    Complete set up Tutorial (Typos?)
    8 Posts 5 Posters 4.1k Views 4 Watching
    • johnnyboyJ
      johnnyboy
        broberg Project Sponsor
        Just to be clear you are refering to this tutorial? : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @broberg
          @broberg hes refering to this one https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
          johnnyboyJ 1 Reply Last reply
          • johnnyboyJ
            johnnyboy @strawberry 3.141
            Q 1 Reply Last reply
            • Q
              qqqqqqqq @johnnyboy
              @johnnyboy
              You should check the tutorial on the pimag . Dead simple, just one line command and it’s done.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
                @qqqqqqqq this command is only about the MagicMirror itself, which is included in the tutorial as well, but the tutorial also include setting up the raspberry pi. When I first read this thread i thought the qutes were there to mark code, but it’s already highlighted with markdown syntax, so it’s probably better to remove them. @Global-Moderators
                johnnyboyJ J 2 Replies Last reply
                • johnnyboyJ
                    Jopyth Moderator @strawberry 3.141
                    @strawberry-3.141 Thanks for tagging. I updated the commands to not include additional single quotes.
