    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @pepemujica
      @pepemujica ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
      Error opening audio device plughw:1 for capture: No such file or directory
      FATAL: “continuous.c”, line 245: Failed to open audio device
        pepemujica @strawberry 3.141
        @strawberry-3.141 So how can I fin this?
          @pepemujica cat /proc/asound/cards
            @strawberry-3.141 said in MMM-voice:
            What should I do with this? Sorry for my bad linux usage
            0_1490896262887_upload-034fd73c-bcbe-4fbc-a037-de9eca9c7bfe
              @pepemujica if this soundcard is your microphone then put microphone: 0 in your config
                @strawberry-3.141 I’ve already tryed that, and got the same result:
                First “Initialising”, after a few seconds “ERROR” and under the microphone “undefined”
                Error.log
                0_1490903332620_upload-9de8f59a-a8e3-4fa3-a056-a66c55142af6
                debug.log
                INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
                Error opening audio device plughw:0 for capture: Device or resource busy
                  @pepemujica the pi is nit able to use your microphone, can you test it with another one?
                    @strawberry-3.141 Actually, I’ve tried whith an “Online Mic Tester” and could record and listen my voice, so I asume it is able to use the microphone.
                    Could you recommend me something else?
                      @pepemujica you could try to record on the pi https://stackoverflow.com/questions/28054731/capture-record-audio-input-in-raspberrypi
                        @strawberry-3.141 I can record with the mic when I use arecord -f cd -D plughw:0 -d 10 a.wav and after I can listen
                          @pepemujica the error message says that your microphone is used by something else, so i guess you have to investigate on that
                          • daenickD Offline
                            daenick
                            Hello, I´m havin problems with this:
                            alt text
                            Any idea?
                              strawberry 3.141 Project Sponsor Module Developer @daenick
                              @daenick what is your os version?
                              daenickD 2 Replies Last reply Reply Quote 0
                              • daenickD Offline
                                daenick @strawberry 3.141
                                @strawberry-3.141 2017-03-02-raspbian-jessie
                                  @daenick can you update your system and try again? sudo apt-get update ; sudo apt-get upgrade
                                  • daenickD Offline
                                    Yes, that was the first thind I do, but doesn´t works…
                                    Mysteriously after of the installation of MMM-mail could continue
                                      @daenick so it is installed now?
                                      • daenickD Offline
                                        daenick
                                        No, now I get this:
                                        alt text
                                          @daenick looks like you executed the installer with sudo
                                          daenickD 1 Reply Last reply Reply Quote 0
                                          • daenickD Offline
                                            @strawberry-3.141 can try again without restart everything?
                                            By the way, you are so friendly. Thanks!
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
