nothing happens. No prompt, no display on mirror.
                                  Can I check where the strange container is called or where the reference is?
                                    karsten13 @Mathes75
                                    @Mathes75
                                    show docker ps -a.
                                    From the logs it looks like the strange container was deleted but I see no labwc container.
                                      Mathes75 @karsten13
                                      @karsten13
                                      pi@magicmirrorMB:/opt/mm/run $ docker ps -a
                                      CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
                                      1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
                                      What? There must be something completely wrong…
                                        Mathes75 @karsten13
                                        @karsten13
                                        Is there a way to reload the images from scratch, delete them from the RPi without losing the customization?
                                          karsten13 @Mathes75
                                          @Mathes75
                                          really strange, the 1b1... is still there …
                                          try docker system prune -f and check after this again docker ps -a
                                            Mathes75 @karsten13
                                            @karsten13
                                            After docker compose down, prune resulted in Total reclaimed space: 0B .
                                            When trying to start the containers and running the commands:
                                            [+] up 2/2
                                             ✔ Container mm                Created        0.5s
                                            pi@magicmirrorMB:/opt/mm/run $ docker system prune -f
                                            Deleted Containers:
                                            b04e79ead19ae7e42b7c7899f8e9b4b2d4f870770362c684bfadbfdaae6725aa
                                            Deleted Networks:
                                            magicmirror_default
                                            Total reclaimed space: 4.096kB
                                            1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   9 days ago   Exited (128) 2 days ago
                                            I think the easiest way is to start from scratch. Save the config.js, remember the modules and just reinstall. Switch to fat image again and fiddle around with FRITZ stuff. Sorry for keeping you busy and thanks a lot for your help and patience!
                                            Let me know if you want to finish troubleshooting ;-)
                                            • 3 / 4
