Trouble with MagicMirror
19 Posts 3 Posters 7.9k Views 3 Watching
  • X Offline
    xVirus94
    Hi, I-m Matt, i have recently installed MagicMirror on my Rasp. Pi3, everythings is ok but i have a problem with modules: only 2/3 default modules work…i have tried to install some new add-ons but nothing to do…the add-ons doesn t works so i need help… someone can help me?
    Thx, Regards
    Matt.
    P.S. Sorry for my bad english
    C 1 Reply Last reply Feb 24, 2017, 8:29 PM Reply Quote 0
      cowboysdude Module Developer @xVirus94
      @xVirus94 What “addons” are you trying to get to work?
      Don’t need to apologize for bad English… heck 1/2 the people that speak English aren’t even good at it LOL
      Did you do this in terminal window?
      ~MagicMirror/config
      then…
      cp config.js.sample config.js
      • X Offline
        xVirus94
        Hi, thx for reply…i’m trying to install some interesting modules, like Forecast…ecc. because the default Forecast module doesn’t work…i have installed the new module but when i lunch my mirror i cant see the module on top-right…
        M C 2 Replies Last reply Feb 24, 2017, 9:03 PM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @xVirus94
          @xVirus94 said in Trouble with MagicMirror:
          post your config.js file so we can have a look at it
          X 2 Replies Last reply Feb 24, 2017, 9:09 PM Reply Quote 1
          • X Offline
            xVirus94 @Mykle1
            @Mykle1 Hi! Thx for reply, now i’m at work so i cant post my config but tomorrow i will post it!
            M 1 Reply Last reply Feb 24, 2017, 9:11 PM Reply Quote 0
              ok, we’ll get you up and running.
                You also need a key to make them work :)
                X 1 Reply Last reply Feb 24, 2017, 9:40 PM Reply Quote 0
                • X Offline
                  xVirus94 @cowboysdude
                  @cowboysdude What key???
                  M 1 Reply Last reply Feb 24, 2017, 10:05 PM Reply Quote 0
                    What key???
                    The API key that you have to sign up for. It’s free. It should tell you where to go in the ReadMe.
                    If you are using the default weather module then you have to go to https://www.openweathermap.org/
                    Each weather module that requires an API key tells you in the ReadMe file where to go to get the key
                    X 1 Reply Last reply Feb 25, 2017, 2:57 PM Reply Quote 0
                    • X Offline
                      xVirus94 @Mykle1
                      X 1 Reply Last reply Feb 25, 2017, 2:52 PM Reply Quote 0
