    MMM-MovieListings
    29 Posts 12 Posters 23.9k Views 12 Watching
    • T
      Tueti
      I re-uploaded the entire module again to a fresh git repository (same url: https://github.com/Tueti/MMM-MovieListings), so if the work around does not work, please try re-installing and let me know if that solved the issue.
      F 1 Reply Last reply
      • F
        fischi87 @Tueti
        @Tueti
        when ich try git pull because of a update i get this
        pi@Magic-Mirror:~/MagicMirror/modules/MMM-MovieListings $ git pull
        *** Please tell me who you are.
        Run
          git config --global user.email "you@example.com"
          git config --global user.name "Your Name"
        to set your account's default identity.
        Omit --global to set the identity only in this repository.
        fatal: empty ident name (for ) not allowed
        and yes i did sudo chown -R pi:pi .git/
        • T
          Tueti
          Could you try deleting the module and re-install? I did a re-upload to a new repository with the same name. Maybe that messed it up.
          I am very sorry for the inconvenience, I think a fresh start might fix it.
          • zeularZ
            zeular
            Hi
            Is it possible to get plot and genre?
            I can see that there are genres in the code but it is not presented.
              Peter
              Can somebody tell me what to put in config.js to make this module working?
              Thanks!
              Peter
              cruunnerrC 1 Reply Last reply
              • cruunnerrC
                cruunnerr @Peter
                @Peter
                must be like this:
                                                module: 'MMM-MovieListings',
                                                position: 'top_left',   // This can be any of the regions. Best results in left or$
                					apiKey: 'YOUR_API_KEY',
                					region: 'DE',
                					language: 'de-DE',
                					interface: 'poster', //'list', 'poster', 'detailed'
                					includeMoviePlot: false,
                					maxPlotLength: 198,
                					header: 'Kinofilme',
                					moviesPerPage: 0,
                					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                					animationSpeed: 2.5 * 1000,
                					pageChangeInterval: 35 * 1000
                P 1 Reply Last reply
                  Peter @cruunnerr
                  @cruunnerr , thanks!
                  I have it running!
                  Looks good.
                  Peter
                    jeffreyking
                    Hello i can’t get mine to work
                    bheplerB 1 Reply Last reply
                    • bheplerB
                      bhepler Module Developer @jeffreyking
                      @jeffreyking - We’re going to need a little more information than that.
                      Do you have any other modules working?
                      What behavior are you seeing?
                      What does the relevant portion of your config.js say?
                      What errors are showing up in your log files?
                        jeffreyking
                        Thank you for replying I got it to work and it is awesome I made a error with the brackets { but I sorted it out .
                        i am running my magic mirror on a laptop with Ubuntu as the os I am new to this and mm-movielistings was the first module I have installed.
                          Radu_Stancu
                          Can anyone tell me how to modify the size and the color of the text? It is rather small, and I would like to make it white , instead of gray.
                          Thanks.
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Radu_Stancu
                            @radu_stancu
                            In your custom.css file, add these and adjust accordingly. I did not test but simply looked at the classes in the module.js file but they should work for you
                            .MMM-MovieListings .header {
                              color: #FFFFFF;               /* Header color. Default is white. */
                            .MMM-MovieListings .small.dimmed {
                              font-size: 18px;
                              color: #FFFFFF;   /* white */
                            .MMM-MovieListings .xsmall {
                              font-size: 18px;
                            .MMM-MovieListings .xsmall.dimmed {
                              font-size: 18px;
                            .MMM-MovieListings .marginTop.xsmall {
                              font-size: 18px;
                            R 1 Reply Last reply
                              Radu_Stancu @Mykle1
                              @mykle1 Thank you very much! I`ll test as soon as I reinstall MM on the Asus TinkerBoard.
                                Radu_Stancu
                                Hi, I have tried the code you provided, and it partially does what I want.
                                It changes the font size and color of the actors but not of the description.
                                I want to enlarge the module as a whole, image, description and any text while also making them white, as my mirror is a bit darker than I was expecting.
                                Any further help is greatly appreciated.
                                • Mykle1M
                                  @radu_stancu
                                  I don’t have an API key for this module so I can’t run it or test it. Looking through the module.js file to see the className of the description text but it’s not immediately apparent. You could try:
                                  .MMM-MovieListings .dimmed {
                                    font-size: 18px;
                                    Radu_Stancu @Mykle1
                                    @mykle1 Thanks, it`s getting closer to what I want. I will check the module you are mentioning. I am not that familiar with js so I did not recognize the things I need to change to accomplish what I was looking for. I will try again and see if I can make the image a bit bigger and the title white. Thanks a lot for your patience.
                                    • Mykle1M
                                      @radu_stancu
                                      No worries, mate. Good luck and have fun.
                                        Socrates
                                        Hopefully its ok to necro bump this topic instead of opening a new thread, as this is the official module page?
                                        The module was working fine until few days back since seeral years, but now it has stopped working. I have regenerated a new api key from tmdb, yet no luck.
                                          sdetweil @Socrates
                                          @Socrates the Official page is the github repo, id check its issues list
                                          do you see any errors listed in the output of npm start?
                                            DarkV
                                            I have tried the script to update itScreenshot 2024-12-19 143617.png and failed. How do I update this module?
