    MMM-NetworkScanner
    networkscannerstatusmac address
    117 Posts 32 Posters 258.7k Views 33 Watching
    • slametpsS
      slametps @Mykle1
      @Mykle1
      @Mykle1 said in MMM-NetworkScanner:
      @slametps Yes, at first the same thing happened to me.
      This might seem obvious but did you change your config.js to ipAddress instead of macAddress?
      I add new entries with ipAddress, but did not recognized. All displayed MAC (with showUnknown: true) already defined as entries with macAddress, but it said as Unknown devices.
      regards,
      Slamet PS
      • I
        ianperrin
        Hi all
        The updates last week seem to have introduced a few issues - sorry folks!
        I’ve quashed one bug with MAC Address scans which you can git pull from the repo to see if that helps, but there still appear to be a few others which need resolving.
        I am looking at it but please bear with me ;)
        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        Mykle1M pugslyP 2 Replies Last reply
        Reply Quote 2
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @ianperrin
          @ianperrin said in MMM-NetworkScanner:
          Shhhhh! Quiet! Genius at work!
          I am completely serious. I think you are a brilliant young man.
          Much success to you. :thumbsup_tone1:
          • pugslyP
            pugsly @ianperrin
            @ianperrin
            Yup good work on getting the updates…
            MAC is working again, but the entries are all duplicated. ;)
              Speedy-one @pugsly
              @pugsly same here -.-
              slametpsS 1 Reply Last reply
              • slametpsS
                slametps @Speedy-one
                @Speedy-one said in MMM-NetworkScanner:
                I freshly install rather than update the module, and working flawlessly.
                regards,
                Slamet PS
                pugslyP 1 Reply Last reply
                • pugslyP
                  pugsly @slametps
                  @slametps Deleted the module and did a fresh install, still showing duplicate entries.
                  • slametpsS
                    slametps @pugsly
                    @pugsly said in MMM-NetworkScanner:
                    Lucky me. Btw, had you installed v0.0.1?
                    regards,
                    Slamet PS
                    • pugslyP
                      pugsly @slametps
                      @slametps Yes i did, and that one worked fine using MAC. I have actually reverted back to that one, so I don’t get the ‘last seen’ message anymore.
                      • bluedoorsB
                        bluedoors
                        Any chance of an enhancement to scan outside the local network mask? i’m not sure if that is a config option in arp-scan that isn’t surfaced?
                        I have my MM on ethernet in one subnet, but want to scan for MAC addresses in another subnet (my Wifi). or at least a broader CIDR range
                        D 1 Reply Last reply
                          bminer1
                          Does anyone have issues with the “occupied” and “vacant” part working? I tried to set it up and test it but i have had no luck. I want the mirror to turn off when i leave and turn back on when i return. I love this idea but need a little help configuring it to work.
                          My config is below:
                          	        module: 'MMM-NetworkScanner',
                          	        position: 'top_right',
                          		header: "Network Scanner",
                          	            devices: [
                          	                    { macAddress: "lower case", name: "B Phone", icon: "mobile"},
                          	                    { macAddress: "lower case", name: "B Work Phone", icon: "mobile"},
                          			    { macAddress: "lower case", name: "B Work Laptop", icon: "laptop"},
                          	            showUnknown: false,
                          	            showOffline: true,
                          	            keepAlive: 300,
                          	            updateInterval: 10,
                          		    showLastSeen: true,
                          	            residents: "B Phone",
                          	            occupiedCMD: {notification: 'REMOTE_ACTION', payload: {action: 'MONITORON'}},
                          	            vacantCMD  : {notification: 'REMOTE_ACTION', payload: {action: 'MONITOROFF'}},
                          binderthB I 2 Replies Last reply
                            bminer1
                            I am also getting duplicates as well. Any help on this?
                            alt text
                            I 1 Reply Last reply
                              derek7467 @bluedoors
                              @bluedoors modify the js file to scan your subnets? If your subnets were 192.168.1.0/24 and 192.168.2.0/24 you could scan 192.168.1.0/23 to scan both subnets, right? Same gateway for both subnets?
                              • binderthB
                                binderth @bminer1
                                @bminer1 said in MMM-NetworkScanner:
                                Ah, nice: Is this doing, what I suspect it’s doing? ;)
                                occupiedCMD: Notification to be sent when a resident returnes home e.g. {notification: ‘REMOTE_ACTION’, payload: {action: ‘MONITORON’}} would turn the mirror on when a resedent returnes home.
                                What does “returnes home” mean: Changing from “offline” to “online”: trigger the action (vice versa for vacantCMD). It does only trigger once? Would it be possible to call an external URL with this? - and then: does it trigger if any resident leaves or can I specify which resident leaves?
                                B 1 Reply Last reply
                                  bminer1 @binderth
                                  @binderth I tried testing it by turning my WiFi off on my phone, waiting a few minutes to see if it turns off and it doesn’t turn off. I even physically left the house for dinner and came home to it still on. I love the feature and would do almost anything to get it to work. I’m new to all this stuff so i don’t have the skill to debug on my own.
                                  binderthB 1 Reply Last reply
                                  • binderthB
                                    binderth @bminer1
                                    @bminer1 yes, this is nice! would be killer, if it were to be configured per device! ;) it seems from the way in the config, it was intended to fire regardless of which device leaves or comes up again…
                                      bminer1 @binderth
                                      @binderth When i read through the Read ME, it says that the Residence determines when to turn on and off. I want this to work for me so then i can put my wifes phone in there as a resident and that way, when both of us leave, it shuts off. when one of us is home, it stays on.
                                      • binderthB
                                        binderth @bminer1
                                        @bminer1 ah. ok, I get it (didn’t have “residents” in my config either). So, this one is realy “every resident is offline”: i do something. “At least one resident is online again”: i do something. So this would then be a generic presence detection.
                                        Would be cool, if it could also be bound to specific residents. So I can have Actions regarding on them also.
                                          bminer1 @binderth
                                          @binderth I think you are on a right track. We just need to debug the “simple” task of turning on and off and then the fun can begin with other stuff.
                                          • I
                                            ianperrin @bminer1
                                            @bminer1, @pugsly, @Speedy-one
                                            I’m still working through the issues introduced last weeekend, but have just added a commitwhich attempts to resolve the duplicate devices issue. I’d be grateful if you could try it out and confirm.
                                            • 3 / 6
