    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @pepemujica
      @pepemujica can you enable debug: true in the config and have a look what the debug log says
      P 2 Replies Last reply Reply Quote 0
        pepemujica @strawberry 3.141
        @strawberry-3.141 at the module config?
          @strawberry-3.141 Got this:
          INFO: pocketsphinx.c(152): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
          Current configuration:
          [NAME] [DEFLT] [VALUE]
          -agc none none
          -agcthresh 2.0 2.000000e+00
          -allphone
          -allphone_ci yes yes
          -alpha 0.97 9.700000e-01
          -ascale 20.0 2.000000e+01
          -aw 1 1
          -backtrace no no
          -beam 1e-48 1.000000e-48
          -bestpath yes yes
          -bestpathlw 9.5 9.500000e+00
          -ceplen 13 13
          -cmn live batch
          -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
          -compallsen no no
          -debug 0
          -dict modules/MMM-voice/MMM-voice.dic
          -dictcase no no
          -dither no no
          -doublebw no no
          -ds 1 1
          -fdict
          -feat 1s_c_d_dd 1s_c_d_dd
          -featparams
          -fillprob 1e-8 1.000000e-08
          -frate 100 100
          -fsg
          -fsgusealtpron yes yes
          -fsgusefiller yes yes
          -fwdflat yes yes
          -fwdflatbeam 1e-64 1.000000e-64
          -fwdflatefwid 4 4
          -fwdflatlw 8.5 8.500000e+00
          -fwdflatsfwin 25 25
          -fwdflatwbeam 7e-29 7.000000e-29
          -fwdtree yes yes
          -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
          -input_endian little little
          -jsgf
          -keyphrase
          -kws
          -kws_delay 10 10
          -kws_plp 1e-1 1.000000e-01
          -kws_threshold 1e-30 1.000000e-30
          -latsize 5000 5000
          -lda
          -ldadim 0 0
          -lifter 0 22
          -lm modules/MMM-voice/MMM-voice.lm
          -lmctl
          -lmname
          -logbase 1.0001 1.000100e+00
          -logfn
          -logspec no no
          -lowerf 133.33334 1.300000e+02
          -lpbeam 1e-40 1.000000e-40
          -lponlybeam 7e-29 7.000000e-29
          -lw 6.5 6.500000e+00
          -maxhmmpf 30000 30000
          -maxwpf -1 -1
          -mdef
          -mean
          -mfclogdir
          -min_endfr 0 0
          -mixw
          -mixwfloor 0.0000001 1.000000e-07
          -mllr
          -mmap yes yes
          -ncep 13 13
          -nfft 512 512
          -nfilt 40 25
          -nwpen 1.0 1.000000e+00
          -pbeam 1e-48 1.000000e-48
          -pip 1.0 1.000000e+00
          -pl_beam 1e-10 1.000000e-10
          -pl_pbeam 1e-10 1.000000e-10
          -pl_pip 1.0 1.000000e+00
          -pl_weight 3.0 3.000000e+00
          -pl_window 5 5
          -rawlogdir
          -remove_dc no no
          -remove_noise yes yes
          -remove_silence yes yes
          -round_filters yes yes
          -samprate 16000 1.600000e+04
          -seed -1 -1
          -sendump
          -senlogdir
          -senmgau
          -silprob 0.005 5.000000e-03
          -smoothspec no no
          -svspec 0-12/13-25/26-38
          -tmat
          -tmatfloor 0.0001 1.000000e-04
          -topn 4 4
          -topn_beam 0 0
          -toprule
          -transform legacy dct
          -unit_area yes yes
          -upperf 6855.4976 6.800000e+03
          -uw 1.0 1.000000e+00
          -vad_postspeech 50 50
          -vad_prespeech 20 20
          -vad_startspeech 10 10
          -vad_threshold 3.0 3.000000e+00
          -var
          -varfloor 0.0001 1.000000e-04
          -varnorm no no
          -verbose no no
          -warp_params
          -warp_type inverse_linear inverse_linear
          -wbeam 7e-29 7.000000e-29
          -wip 0.65 6.500000e-01
          -wlen 0.025625 2.562500e-02
          INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
          INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
          INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
          INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
          INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
          INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
          INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
          INFO: acmod.c(113): Attempting to use PTM computation module
          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
          INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
          INFO: ms_gauden.c(244): 128x13
          INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
          INFO: ms_gauden.c(304): 222 variance values floored
          INFO: ptm_mgau.c(476): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
          INFO: ptm_mgau.c(500): BEGIN FILE FORMAT DESCRIPTION
          INFO: ptm_mgau.c(563): Rows: 128, Columns: 5126
          INFO: ptm_mgau.c(595): Using memory-mapped I/O for senones
          INFO: ptm_mgau.c(838): Maximum top-N: 4
          INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
          INFO: dict.c(320): Allocating 4130 * 32 bytes (129 KiB) for word entries
          INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
          INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
          INFO: dict.c(336): 29 words read
          INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
          INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
          INFO: dict.c(361): 5 words read
          INFO: dict2pid.c(396): Building PID tables for dictionary
          INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
          INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
          INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
          INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
          INFO: ngram_model_trie.c(365): Header doesn’t match
          INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
          INFO: ngram_model_trie.c(193): LM of order 3
          INFO: ngram_model_trie.c(195): #1-grams: 25
          INFO: ngram_model_trie.c(195): #2-grams: 46
          INFO: ngram_model_trie.c(195): #3-grams: 23
          INFO: lm_trie.c(474): Training quantizer
          INFO: lm_trie.c(482): Building LM trie
          INFO: ngram_search_fwdtree.c(74): Initializing search tree
          INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
          INFO: ngram_search_fwdtree.c(186): Creating search channels
          INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
          INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
          INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
          INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
          ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
          Error opening audio device plughw:1 for capture: No such file or directory
          FATAL: “continuous.c”, line 245: Failed to open audio device
            @pepemujica ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
              @strawberry-3.141 So how can I fin this?
                @pepemujica cat /proc/asound/cards
                  @strawberry-3.141 said in MMM-voice:
                  What should I do with this? Sorry for my bad linux usage
                  0_1490896262887_upload-034fd73c-bcbe-4fbc-a037-de9eca9c7bfe
                    @pepemujica if this soundcard is your microphone then put microphone: 0 in your config
                      @strawberry-3.141 I’ve already tryed that, and got the same result:
                      First “Initialising”, after a few seconds “ERROR” and under the microphone “undefined”
                      Error.log
                      0_1490903332620_upload-9de8f59a-a8e3-4fa3-a056-a66c55142af6
                      debug.log
                      Error opening audio device plughw:0 for capture: Device or resource busy
                        @pepemujica the pi is nit able to use your microphone, can you test it with another one?
                          @strawberry-3.141 Actually, I’ve tried whith an “Online Mic Tester” and could record and listen my voice, so I asume it is able to use the microphone.
                          Could you recommend me something else?
                            @pepemujica you could try to record on the pi https://stackoverflow.com/questions/28054731/capture-record-audio-input-in-raspberrypi
                              @strawberry-3.141 I can record with the mic when I use arecord -f cd -D plughw:0 -d 10 a.wav and after I can listen
                                @pepemujica the error message says that your microphone is used by something else, so i guess you have to investigate on that
                                • daenickD Offline
                                  daenick
                                  Hello, I´m havin problems with this:
                                  alt text
                                  Any idea?
                                    strawberry 3.141 Project Sponsor Module Developer @daenick
                                    @daenick what is your os version?
                                    daenickD 2 Replies Last reply Reply Quote 0
                                    • daenickD Offline
                                      daenick @strawberry 3.141
                                      @strawberry-3.141 2017-03-02-raspbian-jessie
                                        @daenick can you update your system and try again? sudo apt-get update ; sudo apt-get upgrade
                                        • daenickD Offline
                                          Yes, that was the first thind I do, but doesn´t works…
                                          Mysteriously after of the installation of MMM-mail could continue
                                            @daenick so it is installed now?
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
