    MMM-voice
    voice control
    329 Posts 55 Posters 998.0k Views 50 Watching
    • johnnyboyJ Offline
      johnnyboy @yawns
      @yawns said in MMM-voice:
      mmm-voice is no apt package, it is a module for magic mirror.
      To remove it you do this
      cd ~/MagicMirror/modules
      rm -r mmm-voice
      I stand corrected @yawns… Sorry for giving wrong direction @pepemujica :-(
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @pepemujica
        @pepemujica can you enable debug: true in the config and have a look what the debug log says
        P 2 Replies Last reply Reply Quote 0
          pepemujica @strawberry 3.141
          @strawberry-3.141 at the module config?
            @strawberry-3.141 Got this:
            INFO: pocketsphinx.c(152): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
            Current configuration:
            [NAME] [DEFLT] [VALUE]
            -agc none none
            -agcthresh 2.0 2.000000e+00
            -allphone
            -allphone_ci yes yes
            -alpha 0.97 9.700000e-01
            -ascale 20.0 2.000000e+01
            -aw 1 1
            -backtrace no no
            -beam 1e-48 1.000000e-48
            -bestpath yes yes
            -bestpathlw 9.5 9.500000e+00
            -ceplen 13 13
            -cmn live batch
            -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
            -compallsen no no
            -debug 0
            -dict modules/MMM-voice/MMM-voice.dic
            -dictcase no no
            -dither no no
            -doublebw no no
            -ds 1 1
            -fdict
            -feat 1s_c_d_dd 1s_c_d_dd
            -featparams
            -fillprob 1e-8 1.000000e-08
            -frate 100 100
            -fsg
            -fsgusealtpron yes yes
            -fsgusefiller yes yes
            -fwdflat yes yes
            -fwdflatbeam 1e-64 1.000000e-64
            -fwdflatefwid 4 4
            -fwdflatlw 8.5 8.500000e+00
            -fwdflatsfwin 25 25
            -fwdflatwbeam 7e-29 7.000000e-29
            -fwdtree yes yes
            -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
            -input_endian little little
            -jsgf
            -keyphrase
            -kws
            -kws_delay 10 10
            -kws_plp 1e-1 1.000000e-01
            -kws_threshold 1e-30 1.000000e-30
            -latsize 5000 5000
            -lda
            -ldadim 0 0
            -lifter 0 22
            -lm modules/MMM-voice/MMM-voice.lm
            -lmctl
            -lmname
            -logbase 1.0001 1.000100e+00
            -logfn
            -logspec no no
            -lowerf 133.33334 1.300000e+02
            -lpbeam 1e-40 1.000000e-40
            -lponlybeam 7e-29 7.000000e-29
            -lw 6.5 6.500000e+00
            -maxhmmpf 30000 30000
            -maxwpf -1 -1
            -mdef
            -mean
            -mfclogdir
            -min_endfr 0 0
            -mixw
            -mixwfloor 0.0000001 1.000000e-07
            -mllr
            -mmap yes yes
            -ncep 13 13
            -nfft 512 512
            -nfilt 40 25
            -nwpen 1.0 1.000000e+00
            -pbeam 1e-48 1.000000e-48
            -pip 1.0 1.000000e+00
            -pl_beam 1e-10 1.000000e-10
            -pl_pbeam 1e-10 1.000000e-10
            -pl_pip 1.0 1.000000e+00
            -pl_weight 3.0 3.000000e+00
            -pl_window 5 5
            -rawlogdir
            -remove_dc no no
            -remove_noise yes yes
            -remove_silence yes yes
            -round_filters yes yes
            -samprate 16000 1.600000e+04
            -seed -1 -1
            -sendump
            -senlogdir
            -senmgau
            -silprob 0.005 5.000000e-03
            -smoothspec no no
            -svspec 0-12/13-25/26-38
            -tmat
            -tmatfloor 0.0001 1.000000e-04
            -topn 4 4
            -topn_beam 0 0
            -toprule
            -transform legacy dct
            -unit_area yes yes
            -upperf 6855.4976 6.800000e+03
            -uw 1.0 1.000000e+00
            -vad_postspeech 50 50
            -vad_prespeech 20 20
            -vad_startspeech 10 10
            -vad_threshold 3.0 3.000000e+00
            -var
            -varfloor 0.0001 1.000000e-04
            -varnorm no no
            -verbose no no
            -warp_params
            -warp_type inverse_linear inverse_linear
            -wbeam 7e-29 7.000000e-29
            -wip 0.65 6.500000e-01
            -wlen 0.025625 2.562500e-02
            INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
            INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
            INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
            INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
            INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
            INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
            INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
            INFO: acmod.c(113): Attempting to use PTM computation module
            INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
            INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
            INFO: ms_gauden.c(244): 128x13
            INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
            INFO: ms_gauden.c(304): 222 variance values floored
            INFO: ptm_mgau.c(476): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
            INFO: ptm_mgau.c(500): BEGIN FILE FORMAT DESCRIPTION
            INFO: ptm_mgau.c(563): Rows: 128, Columns: 5126
            INFO: ptm_mgau.c(595): Using memory-mapped I/O for senones
            INFO: ptm_mgau.c(838): Maximum top-N: 4
            INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
            INFO: dict.c(320): Allocating 4130 * 32 bytes (129 KiB) for word entries
            INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
            INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
            INFO: dict.c(336): 29 words read
            INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
            INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
            INFO: dict.c(361): 5 words read
            INFO: dict2pid.c(396): Building PID tables for dictionary
            INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
            INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
            INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
            INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
            INFO: ngram_model_trie.c(365): Header doesn’t match
            INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
            INFO: ngram_model_trie.c(193): LM of order 3
            INFO: ngram_model_trie.c(195): #1-grams: 25
            INFO: ngram_model_trie.c(195): #2-grams: 46
            INFO: ngram_model_trie.c(195): #3-grams: 23
            INFO: lm_trie.c(474): Training quantizer
            INFO: lm_trie.c(482): Building LM trie
            INFO: ngram_search_fwdtree.c(74): Initializing search tree
            INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
            INFO: ngram_search_fwdtree.c(186): Creating search channels
            INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
            INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
            INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
            INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
            ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
            Error opening audio device plughw:1 for capture: No such file or directory
            FATAL: “continuous.c”, line 245: Failed to open audio device
              @pepemujica ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
                @strawberry-3.141 So how can I fin this?
                  @pepemujica cat /proc/asound/cards
                    @strawberry-3.141 said in MMM-voice:
                    What should I do with this? Sorry for my bad linux usage
                    0_1490896262887_upload-034fd73c-bcbe-4fbc-a037-de9eca9c7bfe
                      @pepemujica if this soundcard is your microphone then put microphone: 0 in your config
                        @strawberry-3.141 I’ve already tryed that, and got the same result:
                        First “Initialising”, after a few seconds “ERROR” and under the microphone “undefined”
                        Error.log
                        0_1490903332620_upload-9de8f59a-a8e3-4fa3-a056-a66c55142af6
                        debug.log
                        Error opening audio device plughw:0 for capture: Device or resource busy
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 32
                        • 33
                        • 17 / 33
