    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      Mykle1 Project Sponsor Module Developer @strawberry 3.141
      @strawberry-3.141 said in MMM-voice:
      i’m just using a usb microphone, never tried a buil in mic of a webcam because i don’t have one.
      I actually got it working on a laptop with Ubuntu so I am now trying it on the Pi 3 with MMM-voice and a Logitech USB microphone. It loads with “Initializing” next to the microphone and for a second it shows “Ready, choose a mode.” but then it changes to Error. I tried to make it the default in Audio Device Settings on the Pi3 but it keeps going back to "bcm2835 (ALSA mixer) (Default). It won’t keep the “AK5370 (Alsa mixer)” as default.
       0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                            bcm2835 ALSA
       1 [AK5370         ]: USB-Audio - AK5370
                            AKM AK5370 at usb-3f980000.usb-1.2, full speed
      I’m going to bed!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Mykle1
        @Mykle1 just set the config to microphone: 1
          I guess I should have mentioned that I already have that setting. I was tired. Does this mean that microphone is not compatible?
            @Mykle1 if you want i can have a look via remote desktop session
              That would be great but I have to run to work for a few hours. I’ll be back in about 4 hours. So, perhaps later if you are available. I’d appreciate that.
                Mykle1 Project Sponsor Module Developer @Mykle1
                I’m here for a while if you should come around
                  @strawberry-3.141
                  I tested my microphone on the Pi by doing this:
                  pi@Pi3:~ $ arecord -D plughw:1,0 test.wav
                  Recording WAVE 'test.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
                  ^CAborted by signal Interrupt...
                  pi@Pi3:~ $
                  That gave me this: 0_1489005574631_soundfile.JPG
                  Which sounds ok. Clear, and not too much white noise.
                  As long as my Audio Device Settings looks like this:0_1489005776320_audiodevicesettings.JPG
                  I am not in debug mode
                       			module: 'MMM-voice',
                       			position: 'top_right',
                           		microphone: 1,
                  			keyword: 'MAGIC MIRROR', // UPPERCASE ONLY
                  			timeout: 15
                  However, I am getting this: 0_1489006683272_fairest.JPG
                  At least we got it working
                  strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
                    @Mykle1 the second line is in debug mode only
                      So, can I remove that from showing?
                        @Mykle1 it shouldn’t be there when you not added debug flag in the config
                        Mykle1M 3 Replies Last reply Reply Quote 0
                          @strawberry-3.141
                          I’ll try debug: false and see what happens
                            @strawberry-3.141
                            You’re right again. I had config.js opened twice. One with debug and one without. I removed debug and saved and closed both. Now it’s fine. One last thing, if you don’t mind, I’d like to align everything in MMM-voice to the right margin. Please and thank you. :thumbsup_tone1:
                              @strawberry-3.141 Oh, and I can change the 'MAGIC MIRROR" activation phrase to something else?
                                @Mykle1 yes you can change it, that’s why it is configurable. try to apply the rule text-align: right; in custom.css
                                Mykle1M 3 Replies Last reply Reply Quote 1
                                  I will endeavor to try, thanks for your help
                                    I tried:
                                    .MMM-voice {
                                      text-align: right;
                                    and
                                    .region.top.right .MMM-voice {
                                      text-align: right;
                                    Nothing happened
                                    At least the module seems stable and it’s working. :thumbsup_tone1:
                                      I don’t mind trying to get it to work but can you give me another hint? Am I close? haha!
                                        @Mykle1 you have to either override the class align-left which is getting confuse or set an important flag
                                        .MMM-voice .align-left {
                                          text-align: right;
                                        .MMM-voice {
                                          text-align: right !important;
                                          Ohhh, I was so close! Thank you again :thumbsup_tone1:
                                            c.keen
                                            Hi guys,
                                            I would like to control my mirror by using MMM-voice. The installation was quite easy. But now, the icon on the mirror gives an “ERROR” after the microphone has been initialised. I have read the whole thread and tried a few options but none of them worked. Reading the error.log it gives only “127”. Reading the debug.log it says: “pocketsphinx_continuous:: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such directory”.
                                            At first I thought that not all dependencies have been installed correctly althought the installer did not give any warnings or errors. So I thought the I have to install pocketsphinx_continuous and lmtool myself but found them in the node_modules folder.
                                            Can you please help me?
                                            • 16
                                            • 17
                                            • 5 / 17
