    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @pepemujica
      @pepemujica cat /proc/asound/cards
      P 1 Reply Last reply
        pepemujica @strawberry 3.141
        @strawberry-3.141 said in MMM-voice:
        What should I do with this? Sorry for my bad linux usage
        0_1490896262887_upload-034fd73c-bcbe-4fbc-a037-de9eca9c7bfe
        • strawberry 3.141S
          @pepemujica if this soundcard is your microphone then put microphone: 0 in your config
            @strawberry-3.141 I’ve already tryed that, and got the same result:
            First “Initialising”, after a few seconds “ERROR” and under the microphone “undefined”
            Error.log
            0_1490903332620_upload-9de8f59a-a8e3-4fa3-a056-a66c55142af6
            debug.log
            INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
            INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
            INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
            Error opening audio device plughw:0 for capture: Device or resource busy
            FATAL: “continuous.c”, line 245: Failed to open audio device
            • strawberry 3.141S
              @pepemujica the pi is nit able to use your microphone, can you test it with another one?
                @strawberry-3.141 Actually, I’ve tried whith an “Online Mic Tester” and could record and listen my voice, so I asume it is able to use the microphone.
                Could you recommend me something else?
                • strawberry 3.141S
                  @pepemujica you could try to record on the pi https://stackoverflow.com/questions/28054731/capture-record-audio-input-in-raspberrypi
                    @strawberry-3.141 I can record with the mic when I use arecord -f cd -D plughw:0 -d 10 a.wav and after I can listen
                    • strawberry 3.141S
                      @pepemujica the error message says that your microphone is used by something else, so i guess you have to investigate on that
                      • daenickD
                        daenick
                        Hello, I´m havin problems with this:
                        alt text
                        Any idea?
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @daenick
                          @daenick what is your os version?
                          daenickD 2 Replies Last reply
                          • daenickD
                            daenick @strawberry 3.141
                            @strawberry-3.141 2017-03-02-raspbian-jessie
                            • strawberry 3.141S
                              @daenick can you update your system and try again? sudo apt-get update ; sudo apt-get upgrade
                              • daenickD
                                Yes, that was the first thind I do, but doesn´t works…
                                Mysteriously after of the installation of MMM-mail could continue
                                • strawberry 3.141S
                                  @daenick so it is installed now?
                                  • daenickD
                                    daenick
                                    No, now I get this:
                                    alt text
                                    • strawberry 3.141S
                                      @daenick looks like you executed the installer with sudo
                                      daenickD 1 Reply Last reply
                                      • daenickD
                                        @strawberry-3.141 can try again without restart everything?
                                        By the way, you are so friendly. Thanks!
                                        • strawberry 3.141S
                                          @daenick remove the node_modules folder in MagicMirror/modules/MMM-voice first and go into /root/pocketsphinx and execute sudo make uninstall same in /root/sphinxbase then rerun the installer
                                          • daenickD
                                            @strawberry-3.141 I ran the bash without the sudo. Finish ok
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
