    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 100.5k Views 16 Watching
      pjkoeleman @broberg
      @broberg The Pi itself is working correctly, the clock module is giving me the right time and date. And is updating around midnight.
      I Will try 23:59 and see what come’s out off it.
        pjkoeleman
        With time set to 23:59 the module is changing at 0:44. The question is were is the offset off 45 minutes comming from ?
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @pjkoeleman
          @pjkoeleman said in MMM-doomsDay - The countdown module,:
          I’m not trying to answer for broberg. It’s his module, but I use this module and I’ve had great success with it. It’s possible that the module is changing at 0:44 if you have the default updateInterval: 60 * 60 * 1000, . If you started the mirror at 44 minutes past any hour, then it wouldn’t update until the next 44 minute mark. If this is your case, then your module updated at 23:44 and not again until 0:44. The logical solution would be to set the updateInterval: to a smaller value or launch the module exactly on the hour, if that’s even possible. I don’t know if the module is set to always update at 24:00. If it’s not, then I would humbly request that it be added to the module.
          P 1 Reply Last reply
            pjkoeleman @Mykle1
            @Mykle1 You are right, changed it to 10 minutes. now have to wait what happens.
            • Mykle1M
              Ok, let me know how it goes. I’m never awake at midnight so I only see the module in the mornings, and it’s been correct all along for me.
                pjkoeleman @Mykle1
                @Mykle1 Now it was changing at 00:06 hour so this module works ok with the right config settings.
                • Mykle1M
                  Good! I like this module. I’ve been using for a month now for all sorts of reminders. It’s a pretty nifty little module!
                    bberg115
                    @broberg, thanks for the hard work :) I needed a “days up” counter for the lady friend. I modified the MMM-doomsDay.js so that it shows the number of days that we’ve been dating. I plan on changing the days to “X years, X days” sometime this week but wanted to say thanks!
                    edit: nice tag/username
                    B 1 Reply Last reply
                      broberg Project Sponsor @bberg115
                      @bberg115 Nice :D (easy to remember the anniversary then haha ;) )
                      My username is my lastname, so it’s easy to remember hahaha
                        bminer1
                        Having an issue with the “toWhat” sticking.
                        I can not get it to change from “Leaving for Paris!”. See my code below:
                        module: ‘MMM-doomsDay’,
                        position: ‘bottom_right’, // This can be any of the regions, best results in center regions
                        doomsDay: “2017-05-07 24:00:00”, // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                        ToWhat: ‘Joeys Wedding in TN!’,
                        updateInterval: 1 * 3600000,
                        singular: ‘more day!’, // what it should say when it’s only one day left, default is Day Left
                        plural: ‘more days’, // what it should say when it’s more days left, default is Days Left
                        // See ‘Configuration options’ for more information.
                        0_1490728574011_upload-95d70689-8dbe-4ab1-b9f6-447b6720a84c
                          broberg Project Sponsor @bminer1
                          @bminer1
                          It’s case sensitive
                          toWhat not ToWhat
                            bminer1
                            Thanks! It worked but that was copied and pasted from GitHub. May want to make the change.
                            0_1490728928244_upload-91d7f2b1-ed96-4c2d-b3e8-04cca60299c2
                              bminer1
                              Also, is there a way to add multiple count downs to the one module or do you duplicate the module with every countdown?
                                @bminer1 nice catch, the example was wrong, somehow I missed that!
                                (it’s correct in the Configuration list however)
                                Multiple instances in the config is the way to go at the moment,
                                  mydiva
                                  It is possible to make instead of just days, weeks and days left? Thanks guys
                                    mydiva
                                    I did it by myself, thank you anyway for the great module.
                                    • N
                                      noelandrews
                                      Hi all,
                                      Bringing an old thread back up, just installed and got this module activated. I think I’ve done it correctly as per github but its not working. It just displays the ‘finished’ message the death and despair bit.
                                      Can anyone tell me what silly obvious thing I’ve done wrong? Config in the pic below
                                      justjim1220J Mykle1M 2 Replies Last reply
                                      • justjim1220J
                                        justjim1220 Module Developer @noelandrews
                                        @noelandrews
                                        try removing the comma at the end of the ‘toWhat’ line
                                        Jim Hallock - 1995
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @noelandrews
                                          @noelandrews said in MMM-doomsDay - The countdown module,:
                                          Your config looks fine. I just installed and ran the module without a problem, duplicating your config entry. Are you sure you saved the config after having made the entry or that you are not working a second config? I’ve done that plenty of times.
                                          Here is a screenshot of the module working with your config
                                              module: 'MMM-doomsDay',
                                              position: 'bottom_center', // This can be any of the regions, best results in center regions
                                                  doomsDay: "2019-07-22 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date
                                                  toWhat: "Leaving for the USA!",
                                          If it continues to give you trouble, you could try https://github.com/mykle1/MMM-EventHorizon which does basically the same thing, with a few more options, as well as a working countdown timer.
                                          • N
                                            noelandrews
                                            Thanks guys, very weird. The config is exactly as you have copied straight from github. I’ll give Event Horizon a shot.
                                            • 3 / 4
