    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 69.3k Views 18 Watching
    • G
      gismo2006
      @Jopyth some time ago my mirror suddenly didn’t work whit pm2. From one day to the other. I changed nothing and it works fine before. I didn’t know what happens. But then I found a little order in the display when I prompt pm2 start mm… I didn’ t rember the order but I know pm2 worked some second displayed something and then everything works fine again. …
      Maybe you found something , too
      Greets gismo
      • MichMichM
        MichMich
        Guys, I’ve just made a modification that hides a region if all modules in a region are hidden. This should prevent unwanted margins when a region (like the top_bar) only contains hidden modules. This allows my to move the updatenotification module to the topbar.
        Due to the nature of the change, this could cause some serious issues if it contains any missed bugs. It would be great if you guys gan pull the latest version and let me know if everything keeps working. If you’re having issues with some modules not showing up, please let me know.
        More info about this change can be found here: https://github.com/MichMich/MagicMirror/commit/e4197012f65778f815cd73a6c7fab1a30ef3b92f
        Thanks!
        E 1 Reply Last reply
        • E
          ESOB @MichMich
          @MichMich I am on the latest develop and it throws an error and just gives me a black screen:
          > magicmirror@2.1.1 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.1.1
          Loading config ...
          App threw an error during load
          TypeError: Path must be a string. Received undefined
              at assertPath (path.js:7:11)
              at Object.resolve (path.js:1148:7)
              at loadConfig (/home/pi/MagicMirror/js/app.js:53:29)
              at App.start (/home/pi/MagicMirror/js/app.js:180:3)
              at Object. (/home/pi/MagicMirror/js/electron.js:102:6)
              at Module._compile (module.js:556:32)
              at Object.Module._extensions..js (module.js:565:10)
              at Module.load (module.js:473:32)
              at tryModuleLoad (module.js:432:12)
              at Function.Module._load (module.js:424:3)
          Launching application.
          When I jump back to Master branch it loads fine:
          //your code> magicmirror@2.1.0 start /home/pi/MagicMirror
          > electron js/electron.js
          Starting MagicMirror: v2.1.0
          Loading config ...
          Loading module helpers ...
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-Traffic
          MMM-Traffic helper started ...
          Connecting socket for: MMM-WunderGround
          MMM-WunderGround helper started ...
          Connecting socket for: MMM-NFL
          Starting module: MMM-NFL
          Starting module: newsfeed
          ERROR! Could not find main module js
          • SnilleS
            Snille Module Developer
            Hi there, got the same problem… It’s time for bed anyway. :)
              roramirez Core Contributors
              So… that is my mistake. I pushed fix the wrong validation :(
              https://github.com/MichMich/MagicMirror/pull/658
              • MichMichM
                MichMich
                I’ve just merged the fix!👍
                • SnilleS
                  Working. :)
                  • X
                    XxX_Cobra_XxX
                    @MichMich I have the same problem as ESOB:
                    I am now also on the latest develop and it throws an error and just gives me a black screen:
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule-alt'
                        at Module._resolveFilename (module.js:455:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                        at Function.Module._load (module.js:403:25)
                        at Module.require (module.js:483:17)
                        at require (internal/module.js:20:19)
                        at Object. (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:20:13)
                    { Error: Cannot find module 'rrule-alt'
                        at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                    When I go back to Master branch it loads normally.
                    Please help me
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @XxX_Cobra_XxX
                      @XxX_Cobra_XxX did you install the dependencies? they have changed for the develop branch
                      X 1 Reply Last reply
                      • X
                        XxX_Cobra_XxX @strawberry 3.141
                        @strawberry-3.141 I have installed the dependencies now with ‘npm install’ and it works! ;-)
                        Thank you very much
                          Hey Guys,
                          To prevent problems like the error on validation on develop branch I say to you we are working a test suite for MagicMirror.
                          Now is initial state with some tests. Today @MichMich merged a change with some testing for e2e area. At now isn’t integrated the e2e tests in Travis. You can run e2e tests with
                          export DISPLAY=:0 && npm run test:e2e
                          You need run npm install before
                          The build a test is simple. If someone is animated and want to build one or need some light let me know.
                          So, also it helps if you run the e2e tests into your system and tells us if something is wrong or good.
                          morozgrafixM 1 Reply Last reply
                          • morozgrafixM
                            morozgrafix Moderator @roramirez
                            @roramirez I just submitted PR to add chai-as-promised to devDependencies. I was missing it from globally installed packages and ran into an error when tried to run tests.
                            • E
                              ESOB @morozgrafix
                              Something on the develop branch turned my magic mirror back to black screen again (It ran fine on develop branch yesterday but when I did my pull&&install today it went down again). Here is the information from the pm2 logs, tell me if you need anything else:
                              mm-0 (out): Module helper loaded: MMM-NFL
                              mm-0 (out): Initializing new module helper ...
                              mm-0 (out): Module helper loaded: newsfeed
                              mm-0 (out): All module helpers loaded.
                              mm-0 (out): Starting server op port 8080 ...
                              mm-0 (out): Server started ...
                              mm-0 (out): Connecting socket for: MMM-Remote-Control
                              mm-0 (out): Starting node helper for: MMM-Remote-Control
                              mm-0 (out): Connecting socket for: calendar
                              mm-0 (out): Starting node helper for: calendar
                              mm-0 (out): Connecting socket for: MMM-Traffic
                              mm-0 (out): MMM-Traffic helper started ...
                              mm-0 (out): Connecting socket for: MMM-WunderGround
                              mm-0 (out): MMM-WunderGround helper started ...
                              mm-0 (out): Connecting socket for: MMM-NFL
                              mm-0 (out): Starting module: MMM-NFL
                              mm-0 (out): Connecting socket for: newsfeed
                              mm-0 (out): Starting module: newsfeed
                              mm-0 (out): Sockets connected & modules started ...
                              mm-0 (out): Launching application.
                              mm-0 (err):     at exports._exceptionWithHostPort (util.js:1049:20)
                              mm-0 (err):     at Server._listen2 (net.js:1253:14)
                              mm-0 (err):     at listen (net.js:1289:10)
                              mm-0 (err):     at net.js:1399:9
                              mm-0 (err):     at _combinedTickCallback (internal/process/next_tick.js:77:11)
                              mm-0 (err):     at process._tickCallback (internal/process/next_tick.js:98:9)
                              mm-0 (err):     at Module.runMain (module.js:592:11)
                              mm-0 (err):     at run (bootstrap_node.js:402:7)
                              mm-0 (err):     at startup (bootstrap_node.js:157:9)
                              mm-0 (err):   code: 'EADDRINUSE',
                              mm-0 (err):   errno: 'EADDRINUSE',
                              mm-0 (err):   syscall: 'listen',
                              mm-0 (err):   address: '::',
                              mm-0 (err):   port: 8080 }
                              mm-0 (err): ERROR! Could not find main module js file.
                              • morozgrafixM
                                morozgrafix Moderator @ESOB
                                @ESOB looks like your port 8080 is in use. Do you happen to have another instance of MM running already? Or maybe something else is taking your port 8080.
                                • E
                                  ESOB @morozgrafix
                                  @morozgrafix maybe, I issued a pm2 stop and then did a restart and I am no longer getting that error. I am still getting a black only screen with the only error being:
                                  "ERROR! Could not find main module js file."
                                  What logs should I get you to figure out the reason for lack of display?
                                  Edit:
                                  Scratch that, I double checked the logs and I get the same error. I will do a full pi reboot again to triple check but it seems consistent.
                                  Edit 2:
                                  After triple check, only one MM instance open and same error noted about port 8080.
                                  morozgrafixM 2 Replies Last reply
                                  • morozgrafixM
                                    @ESOB did you run npm install after pulling development branch? Next step would be to try to start it in node serveronly mode and point your browser at http://:8080 or run npm start Dev and see if you get any errors in console log of the browser or electron app
                                    • morozgrafixM
                                      @ESOB sorry I was replying before you edited post with update. Try temporarily changing your config.js to another port if 8080 is taken for some reason.
                                      • E
                                        ESOB @morozgrafix
                                        @morozgrafix So I tried changing the port number to 8081 and I got this:
                                        mm-0 (err): WARNING! Could not load config file. Starting with default configuration. Error found: RangeError: "port" argument must be >= 0 and < 65536
                                        mm-0 (err): App threw an error during load
                                        mm-0 (err): RangeError: "port" argument must be >= 0 and < 65536
                                        mm-0 (err):     at assertPort (internal/net.js:17:11)
                                        mm-0 (err):     at Server.listen (net.js:1371:7)
                                        mm-0 (err):     at new Server (/home/pi/MagicMirror/js/server.js:20:9)
                                        mm-0 (err):     at /home/pi/MagicMirror/js/app.js:193:18
                                        mm-0 (err):     at loadNextModule (/home/pi/MagicMirror/js/app.js:142:5)
                                        mm-0 (err):     at /home/pi/MagicMirror/js/app.js:137:6
                                        mm-0 (err):     at Class.loaded (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
                                        mm-0 (err):     at loadModule (/home/pi/MagicMirror/js/app.js:118:6)
                                        mm-0 (err):     at loadNextModule (/home/pi/MagicMirror/js/app.js:135:5)
                                        I did run npm install, also tried serveronly and running npm start dev but did not gather any additional information. I will say the weird thing is when I leave it on port 8080, the remote control module still loads.
                                        • morozgrafixM
                                          @ESOB This error WARNING! Could not load config file. seems very odd. Can you please post your config.js file? Also another option is to backup your config.js and do file copy of config.js.sample to config.js to have good known configuration to begin with.
                                          When starting with npm start dev or node serveronly do you see any errors in the Console Log of the dev tools of the electron or your browser?
                                          P.S. I wanted to fork this troubleshooting conversation into a separate thread, but can’t seem to find a way.
                                          • morozgrafixM
                                            @roramirez & @MichMich looks like develop branch got broken with this commit https://github.com/MichMich/MagicMirror/commit/354b745c39a19915c3a8547445a5049555bd37ff#diff-75953debd6cf3faf33d4ff10e8353645R11
                                            Line 11 of defaults.js got this change port: process.env.MM_PORT || 8080, and server is not starting up throwing error in the console log:
                                            Uncaught ReferenceError: process is not defined
                                                at defaults.js:11
                                            (anonymous) @ defaults.js:11
                                            R 1 Reply Last reply
                                            • 2 / 3
