    MMM-MovieListings
    29 Posts 12 Posters 20.9k Views 12 Watching
    • T Offline
      Tueti
      Description:
      A module for displaying movies that are currently airing in theaters near you. I decided to only show the top 20 movies as these are the ones being aired in most movie theaters around you.
      Currently two different views are supported (a simple list with as many movies as you’d like to show at once) and a more advanced poster view, like shown here:
      Screenshot:
      MMM-MovieListings
      Download:
      [card:Tueti/MMM-MovieListings]
      Version 1
      • A third view (a detailed list, without an image but more info that movie titles only) is on the table and will be added probably next week.
      F 1 Reply Last reply Reply Quote 1
      • F Offline
        fischi87 @Tueti
        @Tueti hello, how can i install this module? i get with ssh en error that tis link no .git link are?
        thanks
        • T Offline
          Tueti
          Hi @fischi87,
          the installation should be normal git and therefore exactly as with any other module:
          1. First move into the correct directory => cd ~/MagicMirror/modules
          2. Fetch data from Github => git clone https://github.com/Tueti/MMM-MovieListings.git
          3. Move into module directory and install dependencies => cd MMM-MovieListings && npm install
          This can either be run on the device that runs your MagicMirror or via ssh connected to that device. Are you able to install any other modules or could you post your commands and the console output here?
          Thank you!
          Christian
          P.S.: I updated the README.md now, thanks for the hint that it wasn’t included :)
          • F Offline
            fischi87 @Tueti
            @Tueti thank for ur reply. im so sorry i forgot to write “git clone” i just wrote " git" i solved right now. thanks
            • T Offline
              Tueti
              Glad it helped :D
              • F Offline
                fischi87 @Tueti
                @Tueti hello again, i tried to display ur module but i got always this error:
                error: kann .git/FETCH_HEAD nicht öffnen: Keine Berechtigung
                and yes i have a api v3 :-)
                • T Offline
                  Tueti
                  @fischi87 did you sudo the git clone?
                  As a work around I think it would help if you reset the permissions for the .git directory:
                  cd ~/MagicMirror/modules/MMM-MovieListings and then sudo chown -R pi:pi .git/ (only if you left the user of your raspberry pi as pi - else use the username of your user).
                  But I will investigate this issue, that is weird indeed. Sorry for that :/
                  • T Offline
                    Tueti
                    I re-uploaded the entire module again to a fresh git repository (same url: https://github.com/Tueti/MMM-MovieListings), so if the work around does not work, please try re-installing and let me know if that solved the issue.
                    • F Offline
                      fischi87 @Tueti
                      @Tueti
                      when ich try git pull because of a update i get this
                      pi@Magic-Mirror:~/MagicMirror/modules/MMM-MovieListings $ git pull
                      *** Please tell me who you are.
                      Run
                        git config --global user.email "you@example.com"
                        git config --global user.name "Your Name"
                      to set your account's default identity.
                      Omit --global to set the identity only in this repository.
                      fatal: empty ident name (for ) not allowed
                      and yes i did sudo chown -R pi:pi .git/
                      • T Offline
                        Tueti
                        Could you try deleting the module and re-install? I did a re-upload to a new repository with the same name. Maybe that messed it up.
                        I am very sorry for the inconvenience, I think a fresh start might fix it.
