    MMM-GQuotes
    62 Posts 5 Posters 67.0k Views 6 Watching
    • cowboysdudeC Offline
      Well I actually posted the ‘do a git pull’ then I went and fixed it… it’s working here for me.
      Try the git pull again … I have the module running with other modules and even in the same module positions without issue.
      • FistandantilusF Offline
        Fistandantilus
        Latest update I have installed :(
        pi@Magic_Mirror:~/MagicMirror/modules/MMM-GQuotes $ git pull
        Already up-to-date.
          These are modules listed before and after in the config running in a few different positions…
          commit 3d669a5a4533406e38c98b39fccc0eeb52b608a8
            cowboysdude Module Developer @Fistandantilus
            @Fistandantilus Do you have teamviewer installed?
              Fistandantilus
              have sent you a chat message…
                pauabaer
                @cowboysdude many thanks to you. that is my lovely module. the mirror makes me smart now ;)
                  cowboysdude Module Developer @pauabaer
                  @pauabaer You’re welcome!
                    pauabaer
                    hi @cowboysdude i realized a new issue.
                    when you look at this page:
                    http://www.zitate-online.de/zitatdestages.xml
                    there you have on the one hand the link for the specific quote. and under this one, the whole quote. It seems that your module only shows the “link-text” instead of everything.
                    do you know what i mean?
                      @pauabaer I updated it the best it’s going to be for now.
                      I am working on a module that supports both English and German so this one will be deprecated soon.
                      All these things will be worked out in the new one.
                        pauabaer
                        thanks @cowboysdude. works fine now. keep you in touch if i recognize anything.
                          @cowboysdude said in MMM-GQuotes:
                          I think it’s perfect the way it is. I can appreciate all the time and effort you’ve put into it. I can’t wait to see all the other marvelous things you’ve got in store for us. If there is anything I can do for you, just let me know.
                            pauabaer
                            @cowboysdude I love your module! :D
                            Do you know at which time the quote is getting updated?
                            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                              @pauabaer soon. Very soon
                                pauabaer
                                I mean the qoute itself. Not the module :D
                                At the homepage it is 2 am.
                                  @pauabaer Well it will be working perfectly. I have one change to make and I’ll try to do it tonight…
                                    Mykle1 Project Sponsor Module Developer @pauabaer
                                    @pauabaer said in MMM-GQuotes:
                                    I’m just curious. Have you unvoted any of the posts regarding the work that @cowboysdude has been doing for you?
                                      Fistandantilus
                                      Hi cowboysdude,
                                      regrading the problem of not showing other modules I have done some further investigation running the mirror in dev mode. Attached there are some “screenshots” of errors appearing if I enable GQuotes. The Radio errors I will address to the radio module owner. As this appears also with disabled GQuotes. But the uncaught type error seems to give some hint?
                                      regards,
                                      F.
                                        Delete the entire directory MMM-GQuotes and reinstall.
                                          pauabaer @Mykle1
                                          @Mykle1 said in MMM-GQuotes:
                                          Of course not! Not on purpose. I am glad about @cowboysdudes work he is doing for me/us!! I believe he knows that.
                                            Fistandantilus
                                            @cowboysdude: same result - same error :(
                                            • 2 / 4
