    MMM-GQuotes
    62 Posts 5 Posters 68.8k Views 6 Watching
    • cowboysdudeC
      cowboysdude Module Developer @pauabaer
      @pauabaer Well it will be working perfectly. I have one change to make and I’ll try to do it tonight…
      Reply Quote 2
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @pauabaer
        @pauabaer said in MMM-GQuotes:
        Do you know at which time the quote is getting updated?
        I’m just curious. Have you unvoted any of the posts regarding the work that @cowboysdude has been doing for you?
        P 1 Reply Last reply
        • FistandantilusF
          Fistandantilus
          Hi cowboysdude,
          regrading the problem of not showing other modules I have done some further investigation running the mirror in dev mode. Attached there are some “screenshots” of errors appearing if I enable GQuotes. The Radio errors I will address to the radio module owner. As this appears also with disabled GQuotes. But the uncaught type error seems to give some hint?
          regards,
          F.
          • cowboysdudeC
            Delete the entire directory MMM-GQuotes and reinstall.
              pauabaer @Mykle1
              @Mykle1 said in MMM-GQuotes:
              Of course not! Not on purpose. I am glad about @cowboysdudes work he is doing for me/us!! I believe he knows that.
              Mykle1M 1 Reply Last reply
              • FistandantilusF
                Fistandantilus
                @cowboysdude: same result - same error :(
                • Mykle1M
                  No doubt.
                  • cowboysdudeC
                    cowboysdude Module Developer @Fistandantilus
                    @Fistandantilus Not sure what’s going on but it’s working everywhere else…
                    I get no errors or issues installing or running it.
                    How are you installing it?
                    ~MagicMirror/modules
                    type: git clone https://github.com/cowboysdude/MMM-GQuotes.git
                    ~MagicMirror/modules/MMM-GQuotes
                    type: npm install
                    make sure the config is correct. Not much to it really…
                    I just deleted mine and did the above mentioned actions and it works perfectly.
                    • Mykle1M
                      @cowboysdude said in MMM-GQuotes:
                      As did I.
                        pauabaer
                        As did I.
                        Me too.
                        • FistandantilusF
                          Fistandantilus
                          @cowboysdude: this is exactly the procedure I was following. Could it probably be caused by some shared ressources with another module?
                          The following modules are installed:
                          iFrame
                          MMM-FHEM
                          MMM-nasaastropic
                          MMM-SystemStats
                          MMM-iCloud-Client
                          MMM-RadioDe
                          MMM-GQuotes
                          F.
                          • FistandantilusF
                            Fistandantilus
                            Just tested with only GQuotes activated - screen stays black.
                            The following error shows up:
                            • cowboysdudeC
                              @Fistandantilus I can’t begin to imagine what the issue is. You’re the only one having it. Three of us have uninstalled and reinstalled the module and no one is getting any errors.
                              There is the module running with other modules and my developers window… no errors.
                              So unless it’s conflicting with another module I don’t have an answer for you.
                              • FistandantilusF
                                Fistandantilus
                                I´m using a RPi 2 B+ with the latest Jessie release. In addidion to MM2 I have installed midnight commander, x11vnc, cec-utils and xscreensaver.
                                Does the error give any hint what I could look at?
                                • cowboysdudeC
                                  No that error is a MM error… Cannot read property ‘appendChild’ of undefined and ‘getElementByClassName’ of null…
                                  It’s a getDom function error but like I said unless there’s a conflict of some type… do me a favor and open the ‘package.json’ file you have with GQuotes and tell me what the dependencies say…
                                  • FistandantilusF
                                    Fistandantilus
                                    "qs-iconv": "^1.0.4",
                                    "request": "^2.81.0",
                                    "xml2js": "^0.4.17"
                                    • cowboysdudeC
                                      OK that looks good… you have the newest version…
                                      What I would do is run GQuotes and disable all the other modules… and enable one at a time until you get a conflict… that may go a long way to helping figure out what’s wrong here.
                                      • FistandantilusF
                                        Fistandantilus
                                        That is what I already did. Just running GQuote itself without other modules also shows the mentioned error.
                                        • FistandantilusF
                                          Fistandantilus
                                          Just run a “npm outdated” with the following result:
                                          Package Current Wanted Latest Location
                                          electron 1.6.6 1.6.8 1.6.6 magicmirror
                                          grunt-markdownlint 1.0.33 1.0.37 1.0.37 magicmirror
                                          iconv-lite 0.4.16 0.4.17 0.4.17 magicmirror
                                          • cowboysdudeC
                                            @Fistandantilus said in MMM-GQuotes:
                                            qs-iconv
                                            Yes but if you go into the MMM-GQuote dir and run “npm outdated” it returns nothing… soooooo that’s not the issue…
                                            iconv-lite only appears when you run it from the MagicMirror root dir…
                                            Which means GQuotes is using all the latest version of npm modules…
                                            This is my config:
                                            module: ‘MMM-GQuotes’,
                                            position: ‘top_left’,
                                            maxWidth: “100%”,
                                            header: “Zitat des Tages”,
                                            I cannot find anything wrong with the module that would cause that error.
                                            • 2 / 4
