    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 97.8k Views 16 Watching
      pjkoeleman
      My MagicMirror is updating around 23:00 hour, and can’t find what I did wrong. Has nothing to do with the time zone (I think).
      This is what I have in my config.js
        module: 'MMM-doomsday',
        position: 'top_center',
          doomsDay: '2017-03-31 24:00:00',
          toWhat: 'End of month'
      I even made a test file in my browser, and then it’s is working as aspected.
      Does any one now where the problem is.
        broberg Project Sponsor @pjkoeleman
        @pjkoeleman nope, probably a timezone issue on the Pi itself, does the clock work correctly? daylight saving time?
        Try changing the time from 24:00:00 to 23:59:00
          pjkoeleman @broberg
          @broberg The Pi itself is working correctly, the clock module is giving me the right time and date. And is updating around midnight.
          I Will try 23:59 and see what come’s out off it.
            pjkoeleman
            With time set to 23:59 the module is changing at 0:44. The question is were is the offset off 45 minutes comming from ?
              Mykle1 Project Sponsor Module Developer @pjkoeleman
              @pjkoeleman said in MMM-doomsDay - The countdown module,:
              I’m not trying to answer for broberg. It’s his module, but I use this module and I’ve had great success with it. It’s possible that the module is changing at 0:44 if you have the default updateInterval: 60 * 60 * 1000, . If you started the mirror at 44 minutes past any hour, then it wouldn’t update until the next 44 minute mark. If this is your case, then your module updated at 23:44 and not again until 0:44. The logical solution would be to set the updateInterval: to a smaller value or launch the module exactly on the hour, if that’s even possible. I don’t know if the module is set to always update at 24:00. If it’s not, then I would humbly request that it be added to the module.
                pjkoeleman @Mykle1
                @Mykle1 You are right, changed it to 10 minutes. now have to wait what happens.
                  Ok, let me know how it goes. I’m never awake at midnight so I only see the module in the mornings, and it’s been correct all along for me.
                    pjkoeleman @Mykle1
                    @Mykle1 Now it was changing at 00:06 hour so this module works ok with the right config settings.
                      Good! I like this module. I’ve been using for a month now for all sorts of reminders. It’s a pretty nifty little module!
                        bberg115
                        @broberg, thanks for the hard work :) I needed a “days up” counter for the lady friend. I modified the MMM-doomsDay.js so that it shows the number of days that we’ve been dating. I plan on changing the days to “X years, X days” sometime this week but wanted to say thanks!
                        edit: nice tag/username
                          broberg Project Sponsor @bberg115
                          @bberg115 Nice :D (easy to remember the anniversary then haha ;) )
                          My username is my lastname, so it’s easy to remember hahaha
                            bminer1
                            Having an issue with the “toWhat” sticking.
                            I can not get it to change from “Leaving for Paris!”. See my code below:
                            module: ‘MMM-doomsDay’,
                            position: ‘bottom_right’, // This can be any of the regions, best results in center regions
                            doomsDay: “2017-05-07 24:00:00”, // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                            ToWhat: ‘Joeys Wedding in TN!’,
                            updateInterval: 1 * 3600000,
                            singular: ‘more day!’, // what it should say when it’s only one day left, default is Day Left
                            plural: ‘more days’, // what it should say when it’s more days left, default is Days Left
                            // See ‘Configuration options’ for more information.
                            0_1490728574011_upload-95d70689-8dbe-4ab1-b9f6-447b6720a84c
                              broberg Project Sponsor @bminer1
                              @bminer1
                              It’s case sensitive
                              toWhat not ToWhat
                                bminer1
                                Thanks! It worked but that was copied and pasted from GitHub. May want to make the change.
                                0_1490728928244_upload-91d7f2b1-ed96-4c2d-b3e8-04cca60299c2
                                  bminer1
                                  Also, is there a way to add multiple count downs to the one module or do you duplicate the module with every countdown?
                                    @bminer1 nice catch, the example was wrong, somehow I missed that!
                                    (it’s correct in the Configuration list however)
                                    Multiple instances in the config is the way to go at the moment,
                                      mydiva
                                      It is possible to make instead of just days, weeks and days left? Thanks guys
                                        mydiva
                                        I did it by myself, thank you anyway for the great module.
                                        • N Offline
                                          noelandrews
                                          Hi all,
                                          Bringing an old thread back up, just installed and got this module activated. I think I’ve done it correctly as per github but its not working. It just displays the ‘finished’ message the death and despair bit.
                                          Can anyone tell me what silly obvious thing I’ve done wrong? Config in the pic below
                                          justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                                          • justjim1220J Offline
                                            justjim1220 Module Developer @noelandrews
                                            @noelandrews
                                            try removing the comma at the end of the ‘toWhat’ line
                                            Jim Hallock - 1995
                                            • 3 / 4
