    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 252.8k Views 33 Watching
      Speedy-one @pugsly
      @pugsly same here -.-
      slametpsS 1 Reply Last reply Reply Quote 0
      • slametpsS Offline
        slametps @Speedy-one
        @Speedy-one said in MMM-NetworkScanner:
        I freshly install rather than update the module, and working flawlessly.
        regards,
        Slamet PS
          pugsly @slametps
          @slametps Deleted the module and did a fresh install, still showing duplicate entries.
          • slametpsS Offline
            slametps @pugsly
            @pugsly said in MMM-NetworkScanner:
            Lucky me. Btw, had you installed v0.0.1?
            regards,
            Slamet PS
              pugsly @slametps
              @slametps Yes i did, and that one worked fine using MAC. I have actually reverted back to that one, so I don’t get the ‘last seen’ message anymore.
                bluedoors
                Any chance of an enhancement to scan outside the local network mask? i’m not sure if that is a config option in arp-scan that isn’t surfaced?
                I have my MM on ethernet in one subnet, but want to scan for MAC addresses in another subnet (my Wifi). or at least a broader CIDR range
                  bminer1
                  Does anyone have issues with the “occupied” and “vacant” part working? I tried to set it up and test it but i have had no luck. I want the mirror to turn off when i leave and turn back on when i return. I love this idea but need a little help configuring it to work.
                  My config is below:
                  	        module: 'MMM-NetworkScanner',
                  	        position: 'top_right',
                  		header: "Network Scanner",
                  	            devices: [
                  	                    { macAddress: "lower case", name: "B Phone", icon: "mobile"},
                  	                    { macAddress: "lower case", name: "B Work Phone", icon: "mobile"},
                  			    { macAddress: "lower case", name: "B Work Laptop", icon: "laptop"},
                  	            showUnknown: false,
                  	            showOffline: true,
                  	            keepAlive: 300,
                  	            updateInterval: 10,
                  		    showLastSeen: true,
                  	            residents: "B Phone",
                  	            occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                  	            vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
                  B I 2 Replies Last reply Reply Quote 0
                    bminer1
                    I am also getting duplicates as well. Any help on this?
                    alt text
                      derek7467 @bluedoors
                      @bluedoors modify the js file to scan your subnets? If your subnets were 192.168.1.0/24 and 192.168.2.0/24 you could scan 192.168.1.0/23 to scan both subnets, right? Same gateway for both subnets?
                        binderth @bminer1
                        @bminer1 said in MMM-NetworkScanner:
                        Ah, nice: Is this doing, what I suspect it’s doing? ;)
                        occupiedCMD: Notification to be sent when a resident returnes home e.g. {notification: ‘REMOTE_ACTION’, payload: {action: ‘MONITORON’}} would turn the mirror on when a resedent returnes home.
                        What does “returnes home” mean: Changing from “offline” to “online”: trigger the action (vice versa for vacantCMD). It does only trigger once? Would it be possible to call an external URL with this? - and then: does it trigger if any resident leaves or can I specify which resident leaves?
                          bminer1 @binderth
                          @binderth I tried testing it by turning my WiFi off on my phone, waiting a few minutes to see if it turns off and it doesn’t turn off. I even physically left the house for dinner and came home to it still on. I love the feature and would do almost anything to get it to work. I’m new to all this stuff so i don’t have the skill to debug on my own.
                            binderth @bminer1
                            @bminer1 yes, this is nice! would be killer, if it were to be configured per device! ;) it seems from the way in the config, it was intended to fire regardless of which device leaves or comes up again…
                              bminer1 @binderth
                              @binderth When i read through the Read ME, it says that the Residence determines when to turn on and off. I want this to work for me so then i can put my wifes phone in there as a resident and that way, when both of us leave, it shuts off. when one of us is home, it stays on.
                                binderth @bminer1
                                @bminer1 ah. ok, I get it (didn’t have “residents” in my config either). So, this one is realy “every resident is offline”: i do something. “At least one resident is online again”: i do something. So this would then be a generic presence detection.
                                Would be cool, if it could also be bound to specific residents. So I can have Actions regarding on them also.
                                  bminer1 @binderth
                                  @binderth I think you are on a right track. We just need to debug the “simple” task of turning on and off and then the fun can begin with other stuff.
                                  • I Offline
                                    ianperrin @bminer1
                                    @bminer1, @pugsly, @Speedy-one
                                    I’m still working through the issues introduced last weeekend, but have just added a commitwhich attempts to resolve the duplicate devices issue. I’d be grateful if you could try it out and confirm.
                                    “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                                    • I Offline
                                      ianperrin @derek7467
                                      @derek7467
                                      If you can provide the arp-scan command for this, an option could be added to support it - once the current issues are fixed of course ;)
                                      Cc @bluedoors
                                      • I Offline
                                        ianperrin @bminer1
                                        @bminer1, @binderth
                                        I’m going to be taking a look at the notifications functionally after the issues with the current release have been resolved.
                                          Blackmirror
                                          Nice to make a output gpio in this module, so I can installed a relais, to switch thinks on, only when I am in the house.
                                          • zdenekZ Offline
                                            zdenek
                                            I’ve also issue - “resident” doesn’t work for me:
                                            and here ic config:
                                                    	position: 'bottom_right',
                                                        		devices: [
        { macAddress: "ab:ab:ab:ab:ab:ab", name: "Mobile", icon: "server"},
                                                        		showUnknown: false,
                                            			debug: false,
                                                        		showOffline: true,
                                                        		keepAlive: 60,
                                                        		updateInterval: 30,
                                                        		residents: "Mobile",
                                            			showLastSeen: true,
                                            any idea? module get started, Icon and name appers, but it’s still “grey” (like offline - wifi is on, I can see Raspberry and also Server on the same network via Fing)
                                            Tried also with IP - the same. Tried another device, the same. And arp-scan --localnet I can see the devices I want to monitor
                                            thanks for help
                                            Zdeněk
                                            • 3 / 6
