    [MMM-PIR-Sensor] Install failing
    75 Posts 19 Posters 110.9k Views 18 Watching
      Jopyth Moderator @Makradon
      @Makradon Sensor PIN 22 for the PIR-Sensor module is this one:
      Edit: Maybe I was confused by the diagram of the DHT22 module. It looked to me like the GPIO and WiringPi numbers are different.
      johnnyboyJ 1 Reply Last reply Reply Quote 1
        PindaPower
        In other post they posted this link, maybe it will help??
        https://diyhacking.com/raspberry-pi-gpio-control/
        foxF 1 Reply Last reply Reply Quote 1
        • foxF Offline
          fox @PindaPower
          @PindaPower said in [MMM-PIR-Sensor] Install failing:
          Thank you. With that i understood the delay and sensitivy knob.
          But! When i put sensivity at most right, the monitor goes on automatically ON after a while, even when there is NO movement in the radius… How can i debug this?
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            Mar
            I’ve tried following the instruction above of removing and reinstalling but I keep getting the below errors. I’m not even sure what they are unfortunately, wondering if anyone is able to help.
            pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install
            npm WARN engine electron-rebuild@1.5.7: wanted: {"node":">=6.0.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
            > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/node_modules/epoll/build'
            > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
            > electron-rebuild -e ../../node_modules/electron-prebuilt
            /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/node_modules/spawn-rx/lib/index.js:139
                let cmdArgs = ['/C', exe, ...args];
            SyntaxError: Unexpected token ...
                at exports.runInThisContext (vm.js:53:16)
                at Module._compile (module.js:414:25)
                at Object.Module._extensions..js (module.js:442:10)
                at Module.load (module.js:356:32)
                at Function.Module._load (module.js:311:12)
                at Module.require (module.js:366:17)
                at require (module.js:385:17)
                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                at Module._compile (module.js:435:26)
                at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
            npm ERR! Linux 4.4.38+
            npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
            npm ERR! node v4.2.1
            npm ERR! npm  v2.14.7
            npm ERR! code ELIFECYCLE
            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
            npm ERR! This is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
            npm ERR! not with npm itself.
            npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
            npm ERR! You can get their info via:
            npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
            npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
            edit: I have tried modifying the package.json file in the FAQ but the install exits within a minute, vs a really long time leaving the original. Seems like it gets farther through the install the first time. Though I’ve noticed i do have the electron folder and not an electron-prebuilt. The following is the error I get when i remove the -prebuilt.
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/rebuild.js:38:16)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:24:16)
            npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
            npm ERR!
            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron'.
            After doing the npm rebuild suggested above I get this error (with original/modified package.json)
            npm ERR!
              Jopyth Moderator @Mar
              @Mar said in [MMM-PIR-Sensor] Install failing:
              This is an old node version. Please update your node and npm. (If you need help check the answers to this SO question.)
              M 1 Reply Last reply Reply Quote 2
              • foxF Offline
                fox
                @Jopyth thank you very much for all your efforts for this community.
                Even its in your spare time it should be honored !
                  Mar @Jopyth
                  @Jopyth Hi, thanks for taking the time to respond to this. Sorry I was away for work and didnt have too much time to test this out.
                  So i managed to, using your link, to update node. But there was issues even getting there, I had to use an older version of node to update npm…but anyways here is the output showing I’ve updated to the latest version.
                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm -v
                  4.0.5
                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ node -v
                  v7.4.0
                  But now I’m getting this issue. Again thanks @Jopyth for responding so quickly last time.
                  npm WARN prefer global node-gyp@3.5.0 should be installed with -g
                  > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                  > node-gyp rebuild
                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                  An unhandled error occurred inside electron-rebuild
                  Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                  Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                      at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                      at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                      at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                      at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                      at Module._compile (module.js:571:32)
                      at Object.Module._extensions..js (module.js:580:10)
                      at Module.load (module.js:488:32)
                      at tryModuleLoad (module.js:447:12)
                      at Function.Module._load (module.js:439:3)
                      at Module.runMain (module.js:605:10)
                      at run (bootstrap_node.js:420:7)
                      at startup (bootstrap_node.js:139:9)
                  npm ERR! node v7.4.0
                  npm ERR! npm  v4.0.5
                  npm ERR! Exit status 255
                  npm ERR!
                  npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                  npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                  npm ERR! Or if that isn't available, you can get their info via:
                    @Mar Please change your package.json file as displayed here and execute npm install again. @paviro has not yet responded to my PR, but hopefully this will get merged in sooner or later.
                    M 3 Replies Last reply Reply Quote 1
                      Mar @Jopyth
                      @Jopyth It finally worked!!! :lifter_tone2: thanks so much. Ive spent days on this :(
                      Tried this last link you provided previously before posting but nothing was working, your support around getting node updated (and npm) was all that needed to happen first.
                      Thanks again!
                        Mar @Jopyth
                        @Jopyth Though looks like its failing on the config file now, Do you see any issues with the following?
                                                module: 'MMM-PIR-Sensor',
                                                        sensorPin: 17,
                        i seem to get an error and MM doesnt load when this is in the config file. I can even have disabled:true and it loads, otherwise I’ll get a blank webpage.
                          Mar @Jopyth
                          @Jopyth
                          using PM2 Im able to get the logs when starting, and even though it installed with your instructions i now get this error in the logs.
                          0|mm       | Error: The module '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                          0|mm       | was compiled against a different Node.js version using
                          0|mm       | NODE_MODULE_VERSION 50. This version of Node.js requires
                          0|mm       | NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
                          0|mm       | the module (for instance, using `npm rebuild` or`npm install`).
                          0|mm       |     at Object.Module._extensions..node (module.js:598:18)
                          0|mm       |     at Module.load (module.js:488:32)
                          0|mm       |     at tryModuleLoad (module.js:447:12)
                          0|mm       |     at Function.Module._load (module.js:439:3)
                          0|mm       |     at Module.require (module.js:498:17)
                          0|mm       |     at require (internal/module.js:20:19)
                          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                          0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:99)
                          0|mm       |     at Module._compile (module.js:571:32)
                          0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                          0|mm       | unclutter: someone created a sub-window to my sub-window! giving up
                            Mar @Mar
                            @Mar for anyone else who is getting this an npm rebuild fixes it. from here https://github.com/atom/apm/issues/635
                            • JayJ Offline
                              Jay
                              Hey, thanks for advising us how to install the modules, but I´m still struggling to find a solution for me even after updating nodejs and npm to the latest builts…
                              Similar error with corrected package.json.
                              I even tried the npm rebuild @Mar suggested. My last attempt to get this working was updating electron to its newest version but this didn´t help either.
                              Is there anything I could further try to install this module correctly?
                                Mar @Jay
                                @Jay I forgot what I did here to fix this issue. But to be honest after I got this working it still wasnt perfect. I ended going the route of a script on startup that controls the PIR sensor and its been perfect since and simple.
                                • foxF Offline
                                  fox
                                  did you install the fix? or is this now obsolet?
                                    Jopyth Moderator @fox
                                    @fox This PR should have fixed the issue (it is merged into the master).
                                    Are you running MagicMirror 2.1.0? And is your PIR-Module up-to-date? Try updating both (see this and do it in both directories) to the newest version.
                                    • foxF Offline
                                      fox @Jopyth
                                      @Jopyth said in [MMM-PIR-Sensor] Install failing:
                                      I deleted PIR Sensor completely. And made a new installation of this module and it installed without Problems. looks good from now
                                      • johnnyboyJ Offline
                                        johnnyboy
                                          STEFF92
                                          Hi, i tried to install the module MMM-PIR-Sensor. I did it like its explained here:
                                          https://github.com/paviro/MMM-PIR-Sensor
                                          After installing the module i opened the config.js file an added:
                                          				sensorPIN: 23,
        powerSaving: true,
        relayPIN: none,
        relayOnState: 1,
                                          The way i connected the sensor is shown in the following picture:
                                          alt text
                                          But when i want to start the magic mirror it says that i have to add a correct config.js file.
                                          What did i wrong? Please help me guys ;)
                                          JayJ johnnyboyJ 2 Replies Last reply Reply Quote 0
                                          • JayJ Offline
                                            Jay @STEFF92
                                            @STEFF92
                                            Did you change the name of the config File from “config.js.sample” to “config.js”?
                                            • 2 / 4
