    Defining a module configuration schema standard
    9 Posts 4 Posters 5.7k Views 5 Watching
    • strawberry 3.141S Offline
      As in the last weeks some solutions (MMM-RemoteControl, MMM-Admin-Interface, MagicMirrorApp, MMM-Mobile, etc.), to easily configure the MagicMirror², came out, I would like to define a standard for 3rd party module developers.
      How should the configuration structure for modules look like so the developers have to put only effort once to include their modules in all solutions.
      I’m pinning some people, who I’m interested on their oppinions:
      @MichMich @Jopyth @ItayXD @aschulz90 @yawns @ianperrin @morozgrafix
      J 1 Reply Last reply Reply Quote 2
        roramirez Core Contributors
        I been working a little pice of work for that. You can check
        https://github.com/roramirez/MagicMirror-Module-Template
        strawberry 3.141S 1 Reply Last reply Reply Quote 2
          dz
          Yup…I’m looking the same… standard method/structure where we can just include our own modules/solution to it. Looking forward. Thanks
            strawberry 3.141 Project Sponsor Module Developer @roramirez
            @roramirez you’re off the path it’s about a configuration scheme like
            "maximumEntries": {
              "description": "The maximum number of events shown.",
              "values": {
                "Integer": {
                  "min": 0,
                  "max": 100
              "default": 10
              roramirez Core Contributors @strawberry 3.141
              @strawberry-3.141 Ok. For this case is need it uses a library to validate this case .
              On Python I’m using
              http://python-jsonschema.readthedocs.io/en/latest/
              http://validictory.readthedocs.io/en/latest/
              I think for this is need two thing.
              • First define a name in module for configuration schema, like this config.schema
              • After that is required by the core to check if the file exists inside the module and validate configuration, if ok loads the module. But this I think is @MichMich should tell what he think about this.
              The second part is possible do it inside the module too.
                @roramirez this is not for the core, this will be for the configuration solutions out there. so the user can decide which one he wants to use but the developers have to define their schema just once and it will work with all solutions
                  Jopyth Moderator @strawberry 3.141
                  @strawberry-3.141 Good idea to get this issue out here.
                  I think JSON Schema (as suggested by @roramirez) seems like a reasonable solution, and if I am right, it is compatible with the JSON Editor the MMM-Admin-Interface already uses.
                  As a file name I think it should end with .json, e.g. config.schema.json. This file should include the configuration options for the module.
                  After we find a good solution, we could add this to the MagicMirrorModule-Template?
                    strawberry 3.141 Project Sponsor Module Developer @Jopyth
                    @Jopyth how about handling global extensions like modulescheduler?
                      I just publish a first release functional of
                      If there suggest about include JSON Schema of something else, come on!, let me know
