    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      pepemujica @strawberry 3.141
      @strawberry-3.141 Got this:
      INFO: pocketsphinx.c(152): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
      Current configuration:
      [NAME] [DEFLT] [VALUE]
      -agc none none
      -agcthresh 2.0 2.000000e+00
      -allphone
      -allphone_ci yes yes
      -alpha 0.97 9.700000e-01
      -ascale 20.0 2.000000e+01
      -aw 1 1
      -backtrace no no
      -beam 1e-48 1.000000e-48
      -bestpath yes yes
      -bestpathlw 9.5 9.500000e+00
      -ceplen 13 13
      -cmn live batch
      -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
      -compallsen no no
      -debug 0
      -dict modules/MMM-voice/MMM-voice.dic
      -dictcase no no
      -dither no no
      -doublebw no no
      -ds 1 1
      -fdict
      -feat 1s_c_d_dd 1s_c_d_dd
      -featparams
      -fillprob 1e-8 1.000000e-08
      -frate 100 100
      -fsg
      -fsgusealtpron yes yes
      -fsgusefiller yes yes
      -fwdflat yes yes
      -fwdflatbeam 1e-64 1.000000e-64
      -fwdflatefwid 4 4
      -fwdflatlw 8.5 8.500000e+00
      -fwdflatsfwin 25 25
      -fwdflatwbeam 7e-29 7.000000e-29
      -fwdtree yes yes
      -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
      -input_endian little little
      -jsgf
      -keyphrase
      -kws
      -kws_delay 10 10
      -kws_plp 1e-1 1.000000e-01
      -kws_threshold 1e-30 1.000000e-30
      -latsize 5000 5000
      -lda
      -ldadim 0 0
      -lifter 0 22
      -lm modules/MMM-voice/MMM-voice.lm
      -lmctl
      -lmname
      -logbase 1.0001 1.000100e+00
      -logfn
      -logspec no no
      -lowerf 133.33334 1.300000e+02
      -lpbeam 1e-40 1.000000e-40
      -lponlybeam 7e-29 7.000000e-29
      -lw 6.5 6.500000e+00
      -maxhmmpf 30000 30000
      -maxwpf -1 -1
      -mdef
      -mean
      -mfclogdir
      -min_endfr 0 0
      -mixw
      -mixwfloor 0.0000001 1.000000e-07
      -mllr
      -mmap yes yes
      -ncep 13 13
      -nfft 512 512
      -nfilt 40 25
      -nwpen 1.0 1.000000e+00
      -pbeam 1e-48 1.000000e-48
      -pip 1.0 1.000000e+00
      -pl_beam 1e-10 1.000000e-10
      -pl_pbeam 1e-10 1.000000e-10
      -pl_pip 1.0 1.000000e+00
      -pl_weight 3.0 3.000000e+00
      -pl_window 5 5
      -rawlogdir
      -remove_dc no no
      -remove_noise yes yes
      -remove_silence yes yes
      -round_filters yes yes
      -samprate 16000 1.600000e+04
      -seed -1 -1
      -sendump
      -senlogdir
      -senmgau
      -silprob 0.005 5.000000e-03
      -smoothspec no no
      -svspec 0-12/13-25/26-38
      -tmat
      -tmatfloor 0.0001 1.000000e-04
      -topn 4 4
      -topn_beam 0 0
      -toprule
      -transform legacy dct
      -unit_area yes yes
      -upperf 6855.4976 6.800000e+03
      -uw 1.0 1.000000e+00
      -vad_postspeech 50 50
      -vad_prespeech 20 20
      -vad_startspeech 10 10
      -vad_threshold 3.0 3.000000e+00
      -var
      -varfloor 0.0001 1.000000e-04
      -varnorm no no
      -verbose no no
      -warp_params
      -warp_type inverse_linear inverse_linear
      -wbeam 7e-29 7.000000e-29
      -wip 0.65 6.500000e-01
      -wlen 0.025625 2.562500e-02
      INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
      INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
      INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
      INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
      INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
      INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
      INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
      INFO: acmod.c(113): Attempting to use PTM computation module
      INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
      INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
      INFO: ms_gauden.c(244): 128x13
      INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
      INFO: ms_gauden.c(304): 222 variance values floored
      INFO: ptm_mgau.c(476): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
      INFO: ptm_mgau.c(500): BEGIN FILE FORMAT DESCRIPTION
      INFO: ptm_mgau.c(563): Rows: 128, Columns: 5126
      INFO: ptm_mgau.c(595): Using memory-mapped I/O for senones
      INFO: ptm_mgau.c(838): Maximum top-N: 4
      INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
      INFO: dict.c(320): Allocating 4130 * 32 bytes (129 KiB) for word entries
      INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
      INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
      INFO: dict.c(336): 29 words read
      INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
      INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
      INFO: dict.c(361): 5 words read
      INFO: dict2pid.c(396): Building PID tables for dictionary
      INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
      INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
      INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
      INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
      INFO: ngram_model_trie.c(365): Header doesn’t match
      INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
      INFO: ngram_model_trie.c(193): LM of order 3
      INFO: ngram_model_trie.c(195): #1-grams: 25
      INFO: ngram_model_trie.c(195): #2-grams: 46
      INFO: ngram_model_trie.c(195): #3-grams: 23
      INFO: lm_trie.c(474): Training quantizer
      INFO: lm_trie.c(482): Building LM trie
      INFO: ngram_search_fwdtree.c(74): Initializing search tree
      INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
      INFO: ngram_search_fwdtree.c(186): Creating search channels
      INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
      INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
      INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
      INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
      ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
      Error opening audio device plughw:1 for capture: No such file or directory
      FATAL: “continuous.c”, line 245: Failed to open audio device
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @pepemujica
        @pepemujica ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
        P 1 Reply Last reply
          @strawberry-3.141 So how can I fin this?
          • strawberry 3.141S
            @pepemujica cat /proc/asound/cards
              @strawberry-3.141 said in MMM-voice:
              What should I do with this? Sorry for my bad linux usage
              0_1490896262887_upload-034fd73c-bcbe-4fbc-a037-de9eca9c7bfe
              • strawberry 3.141S
                @pepemujica if this soundcard is your microphone then put microphone: 0 in your config
                  @strawberry-3.141 I’ve already tryed that, and got the same result:
                  First “Initialising”, after a few seconds “ERROR” and under the microphone “undefined”
                  Error.log
                  0_1490903332620_upload-9de8f59a-a8e3-4fa3-a056-a66c55142af6
                  debug.log
                  Error opening audio device plughw:0 for capture: Device or resource busy
                  • strawberry 3.141S
                    @pepemujica the pi is nit able to use your microphone, can you test it with another one?
                      @strawberry-3.141 Actually, I’ve tried whith an “Online Mic Tester” and could record and listen my voice, so I asume it is able to use the microphone.
                      Could you recommend me something else?
                      • strawberry 3.141S
                        @pepemujica you could try to record on the pi https://stackoverflow.com/questions/28054731/capture-record-audio-input-in-raspberrypi
                          @strawberry-3.141 I can record with the mic when I use arecord -f cd -D plughw:0 -d 10 a.wav and after I can listen
                          • strawberry 3.141S
                            @pepemujica the error message says that your microphone is used by something else, so i guess you have to investigate on that
                            • daenickD
                              daenick
                              Hello, I´m havin problems with this:
                              alt text
                              Any idea?
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @daenick
                                @daenick what is your os version?
                                daenickD 2 Replies Last reply
                                • daenickD
                                  daenick @strawberry 3.141
                                  @strawberry-3.141 2017-03-02-raspbian-jessie
                                  • strawberry 3.141S
                                    @daenick can you update your system and try again? sudo apt-get update ; sudo apt-get upgrade
                                    • daenickD
                                      Yes, that was the first thind I do, but doesn´t works…
                                      Mysteriously after of the installation of MMM-mail could continue
                                      • strawberry 3.141S
                                        @daenick so it is installed now?
                                        • daenickD
                                          daenick
                                          No, now I get this:
                                          alt text
                                          • strawberry 3.141S
                                            @daenick looks like you executed the installer with sudo
                                            daenickD 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
