    Where to buy good two way mirrors ?
    86 Posts 33 Posters 210.0k Views 31 Watching
      Bangee Module Developer
      https://www.glastroesch.ch/glas/82-spionspiegel.html
      This is an adress for Switzerland, where I’ll buy my mirror.
        djsunrise19
        I got my two mirrors (24" and 27") here (germany): https://www.myspiegel.de/spionspiegel-pg-2102.html
        Good quality! I’ll post some pictures soon.
        At first I wanted to give foils a try, but the result was terrible.
        MichMichM R 2 Replies Last reply Reply Quote 0
        • MichMichM Offline
          MichMich @djsunrise19
          @djsunrise19 said in Where to buy good two way mirrors ?:
          If only people would understand this and not try to save a few bucks on a +$200,- project … ;)
          N 1 Reply Last reply Reply Quote 1
            Alex
            Thanks to all for your answers and contributions.
            Is there any recommandation about the best reflection and transmission ratio to use for such magic mirror ?
            Sometimes, I had seen mirrors for which you can select different thickness. What are yours and what are the impact observed please ? Have you any recommandations about thickness of mirror ?
            Thanks to all makers :)
            • N Offline
              nhubbard @MichMich
              @MichMich I’m assuming you mean the ± symbol. That’s fine, I just like correcting people. :smile:
              Just because something doesn’t do what you planned it to do doesn’t mean it’s useless.
              – Thomas Edison
              • T Offline
                Try2Fly
                I just ordered a 20" acrylic mirror at dokterplexiglas.nl for only 13 euro. Do not know the quality yet.
                  jordi2830 @Try2Fly
                  @Try2Fly said in Where to buy good two way mirrors ?:
                  Let us know how it works out, I’m currently looking for a not too expensive acrylic mirror as well. :p
                    Mitchfarino Module Developer
                    Has anyone tried this place? https://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror
                    Pretty decent price for the size I need (~£30)
                    • F Offline
                      feuerball
                      @Try2Fly did the mirror arrive?
                      • T Offline
                        Try2Fly @feuerball
                        @feuerball No not yet. They did not have it in stock. They’ll probably have it ready by the 20th of may
                          I use a 12 % Mirror
                          Here you can see my three samples I’ve orderd.
                            Mitchfarino Module Developer @Bangee
                            @Bangee I’m not quite sure what the your images are showing
                              RedNax Module Developer
                              Any of you guys that were waiting for your mirror have any experience to share yet?
                                RedNax Module Developer @djsunrise19
                                @djsunrise19 IS it really 8mm thick as the site says? Must be quite heavy. I’ve also seen mirrors which consist of 2 panes with reflective foil sandwiched in between… What type is the https://www.myspiegel.de/spionspiegel-pg-2102.html one?
                                Any pictures to share yet?
                                S P 2 Replies Last reply Reply Quote 0
                                • N Offline
                                  Niarfee
                                  Which mirror you think is best, 1%, 3%, 12%, 20% or Mirror “mirona”?
                                  https://forum.magicmirror.builders/topic/171/mirona-mirror-for-the-magic-mirror
                                    Shampooman @RedNax
                                    @RedNax It’s the type you descriped. I allready bought one of these. And ist really heavy…
                                      sunnysys
                                      Hey Guys!
                                      Do you know a place that I can find proper glass two way mirror with shipping to Hungary?
                                      In Hungary there is no mirror with high reflection, in UK and Germany I only found stores with local distribution.
                                      Thanks!
                                        Mark @Try2Fly
                                        Did you have your mirror already? and wich one did you order? the normal mirror?
                                          prototype0815 @RedNax
                                          @RedNax Hey, I bought a mirror from them. The quality is great, but although the mirror is a little bit heavy. It costs 75€ for a 650x430mm mirror, thats really cheap because I found only shops which offered that mirror for 120-150€.
                                          How much it weighs exactly, I don’t know because it’s already built-in.
                                          • T Offline
                                            Try2Fly @jordi2830
                                            @jordi2830 @Mark Finaly received my mirror last friday. Took a long time. Mirror looked good before inserting it in the frame. It is now hanging next to my front door, but it is to dark in the hall, so there is not a real mirror effect, and can look through the mirror… I ordered the 2 way mirror, or confrontation mirror. I am tinking about taping the sides where there is no screen, to see if that improves the effect.
                                            M D 2 Replies Last reply Reply Quote 0
                                            • 2 / 5
