    Trouble with MagicMirror
    19 Posts 3 Posters 9.9k Views 3 Watching
    • X Offline
      xVirus94
      Hi, thx for reply…i’m trying to install some interesting modules, like Forecast…ecc. because the default Forecast module doesn’t work…i have installed the new module but when i lunch my mirror i cant see the module on top-right…
      Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @xVirus94
        @xVirus94 said in Trouble with MagicMirror:
        post your config.js file so we can have a look at it
        X 2 Replies Last reply Reply Quote 1
        • X Offline
          xVirus94 @Mykle1
          @Mykle1 Hi! Thx for reply, now i’m at work so i cant post my config but tomorrow i will post it!
            ok, we’ll get you up and running.
            • cowboysdudeC Offline
              cowboysdude Module Developer @xVirus94
              You also need a key to make them work :)
              X 1 Reply Last reply Reply Quote 0
              • X Offline
                xVirus94 @cowboysdude
                @cowboysdude What key???
                  What key???
                  The API key that you have to sign up for. It’s free. It should tell you where to go in the ReadMe.
                  If you are using the default weather module then you have to go to https://www.openweathermap.org/
                  Each weather module that requires an API key tells you in the ReadMe file where to go to get the key
                  • X Offline
                    xVirus94 @Mykle1
                    • X Offline
                      xVirus94 @xVirus94
                      • X Offline
                        xVirus94 @Mykle1
                        @Mykle1 module: ‘currentweather’,
                        position: ‘top_left’,
                        locationID: ‘3176746’, //ID from http://www.openweathermap.org
                        appid: ’37f’
                        Why doesn-t work?
                          @Mykle1 {
                          appid: ‘xxxxxxxxxxxxxxxxxxxxxxxxx’
                          Why doesn-t work?
                          Let’s take a look here…
                          Remember do not post your api key for any app ;)
                          At any rate this returns :
                          “invalid API key”… so you don’t have a correct API key, where did you get it from?
                          Plus you had Syntax errors… this is the correct way other than API Key…
                                       module: 'currentweather',
                                       position: 'top_left',
                                          locationID: '3176746', //ID from http://www.openweathermap.org
                                          appid: 'ca7b4eb9089beeb6a71918a37f20b9'
                            @cowboysdude said in Trouble with MagicMirror:
                            Oops! :left_facing_fist_tone2:
                            • X Offline
                              xVirus94 @Mykle1
                              @Mykle1 this isn’t a real Api key…
                                @xVirus94 There you go copy the format I pasted above use your real api key and it should be working :)
                                X 1 Reply Last reply Reply Quote 1
                                • X Offline
                                  @cowboysdude It’s working!!! Thanks a lot! Owesome!
                                    @xVirus94 AWESOME… it’s awesome when something is working :)
                                    • X Offline
                                      @cowboysdude That’ s right! :D
