    MMM-GQuotes
    62 Posts 5 Posters 68.2k Views 6 Watching
      pauabaer
      hey @cowboysdude thank you for this special module. looks like i wanted it!
      one thing you could change: the url
      http://www.zitate-online.de/zitatdestages.xml
      instead of
      http://www.zitate-online.de/neustezitate.xml
      the first one should change every day.
      again. Thank you very much!!
      • cowboysdudeC
        cowboysdude Module Developer @pauabaer
        • FistandantilusF
          Fistandantilus
          thank you very much for your effort. I have just tested your module. The module standalone is working fine but when I load other modules as well some do not work anymore:
          MMM-FHEM
          newsfeed
          As these two modules follow the GQuotes it is also possible that every module which follows GQuotes will fail. Can you please have a look into that issue?
          Thx F.
            pauabaer
            Hi guys…i noticed the same issue. @cowboysdude can you look into that? perhaps you have an idea why this is happening.
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @pauabaer
              @pauabaer @Fistandantilus do you get any errors in the terminal or electron console?
              • FistandantilusF
                Fistandantilus
                I didn´t see any.
                • cowboysdudeC
                  I believe I found the issue…
                  Do a git pull to update ;)
                  • FistandantilusF
                    Fistandantilus
                    Unfortunatelly it is not yet working - same issue.
                    • cowboysdudeC
                      Well I actually posted the ‘do a git pull’ then I went and fixed it… it’s working here for me.
                      Try the git pull again … I have the module running with other modules and even in the same module positions without issue.
                      • FistandantilusF
                        Fistandantilus
                        Latest update I have installed :(
                        pi@Magic_Mirror:~/MagicMirror/modules/MMM-GQuotes $ git pull
                        Already up-to-date.
                        • cowboysdudeC
                          These are modules listed before and after in the config running in a few different positions…
                          commit 3d669a5a4533406e38c98b39fccc0eeb52b608a8
                          • cowboysdudeC
                            cowboysdude Module Developer @Fistandantilus
                            @Fistandantilus Do you have teamviewer installed?
                            • FistandantilusF
                              Fistandantilus
                              have sent you a chat message…
                                pauabaer
                                @cowboysdude many thanks to you. that is my lovely module. the mirror makes me smart now ;)
                                • cowboysdudeC
                                  @pauabaer You’re welcome!
                                    pauabaer
                                    hi @cowboysdude i realized a new issue.
                                    when you look at this page:
                                    there you have on the one hand the link for the specific quote. and under this one, the whole quote. It seems that your module only shows the “link-text” instead of everything.
                                    do you know what i mean?
                                    • cowboysdudeC
                                      @pauabaer I updated it the best it’s going to be for now.
                                      I am working on a module that supports both English and German so this one will be deprecated soon.
                                      All these things will be worked out in the new one.
                                        pauabaer
                                        thanks @cowboysdude. works fine now. keep you in touch if i recognize anything.
                                        • Mykle1M
                                          @cowboysdude said in MMM-GQuotes:
                                          I think it’s perfect the way it is. I can appreciate all the time and effort you’ve put into it. I can’t wait to see all the other marvelous things you’ve got in store for us. If there is anything I can do for you, just let me know.
                                            pauabaer
                                            @cowboysdude I love your module! :D
                                            Do you know at which time the quote is getting updated?
                                            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                                            • 1 / 4
