    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 100.4k Views 16 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @broberg
      @broberg said in MMM-doomsDay - The countdown module,:
      Finally got around to adding the option to change the text displayed when the doomsDay has passed as @Snille suggested!
      So I should do a git pull?
      B 1 Reply Last reply
        broberg Project Sponsor @Mykle1
        @Mykle1 Only if you feel like it!
        But the latest is the coolest, don’t you think? ;)
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Of course I feel like it.
          No doubt! I’m a huge fan of this module. :thumbsup:
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Mykle1
            @broberg
            Actually, I won’t know for 26 days. I’ll let you know then!
              @Mykle1 Hahaha, fair enough :thumbsup:
                pjkoeleman
                My MagicMirror is updating around 23:00 hour, and can’t find what I did wrong. Has nothing to do with the time zone (I think).
                This is what I have in my config.js
                  module: 'MMM-doomsday',
                  position: 'top_center',
                    doomsDay: '2017-03-31 24:00:00',
                    toWhat: 'End of month'
                I even made a test file in my browser, and then it’s is working as aspected.
                Does any one now where the problem is.
                  broberg Project Sponsor @pjkoeleman
                  @pjkoeleman nope, probably a timezone issue on the Pi itself, does the clock work correctly? daylight saving time?
                  Try changing the time from 24:00:00 to 23:59:00
                  P 1 Reply Last reply
                    pjkoeleman @broberg
                    @broberg The Pi itself is working correctly, the clock module is giving me the right time and date. And is updating around midnight.
                    I Will try 23:59 and see what come’s out off it.
                      pjkoeleman
                      With time set to 23:59 the module is changing at 0:44. The question is were is the offset off 45 minutes comming from ?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @pjkoeleman
                        @pjkoeleman said in MMM-doomsDay - The countdown module,:
                        I’m not trying to answer for broberg. It’s his module, but I use this module and I’ve had great success with it. It’s possible that the module is changing at 0:44 if you have the default updateInterval: 60 * 60 * 1000, . If you started the mirror at 44 minutes past any hour, then it wouldn’t update until the next 44 minute mark. If this is your case, then your module updated at 23:44 and not again until 0:44. The logical solution would be to set the updateInterval: to a smaller value or launch the module exactly on the hour, if that’s even possible. I don’t know if the module is set to always update at 24:00. If it’s not, then I would humbly request that it be added to the module.
                          pjkoeleman @Mykle1
                          @Mykle1 You are right, changed it to 10 minutes. now have to wait what happens.
                          • Mykle1M
                            Ok, let me know how it goes. I’m never awake at midnight so I only see the module in the mornings, and it’s been correct all along for me.
                              pjkoeleman @Mykle1
                              @Mykle1 Now it was changing at 00:06 hour so this module works ok with the right config settings.
                              • Mykle1M
                                Good! I like this module. I’ve been using for a month now for all sorts of reminders. It’s a pretty nifty little module!
                                  bberg115
                                  @broberg, thanks for the hard work :) I needed a “days up” counter for the lady friend. I modified the MMM-doomsDay.js so that it shows the number of days that we’ve been dating. I plan on changing the days to “X years, X days” sometime this week but wanted to say thanks!
                                  edit: nice tag/username
                                    broberg Project Sponsor @bberg115
                                    @bberg115 Nice :D (easy to remember the anniversary then haha ;) )
                                    My username is my lastname, so it’s easy to remember hahaha
                                      bminer1
                                      Having an issue with the “toWhat” sticking.
                                      I can not get it to change from “Leaving for Paris!”. See my code below:
                                      module: ‘MMM-doomsDay’,
                                      position: ‘bottom_right’, // This can be any of the regions, best results in center regions
                                      doomsDay: “2017-05-07 24:00:00”, // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                      ToWhat: ‘Joeys Wedding in TN!’,
                                      updateInterval: 1 * 3600000,
                                      singular: ‘more day!’, // what it should say when it’s only one day left, default is Day Left
                                      plural: ‘more days’, // what it should say when it’s more days left, default is Days Left
                                      // See ‘Configuration options’ for more information.
                                      0_1490728574011_upload-95d70689-8dbe-4ab1-b9f6-447b6720a84c
                                        broberg Project Sponsor @bminer1
                                        @bminer1
                                        It’s case sensitive
                                        toWhat not ToWhat
                                          bminer1
                                          Thanks! It worked but that was copied and pasted from GitHub. May want to make the change.
                                          0_1490728928244_upload-91d7f2b1-ed96-4c2d-b3e8-04cca60299c2
                                            bminer1
                                            Also, is there a way to add multiple count downs to the one module or do you duplicate the module with every countdown?
                                            • 3 / 4
