    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 100.4k Views 16 Watching
      broberg Project Sponsor @strawberry 3.141
      @strawberry-3.141 Yeah I’ve noticed. If this module keeps misbehaving I will look in to the moment.js instead. looka a lot simpler, thanks for the link!
      Mykle1M 1 Reply Last reply
      • Y
        yawns Moderator @strawberry 3.141
        @strawberry-3.141
        Absolutely right, moment.js makes life a lot easier when it comes to times and dates.
        • SnilleS
          Snille Module Developer
          Hi there! I just posted a PR to you on github, adding the “passed” text via the config. And also let the “toWhat” event to still be shown when the event has passed (makes more sense i think if you use the “passed” text.) :)
          B 1 Reply Last reply
            broberg Project Sponsor @Snille
            @Snille There is already a text being displayed once the day has passed, not configurable, but, there is one :D
            SnilleS 1 Reply Last reply
            • SnilleS
              Snille Module Developer @broberg
              @broberg I know, that’s why I only made it configurable. :) Then ppl don’t have to change your code to set their own message. :)
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @broberg
                @broberg said in MMM-doomsDay - The countdown module,:
                Hey Bro, I just wanted to report that my last 3 day test worked correctly, without a hitch. When I looked at my mirror this morning, it said, “Did it work?” :thumbsup_tone1:
                  Finally got around to adding the option to change the text displayed when the doomsDay has passed as @Snille suggested!
                  • Mykle1M
                    So I should do a git pull?
                      broberg Project Sponsor @Mykle1
                      @Mykle1 Only if you feel like it!
                      But the latest is the coolest, don’t you think? ;)
                      • Mykle1M
                        Of course I feel like it.
                        No doubt! I’m a huge fan of this module. :thumbsup:
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Mykle1
                          @broberg
                          Actually, I won’t know for 26 days. I’ll let you know then!
                            @Mykle1 Hahaha, fair enough :thumbsup:
                              pjkoeleman
                              My MagicMirror is updating around 23:00 hour, and can’t find what I did wrong. Has nothing to do with the time zone (I think).
                              This is what I have in my config.js
                                module: 'MMM-doomsday',
                                position: 'top_center',
                                  doomsDay: '2017-03-31 24:00:00',
                                  toWhat: 'End of month'
                              I even made a test file in my browser, and then it’s is working as aspected.
                              Does any one now where the problem is.
                                broberg Project Sponsor @pjkoeleman
                                @pjkoeleman nope, probably a timezone issue on the Pi itself, does the clock work correctly? daylight saving time?
                                Try changing the time from 24:00:00 to 23:59:00
                                P 1 Reply Last reply
                                  pjkoeleman @broberg
                                  @broberg The Pi itself is working correctly, the clock module is giving me the right time and date. And is updating around midnight.
                                  I Will try 23:59 and see what come’s out off it.
                                    pjkoeleman
                                    With time set to 23:59 the module is changing at 0:44. The question is were is the offset off 45 minutes comming from ?
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @pjkoeleman
                                      @pjkoeleman said in MMM-doomsDay - The countdown module,:
                                      I’m not trying to answer for broberg. It’s his module, but I use this module and I’ve had great success with it. It’s possible that the module is changing at 0:44 if you have the default updateInterval: 60 * 60 * 1000, . If you started the mirror at 44 minutes past any hour, then it wouldn’t update until the next 44 minute mark. If this is your case, then your module updated at 23:44 and not again until 0:44. The logical solution would be to set the updateInterval: to a smaller value or launch the module exactly on the hour, if that’s even possible. I don’t know if the module is set to always update at 24:00. If it’s not, then I would humbly request that it be added to the module.
                                        pjkoeleman @Mykle1
                                        @Mykle1 You are right, changed it to 10 minutes. now have to wait what happens.
                                        • Mykle1M
                                          Ok, let me know how it goes. I’m never awake at midnight so I only see the module in the mornings, and it’s been correct all along for me.
                                            pjkoeleman @Mykle1
                                            @Mykle1 Now it was changing at 00:06 hour so this module works ok with the right config settings.
                                            • 3 / 4
