    Trouble with MagicMirror
    19 Posts 3 Posters 10.8k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @xVirus94
      @xVirus94 said in Trouble with MagicMirror:
      What key???
      The API key that you have to sign up for. It’s free. It should tell you where to go in the ReadMe.
      If you are using the default weather module then you have to go to https://www.openweathermap.org/
      Each weather module that requires an API key tells you in the ReadMe file where to go to get the key
      X 1 Reply Last reply Reply Quote 0
      • X Offline
        xVirus94 @Mykle1
        • X Offline
          xVirus94 @xVirus94
          • X Offline
            xVirus94 @Mykle1
            @Mykle1 module: ‘currentweather’,
            position: ‘top_left’,
            locationID: ‘3176746’, //ID from http://www.openweathermap.org
            appid: ’37f’
            Why doesn-t work?
            • cowboysdudeC Offline
              cowboysdude Module Developer @xVirus94
              @Mykle1 {
              appid: ‘xxxxxxxxxxxxxxxxxxxxxxxxx’
              Why doesn-t work?
              Let’s take a look here…
              Remember do not post your api key for any app ;)
              At any rate this returns :
              “invalid API key”… so you don’t have a correct API key, where did you get it from?
              Plus you had Syntax errors… this is the correct way other than API Key…
                           module: 'currentweather',
                           position: 'top_left',
                              locationID: '3176746', //ID from http://www.openweathermap.org
                              appid: 'ca7b4eb9089beeb6a71918a37f20b9'
                @cowboysdude said in Trouble with MagicMirror:
                Oops! :left_facing_fist_tone2:
                • X Offline
                  xVirus94 @Mykle1
                  @Mykle1 this isn’t a real Api key…
                    @xVirus94 There you go copy the format I pasted above use your real api key and it should be working :)
                    X 1 Reply Last reply Reply Quote 1
                    • X Offline
                      xVirus94 @cowboysdude
                      @cowboysdude It’s working!!! Thanks a lot! Owesome!
                        @xVirus94 AWESOME… it’s awesome when something is working :)
                        • X Offline
                          @cowboysdude That’ s right! :D
