Complete set up Tutorial (Typos?)
This post is deleted! -
Just to be clear you are refering to this tutorial? : https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
@broberg hes refering to this one https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
You should check the tutorial on the pimag . Dead simple, just one line command and it’s done.
@qqqqqqqq this command is only about the MagicMirror itself, which is included in the tutorial as well, but the tutorial also include setting up the raspberry pi. When I first read this thread i thought the qutes were there to mark code, but it’s already highlighted with markdown syntax, so it’s probably better to remove them. @Global-Moderators
@strawberry-3.141 Thanks for tagging. I updated the commands to not include additional single quotes.
