    MMM-MovieListings
    29 Posts 12 Posters 20.9k Views 12 Watching
    • F Offline
      fischi87 @Tueti
      @Tueti hello again, i tried to display ur module but i got always this error:
      error: kann .git/FETCH_HEAD nicht öffnen: Keine Berechtigung
      and yes i have a api v3 :-)
      • T Offline
        Tueti
        @fischi87 did you sudo the git clone?
        As a work around I think it would help if you reset the permissions for the .git directory:
        cd ~/MagicMirror/modules/MMM-MovieListings and then sudo chown -R pi:pi .git/ (only if you left the user of your raspberry pi as pi - else use the username of your user).
        But I will investigate this issue, that is weird indeed. Sorry for that :/
        • T Offline
          Tueti
          I re-uploaded the entire module again to a fresh git repository (same url: https://github.com/Tueti/MMM-MovieListings), so if the work around does not work, please try re-installing and let me know if that solved the issue.
          • F Offline
            fischi87 @Tueti
            @Tueti
            when ich try git pull because of a update i get this
            pi@Magic-Mirror:~/MagicMirror/modules/MMM-MovieListings $ git pull
            *** Please tell me who you are.
            Run
              git config --global user.email "you@example.com"
              git config --global user.name "Your Name"
            to set your account's default identity.
            Omit --global to set the identity only in this repository.
            fatal: empty ident name (for ) not allowed
            and yes i did sudo chown -R pi:pi .git/
            • T Offline
              Tueti
              Could you try deleting the module and re-install? I did a re-upload to a new repository with the same name. Maybe that messed it up.
              I am very sorry for the inconvenience, I think a fresh start might fix it.
              • zeularZ Offline
                zeular
                Hi
                Is it possible to get plot and genre?
                I can see that there are genres in the code but it is not presented.
                • P Online
                  Peter
                  Can somebody tell me what to put in config.js to make this module working?
                  Thanks!
                  Peter
                  cruunnerrC 1 Reply Last reply Reply Quote 0
                  • cruunnerrC Offline
                    cruunnerr @Peter
                    @Peter
                    must be like this:
                                                    module: 'MMM-MovieListings',
                                                    position: 'top_left',   // This can be any of the regions. Best results in left or$
                    					apiKey: 'YOUR_API_KEY',
                    					region: 'DE',
                    					language: 'de-DE',
                    					interface: 'poster', //'list', 'poster', 'detailed'
                    					includeMoviePlot: false,
                    					maxPlotLength: 198,
                    					header: 'Kinofilme',
                    					moviesPerPage: 0,
                    					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                    					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                    					animationSpeed: 2.5 * 1000,
                    					pageChangeInterval: 35 * 1000
                    • P Online
                      Peter @cruunnerr
                      @cruunnerr , thanks!
                      I have it running!
                      Looks good.
                      Peter
                        jeffreyking
                        Hello i can’t get mine to work
