    Calendar Module: Multiple Icons.
    21 Posts 6 Posters 15.6k Views 6 Watching
      Richard238
      What’s the code to have multiple icons on the calendar?
      I’ve tried a few…
      symbol: 'calendar-check-o ', 'smile-o ',
      symbol: 'calendar-check-o ’ 'smile-o ',
      symbol: 'calendar-check-o smile-o ',
      • Y Offline
        yawns Moderator
        Multiple Icons? So you want to display two (or even more) icons next to each calendar entry?
          Richard238
          Yes, exactly that.
          I’m building a ‘Binday’ calendar.
          I’d like two icons, to indicate which bins to put out: rubbish and recycling, or rubbish and green.
          Thanks.
          johnnyboyJ 1 Reply Last reply Reply Quote 0
          • johnnyboyJ Offline
            johnnyboy @Richard238
              Richard238
              I’ve got a coloured trash-o icon against each entry in my binday calendar, but I’d like two, one per bin.
              strawberry 3.141S johnnyboyJ 2 Replies Last reply Reply Quote 0
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Richard238
                @Richard238 in my oppinion there is no easy and clean solution for that without modyfing the code
                in the next update there is at least the possibility to colorize every calendar differently
                  johnnyboy @strawberry 3.141
                      Richard238
                      Sure, it’s in /home/pi/MagicMirror/css/custom.css
                       * Changes to this files will be ignored by GIT. *
                       body {
                       .fa.fa-calendar-check-o {
                        color: #00d2ff; /* Blue */
                       .fa.fa-trash-o  {
                        color: #C97F7F; /* Brown */
                      johnnyboyJ strawberry 3.141S 2 Replies Last reply Reply Quote 1
                          @Richard238 https://github.com/MichMich/MagicMirror/pull/779
                          johnnyboyJ R 2 Replies Last reply Reply Quote 1
                              strawberry 3.141 Project Sponsor Module Developer @johnnyboy
                              @johnnyboy There is a css trick you probably didn’t know about, but will blow your mind :D
                              there is only one trash can icon in fontawesome, so how can we use it but colorize it differently for different trash types.
                              In germany, at least in my area, paper is blue, plastic is yellow, biowaste is brown and rest is black.
                              this is a working example https://jsfiddle.net/a8p7snpd/4/ you just need some icons that you never will use in the calendar module like car, truck and cab
                              johnnyboyJ 1 Reply Last reply Reply Quote 1
                                Richard238 @strawberry 3.141
                                @strawberry-3.141 What do I do with that, how do I use it?
                                Thanks.
                                • cowboysdudeC Offline
                                  strawberry taught me how to do this he said:
                                  “there two ways to make a truck to a trash can 1. you take my css 2. you crash the truck into a wall :D”
                                    @Richard238 you have to wait until it gets merged into the code base or you switch to my fork, but i wouldnt recommend that
                                        changes got merged and can be used in the develop branch or you have to wait until the new version gets deployed
                                        alt text
                                          Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                          @strawberry-3.141 said in Calendar Module: Multiple Icons.:
                                          Will I be able to choose NO ICON?
                                            strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                            @Mykle1 there is a default symbol, but you could try to cheat and define symbol as an empty string. cant test it atm.
