    How HOT Does it Get?
    29 Posts 9 Posters 24.8k Views 8 Watching
      schlachtkreuzer6 @AAPS
      @AAPS is your case ventilated/some holes? do you using a heatsink for cpu and Ram? my pi2 climbs to max. 60°C so anyway your far far faaaaaar way to melt your PLA case ^^
        AAPS
        My case is ventilated, but I still might consider a tiny fan to make sure nothing happens anyway. I don’t use a heatsink. Either way, my raspberry pi shouldn’t ever get hot enough to melt the plastic, which melts at like 200°C in the 3d printer.
          AAPS
          I am also assuming that it is okay for me to always keep the pi on (the display will mostly stay off, though). Someone please correct me if I am wrong because the last thing I need is my raspberry pi not being powerful enough to always stay active.
            planet4
            I did some tests and here is my results. However my PI is located on the other side of the wall and not in the frame.
            PI Without heatsink and with
            alt text
            With vent holes
            alt text
            Without holes
            alt text
              AAPS
              It seems like I should be completely fine, and nothing should melt or get messed up. Is this right?
                AAPS
                I just realized that I do have a heatsink, but it’s one for an old computer. Do they run mechanically or electronically? It might be just what I need. It won’t be ideal, but I can figure something out.
                1 1 Reply Last reply Reply Quote 0
                • 1 Offline
                  1m2 @AAPS
                  @AAPS
                  Honestly I think this thing def. needs a fan even with a heatsink. It gets way too hot. I have not finished with OS set up and config quite yet though so it’s not my focus yet, case wise. I had to open the top part of the case even though it was well ventilated, I added a fan and sinse then it’s been running cool to the touch where that was not the case with an open case and heatsink. I will def. encorporate a fan once I get to that point in my build.
                    AAPS
                    Thanks! That’s the kind of response I was waiting to hear.
                      Mykle1 Project Sponsor Module Developer @1m2
                      @1m2 said in How HOT Does it Get?:
                      I was waiting to see what sort of response you would get about the fan. I’ve been wanting to add a fan although all searches say that the Pi can run without problems up to 80°C or more. That “seemed” hot to me. My Pi was running at 60°C, which is well under the maximum that I discovered. So, I took it upon myself to add a fan (I have spare parts lying around) and connected it to a 5V pin and a GRD pin on the GPIO header. I’ve been running the mirror all day without a hitch and my CPU temp is nearly 20°C cooler. Have a look.
                      slametpsS 1 Reply Last reply Reply Quote 0
                      • slametpsS Offline
                        slametps @Mykle1
                        @Mykle1 my Pi CPU temp was at up to 73°C. I think the heat caused by monitor heat emission although there are some vent holes. When I turn off the monitor for a while, when I turn the monitor on, the CPU temp was at 61°C.
                        I think, it is a good idea add some fans to reduce the heat.
                        regards,
                        Slamet PS
                          AAPS
                          @Mykle1 That’s great. My new problem now is figuring out how to make it wake up. How did you do it?
                          • 1 Offline
                            1m2
                            Not that anyone would need to see this but I thought I’d share just for reference ( it’s blowing air out ).
                            I just cut a hole and glued the four corners of the fan down ( can take it out any time I wish ).
                            1_1486697979646_IMG_20170209_203629.jpg 0_1486697979645_IMG_20170209_203647.jpg
                              AAPS @1m2
                              @1m2 That’s really smart! What kind of case is that?
                                Mykle1 Project Sponsor Module Developer @AAPS
                                @AAPS said in How HOT Does it Get?:
                                It’s no good connecting a mouse and/or keyboard to the mirror to wake it up. It takes the “magic” away, you know?
                                I had this problem as well. I decided to disable the screensaver. IMHO this is easiest done by installing xscreensaver (you don’t have to do any coding). Once installed, you go to the desktop of your GUI on the Pi, click on the raspberry icon, upper left, select preferences, select screensaver and disable the screensaver. Its one of the button choices. Now you can use the MMM-Remote-Control module to turn your monitor on and off, modules on and off, etc. It’s fabulous. Works from any computer on the same network and even works from your cell phone.
                                You can thank me later. ;-)
                                  AAPS
                                  I’ll thank you right now, and the remote control thing is pretty much what I have been doing, but I want motion detection because the ip adress of my pi changes constantly, so I run the risk of turning my display off and not knowing the site I need to go on to turn it back on. Either way I am about to buy a pir sensor for five bucks and play with it, so whatever I manage to do will have to work for me. ☺
                                    @AAPS
                                    My ip address changes too but I can find it easily by signing in to my router. You can set a static ip address for your Pi. I tried but got frustrated and gave it up. I’ll try again when my patience isn’t so low.
                                    I’ve also been toying with the idea of a PIR sensor or webcam but I’m still just trying to perfect my setup before diving into that. Good luck in your venture. I wish I could have been more help
                                      AAPS
                                      You just telling me this is helpful. I could maybe set a static IP address if I suddenly start feeling less lazy. :thinking:
                                      • O Offline
                                        ottobot @AAPS
                                        @AAPS just checked my pi zero after running for a few days straight. 51.4c that’s with no fan, no heatsink, and the frame around the mirror covering it.
                                        • O Offline
                                          ottobot @Mykle1
                                          @Mykle1 Fing is a great app to find your pi on your network as well. They make it for android and ios.
                                            I did some poking around and discovered an easier way to set a static IP for the Pi, although it’s not permanent. I have FIOS, and within the router interface you can set a “static lease” for any of the devices on your network. Easy as Pi. Took less than a minute
                                            A 2 Replies Last reply Reply Quote 0
