    MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call
    69 Posts 7 Posters 20.3k Views 8 Watching
      rkorell Module Developer @Jose1701
      @Jose1701 Dear Jose,
      you are referring to my post but may I’m the wrong person.
      You may ask the developer, @xIExodusIx, too.
      As I’m not knowing exactly what your problem is, I just can guess what’s going on…
      from configuration perspective I do not see an issue - mine is similar.
      As I wrote before I only have ‘MMM-FRITZ-Box-Callmonitor-py3’ in use, NOT ‘MMM-Callmonitor-Current-Call’,
      For ‘MMM-FRITZ-Box-Callmonitor-py3’ I’m aware of some problems, but I do not know if this aligns with your problems.
      • do you have the right (actual) fork? in my case this was https://github.com/xIExodusIx/MMM-FRITZ-Box-Callmonitor-py3.git
      • I’m not sure if this is correct: In your config a username is missing. As far as I’m aware of you have to use a username/password combination - therefore I remember that I had to create a separate user for using the module.
      • there were some requirements for the module - some python libraries as I remember correctly. - Do you have installed them in a proper version?
      This is the “guessing” version.
      If you could describe the “problem” more exact or concrete may we get other ideas…
      Good luck!
      Regards,
      Ralf
        Jose1701 @rkorell
        @rkorell
        sorry for the late response but I was ill and laying in bed.
        I will have a look. Actually I have the following “proofed”.
        @rkorell said in MMM-FRITZ-Box-Callmonitor-py3 and MMM-Callmonitor-Current-Call:
        Yes, I’m using this one, too.
        Well, until now I didn’t need more. Everything is working fine except the arrows and colours. But I will see if sth. is needed.
        I think I have the right ones and up to date but I will have a look, too.
        Thanks so far.
        Kind regards
        Jose
          Jose1701 @Jose1701
          That was the reason. Don`t know it shows the calls without a password but not the arrows.
          Now everything is working fine.
          Thanks a greets
          Jose
            Mathes75
            @xiexodusix - I set up my MagicMirror from scratch and now wanted to integrate the FRITZ-Callmonitor to it, unfortunately with no luck. No calls are displayed, the phonebook has non-stop rotating icon. In the docker logs (Yes, I’m using latest MagicMirrorOS with integrated Docker) I get the following error:
            [2026-01-11 02:10:11.646] [ERROR] [app] Whoops! There was an uncaught exception...
            [2026-01-11 02:10:11.684] [ERROR] [app] Error: spawn python3 ENOENT
                at ChildProcess._handle.onexit (node:internal/child_process:285:19)
                at onErrorNT (node:internal/child_process:483:16)
                at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
              errno: -2,
              code: 'ENOENT',
              syscall: 'spawn python3',
              path: 'python3',
              spawnargs: [
                '/opt/magic_mirror/modules/MMM-FRITZ-Box-Callmonitor-py3/fritz_access.py',
                '-i',
                '192.168.0.1',
                '-p',
                '-u',
                'magicmirror'
            [2026-01-11 02:10:11.686] [ERROR] [app] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            As you can see, I have created username and password only for MM.
            Starting fritzconnection from (host) commandline works, incomming calls are registered and shown in Terminal.
            • karsten13K Online
              karsten13 @Mathes75
              @Mathes75
              probably python missing, see https://khassel.gitlab.io/magicmirror/faq/dependencies/#use-the-fat-image
              You can change the image in the .env file.
                Mathes75 @karsten13
                @karsten13 to get this right: Using the fat image would have at least python on board. And to get everything to work I would need to add a script, adding the dependencies for MMM-FRITZ-Box-Callmonitor-py3:
                Execute npm install to install the dependencies.
                (Optional) Execute sudo apt-get install python3-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install --break-system-packages fritzconnection to allow access to your FRITZ!Box phone book and recent calls. This can take a few minutes.
                Will definitely give it a try!
                  Mathes75 @Mathes75
                  Hello @karsten13,
                  I have changed the docker image to fat in .env file. Unfortunately, after pulling the docker image, the script stopped with error: No such container: 1b169eacdb711[~35 more numbers/letters].
                  Magic Mirror stopped working :( What did I do wrong?
                  • karsten13K Online
                    karsten13 @Mathes75
                    @Mathes75
                    which script?
                    show content of “the script” and output of docker compose config
                      Mathes75 @karsten13
                      @karsten13
                      Sorry for being that unspecific. I changed the .env file in the “Docker image to use” section:
                      # Docker Images to use:
                      MM_IMAGE="karsten13/magicmirror:v2.34.0_fat"
                      LABWC_IMAGE="karsten13/labwc:latest"
                      MMPM_IMAGE="karsten13/mmpm:latest"
                      WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
                      Executed cd /opt/mm/run && docker compose up -d --force-recreate and the download started. After successfully pulling the image, Terminal stopped here:
                       ✔ Image karsten13/magicmirror:fat Pulled                                318.2s
                         ✔ 304150113e8d                  Pull complete                          97.1s
                         ✔ 964f5c44c7bd                  Pull complete                           0.9s
                         ✔ ac8996972af0                  Pull complete                           0.9s
                         ✔ 3ee9d8e5c8b3                  Pull complete                         131.8s
                         ✔ f9b5315e0a0e                  Pull complete                           0.8s
                         ✔ 5e7a4985a616                  Pull complete                           0.7s
                         ✔ 9f175b8c171e                  Pull complete                          98.7s
                         ✔ c1be2df81e57                  Pull complete                           0.7s
                         ✔ 4f4fb700ef54                  Pull complete                           0.0s
                         ✔ 9dcfcb600955                  Pull complete                           1.0s
                         ✔ 0902543587b7                  Pull complete                         212.6s
                         ✔ 6454a8f98e11                  Pull complete                         314.9s
                         ✔ fe8e38a18048                  Pull complete                          97.6s
                         ✔ a4662295f62c                  Pull complete                           0.9s
                         ✔ c5dcf86b0f8a                  Pull complete                           1.0s
                       ✔ Network magicmirror_default     Created                                 0.4s
                       ✘ Container 1b169eacdb71          Error response from daemon: No such container: 1b169eacdb711404e12c838a79de243c677daaaea260867d04c133a86cc3025b 6.8s
                      Output of docker compose config:
                      services:
                        labwc:
                          container_name: labwc
                          environment:
                            LAB_WC_HIDE_CURSOR: "true"
                            RANDR_PARAMS: ""
                            RANDR_POLL: 1m
                            XDG_RUNTIME_DIR: /tmp/labwc
                          image: karsten13/labwc:latest
                          networks:
                            default: null
                          privileged: true
                          restart: always
                          volumes:
                            - type: bind
                              source: /tmp/labwc
                              target: /tmp/labwc
                              bind: {}
                            - type: bind
                              source: /run/udev
                              target: /run/udev
                              bind: {}
                        magicmirror:
                          container_name: mm
                          depends_on:
                            labwc:
                              condition: service_healthy
                              restart: true
                              required: true
                          environment:
                            DISPLAY: unix:0.0
                            ELECTRON_ENABLE_GPU: "0"
                            MM_CUSTOMCSS_FILE: css/custom.css
                            MM_MODULES_DIR: modules
                            MM_OVERRIDE_DEFAULT_MODULES: "true"
                            MM_SCENARIO: electron
                            MM_SHOW_CURSOR: "false"
                            WAYLAND_DISPLAY: wayland-0
                          image: karsten13/magicmirror:v2.34.0_fat
                          network_mode: host
                          privileged: true
                          restart: always
                          shm_size: "268435456"
                          volumes:
                            - type: bind
                              source: /tmp/.X11-unix
                              target: /tmp/.X11-unix
                              bind: {}
                            - type: bind
                              source: /home/pi/.Xauthority
                              target: /home/node/.Xauthority
                              bind: {}
                            - type: bind
                              source: /tmp/labwc
                              target: /tmp/labwc
                              bind: {}
                            - type: bind
                              source: /opt/mm/mounts/config
                              target: /opt/magic_mirror/config
                              bind: {}
                            - type: bind
                              source: /opt/mm/mounts/modules
                              target: /opt/magic_mirror/modules
                              bind: {}
                            - type: bind
                              source: /opt/mm/mounts/css/custom.css
                              target: /opt/magic_mirror/css/custom.css
                              bind: {}
                          post_start:
                            - command:
                                - /bin/sh
                                - -c
                                  if [ "init" = "init" ]; then
                                    # update volume permissions
                                    chown -R 1000:1000 config modules css/custom.css
                                    chmod -R 777 config modules css/custom.css
                                  fi
                                  if command -v node_modules/.bin/electron > /dev/null; then
                                    # if electron is installed then start dbus-daemon to avoid errors in the logs
                                    dbus-daemon --system || true
                                  fi
                              user: root
                      networks:
                        default:
                      • karsten13K Online
                        karsten13 @Mathes75
                        @Mathes75
                        looks like there is an old container but no idea why docker is unable to remove it.
                        You can try
                        cd /opt/mm/run
                        docker compose down
                        docker rm -f $(docker ps -aq)
                          Mathes75 @karsten13
                          @karsten13
                          Doesn´t look good. I’m too noob about Docker to really understand what’s going on:
                          pi@magicmirrorMB:~ $ cd /opt/mm/run/
                          pi@magicmirrorMB:/opt/mm/run $ docker compose down
                          [+] down 1/1
                           ✔ Container 1b169eacdb71 Removed                                          0.0s
                          pi@magicmirrorMB:/opt/mm/run $ docker rm -f $(docker ps -aq)
                          pi@magicmirrorMB:/opt/mm/run $ docker compose up -d
                          WARN[0000] No services to build
                          [+] up 2/2
                           ✔ Network magicmirror_default Created                                     0.2s
                           ✔ Container mm                Created                                     0.9s
                          After last line just nothing happens. No prompt, no display on mirror.
                          Can I check where the strange container is called or where the reference is?
                          • karsten13K Online
                            karsten13 @Mathes75
                            @Mathes75
                            show docker ps -a.
                            From the logs it looks like the strange container was deleted but I see no labwc container.
                              Mathes75 @karsten13
                              @karsten13
                              pi@magicmirrorMB:/opt/mm/run $ docker ps -a
                              CONTAINER ID   IMAGE                    COMMAND            CREATED      STATUS                    PORTS     NAMES
                              1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   8 days ago   Exited (128) 2 days ago
                              What? There must be something completely wrong…
                                Mathes75 @karsten13
                                @karsten13
                                Is there a way to reload the images from scratch, delete them from the RPi without losing the customization?
                                • karsten13K Online
                                  karsten13 @Mathes75
                                  @Mathes75
                                  really strange, the 1b1... is still there …
                                  try docker system prune -f and check after this again docker ps -a
                                    Mathes75 @karsten13
                                    @karsten13
                                    After docker compose down, prune resulted in Total reclaimed space: 0B .
                                    When trying to start the containers and running the commands:
                                    [+] up 2/2
                                     ✔ Container mm                Created        0.5s
                                    pi@magicmirrorMB:/opt/mm/run $ docker system prune -f
                                    Deleted Containers:
                                    b04e79ead19ae7e42b7c7899f8e9b4b2d4f870770362c684bfadbfdaae6725aa
                                    Deleted Networks:
                                    magicmirror_default
                                    Total reclaimed space: 4.096kB
                                    1b169eacdb71   karsten13/labwc:latest   "/entrypoint.sh"   9 days ago   Exited (128) 2 days ago
                                    I think the easiest way is to start from scratch. Save the config.js, remember the modules and just reinstall. Switch to fat image again and fiddle around with FRITZ stuff. Sorry for keeping you busy and thanks a lot for your help and patience!
                                    Let me know if you want to finish troubleshooting ;-)
                                    • karsten13K Online
                                      karsten13 @Mathes75
                                      @Mathes75
                                      one thing (if not already done) would be a reboot and then again the prune command.
                                      Otherwise start from scratch …
                                        Mathes75 @karsten13
                                        @karsten13
                                        To make it short - same. Will start from scratch and let you know.
                                          Mathes75 @Mathes75
                                          Short and final update on this - I give up.
                                          Reimaged the card, edited the .env file before first start, so directly pulled the fat image. Set up my standard Modules, everything up and running - except MMM-FRITZ-BoxCallmonitor - and started to test mounts to map the fritzconnection Python scripts… as again, a strange container showed up:
                                          pi@magicmirroros:/opt/mm/run $ docker compose up -d
                                          [+] up 2/2
                                           ✘ Container b053acabeef9 Error response from daemon: No such container: b053acabeef9f142eb3382656732bee6b75d549c10ec2ef80da27ec2c60946d6                                          2.2s
                                           ✔ Container labwc        Recreated        2.2s
                                          Now I am sure my trusty SDcard is corrupt. Thanks @karsten13 for all the troubleshooting and help! I have learned a lot around Docker last days.
                                          Will get a new card and see some time. Other projects requiring my attention.
                                            MiPraSo @rkorell
                                            @rkorell
                                            Thank you for the adjustment. Now the pop-up window no longer freezes when calls are blocked. The installation worked as described here.
                                            Regards,
                                            Michael
                                            • 3 / 4
