    Where to buy good two way mirrors ?
    86 Posts 33 Posters 209.8k Views 31 Watching
      Mitchfarino Module Developer @Bangee
      @Bangee I’m not quite sure what the your images are showing
        RedNax Module Developer
        Any of you guys that were waiting for your mirror have any experience to share yet?
          RedNax Module Developer @djsunrise19
          @djsunrise19 IS it really 8mm thick as the site says? Must be quite heavy. I’ve also seen mirrors which consist of 2 panes with reflective foil sandwiched in between… What type is the https://www.myspiegel.de/spionspiegel-pg-2102.html one?
          Any pictures to share yet?
          S P 2 Replies Last reply Reply Quote 0
          • N Offline
            Niarfee
            Which mirror you think is best, 1%, 3%, 12%, 20% or Mirror “mirona”?
            https://forum.magicmirror.builders/topic/171/mirona-mirror-for-the-magic-mirror
              Shampooman @RedNax
              @RedNax It’s the type you descriped. I allready bought one of these. And ist really heavy…
                sunnysys
                Hey Guys!
                Do you know a place that I can find proper glass two way mirror with shipping to Hungary?
                In Hungary there is no mirror with high reflection, in UK and Germany I only found stores with local distribution.
                Thanks!
                  Mark @Try2Fly
                  @Try2Fly said in Where to buy good two way mirrors ?:
                  robably have it ready by the 20th of ma
                  Did you have your mirror already? and wich one did you order? the normal mirror?
                    prototype0815 @RedNax
                    @RedNax Hey, I bought a mirror from them. The quality is great, but although the mirror is a little bit heavy. It costs 75€ for a 650x430mm mirror, thats really cheap because I found only shops which offered that mirror for 120-150€.
                    How much it weighs exactly, I don’t know because it’s already built-in.
                    • T Offline
                      Try2Fly @jordi2830
                      @jordi2830 @Mark Finaly received my mirror last friday. Took a long time. Mirror looked good before inserting it in the frame. It is now hanging next to my front door, but it is to dark in the hall, so there is not a real mirror effect, and can look through the mirror… I ordered the 2 way mirror, or confrontation mirror. I am tinking about taping the sides where there is no screen, to see if that improves the effect.
                      M D 2 Replies Last reply Reply Quote 0
                      • K Offline
                        KirAsh4 Moderator
                        If the room itself is dark, there is nothing to reflect off of the screen, you will (only) see the monitor behind it.
                          Mark @Try2Fly
                          @Try2Fly I work a 10 minute drive away from DokterPlexiglas so I have no troubles with the delivery. I hope that they finish mine a lot faster then they did yours.
                          My mirror is bigger then the monitor but I made a woodenframe (spraypaint it black) to cover the mirror where there is no monitor. This works great even with the folie I tested it on (I only used the folie to test it, so please dont ban my guys)
                          T 2 Replies Last reply Reply Quote 0
                          • T Offline
                            Try2Fly @Mark
                            @Mark me too ;) I picked it up there since I also live nearby. I guess they have a big sheet of it now, so hopefully yours won’t take that long.
                            • T Offline
                              Try2Fly @Mark
                              @Mark I do think that a real glass mirror is better than the plexiglas. But that costs more, and for me this is now only a test and see where the project goes. If I am satisfied with the way MM is working and still find it usefull/fun, I might consider buying a glass mirror and building a nicer frame…
                                Mark @Try2Fly
                                @Try2Fly I tested with the adhesive film, and I am going to try the plexiglas 50x70 cm.
                                Let me know, if you have a cheap adres for the glass version.
                                  rockja @michelleoj
                                  @michelleoj Just went onto their site and the price quote for a 24" x 36" acrylic is $270. Am I missing something or have they jacked up their prices from when you bought yours?
                                    andy952 @Mitchfarino
                                    @Mitchfarino Cutplasticsheeting is the company I used for my acrylic mirror.
                                    It does the job, at a fraction of the cost! Yes it may scratch over time, but for £30 for a 22" I can’t really complain at that!
                                      Mitchfarino Module Developer @andy952
                                      @andy952 awesome!
                                      I’m going to go with them then, just wanted to make sure the two way worked well enough.
                                      Thanks for your feedback!
                                        patm189
                                        Hi @andy952 , I’m looking at Cutplasticsheeting now. Do you mind sharing what type of Material and Thickness you used? It seems there are many different kinds. I’m not too handy with acrylic lingo and want to make sure I order the proper sheet. Thanks in advance!
                                          Petal0u
                                          Hi, i’m looking for a two Way mirror and i’ve not found any shop Which could ship in France.
                                          Does anybody Know where i could order ?
                                            Alex @Petal0u
                                            @Petal0u
                                            I am also living in France and, for now, I did not find one. I asked to local shop but price was not very cheap. If you find one, I would be glad to hear about ! :)
                                            Alex
                                            • 2 / 5
