    MMM-GQuotes
    62 Posts 5 Posters 68.2k Views 6 Watching
      pauabaer
      hi @cowboysdude i realized a new issue.
      when you look at this page:
      http://www.zitate-online.de/zitatdestages.xml
      there you have on the one hand the link for the specific quote. and under this one, the whole quote. It seems that your module only shows the “link-text” instead of everything.
      do you know what i mean?
      • cowboysdudeC
        cowboysdude Module Developer @pauabaer
        @pauabaer I updated it the best it’s going to be for now.
        I am working on a module that supports both English and German so this one will be deprecated soon.
        All these things will be worked out in the new one.
          pauabaer
          thanks @cowboysdude. works fine now. keep you in touch if i recognize anything.
          • Mykle1M
            @cowboysdude said in MMM-GQuotes:
            I think it’s perfect the way it is. I can appreciate all the time and effort you’ve put into it. I can’t wait to see all the other marvelous things you’ve got in store for us. If there is anything I can do for you, just let me know.
              pauabaer
              @cowboysdude I love your module! :D
              Do you know at which time the quote is getting updated?
              cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
              • cowboysdudeC
                @pauabaer soon. Very soon
                  pauabaer
                  I mean the qoute itself. Not the module :D
                  At the homepage it is 2 am.
                  • cowboysdudeC
                    @pauabaer Well it will be working perfectly. I have one change to make and I’ll try to do it tonight…
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @pauabaer
                      @pauabaer said in MMM-GQuotes:
                      I’m just curious. Have you unvoted any of the posts regarding the work that @cowboysdude has been doing for you?
                      • FistandantilusF
                        Fistandantilus
                        Hi cowboysdude,
                        regrading the problem of not showing other modules I have done some further investigation running the mirror in dev mode. Attached there are some “screenshots” of errors appearing if I enable GQuotes. The Radio errors I will address to the radio module owner. As this appears also with disabled GQuotes. But the uncaught type error seems to give some hint?
                        regards,
                        F.
                        • cowboysdudeC
                          Delete the entire directory MMM-GQuotes and reinstall.
                            pauabaer @Mykle1
                            @Mykle1 said in MMM-GQuotes:
                            Of course not! Not on purpose. I am glad about @cowboysdudes work he is doing for me/us!! I believe he knows that.
                            • FistandantilusF
                              Fistandantilus
                              @cowboysdude: same result - same error :(
                              • Mykle1M
                                No doubt.
                                • cowboysdudeC
                                  cowboysdude Module Developer @Fistandantilus
                                  @Fistandantilus Not sure what’s going on but it’s working everywhere else…
                                  I get no errors or issues installing or running it.
                                  How are you installing it?
                                  ~MagicMirror/modules
                                  type: git clone https://github.com/cowboysdude/MMM-GQuotes.git
                                  ~MagicMirror/modules/MMM-GQuotes
                                  type: npm install
                                  make sure the config is correct. Not much to it really…
                                  I just deleted mine and did the above mentioned actions and it works perfectly.
                                  • Mykle1M
                                    As did I.
                                      pauabaer
                                      As did I.
                                      Me too.
                                      • FistandantilusF
                                        Fistandantilus
                                        @cowboysdude: this is exactly the procedure I was following. Could it probably be caused by some shared ressources with another module?
                                        The following modules are installed:
                                        iFrame
                                        MMM-FHEM
                                        MMM-nasaastropic
                                        MMM-SystemStats
                                        MMM-iCloud-Client
                                        MMM-RadioDe
                                        MMM-GQuotes
                                        F.
                                        • FistandantilusF
                                          Fistandantilus
                                          Just tested with only GQuotes activated - screen stays black.
                                          The following error shows up:
                                          • cowboysdudeC
                                            @Fistandantilus I can’t begin to imagine what the issue is. You’re the only one having it. Three of us have uninstalled and reinstalled the module and no one is getting any errors.
                                            There is the module running with other modules and my developers window… no errors.
                                            So unless it’s conflicting with another module I don’t have an answer for you.
                                            • 2 / 4
