    MMM-Globe
    118 Posts 32 Posters 170.8k Views 37 Watching
    • E Offline
      Eunanibus Module Developer
      Awesome! How are the sizes for you?
        d3r
        That module looks sick. I’ll try it this evening.
        • cowboysdudeC Offline
          cowboysdude Module Developer @Eunanibus
          @Eunanibus The sizes may be an issue… even the xsmall is quite big. I’m thinking on some smaller mirrors it’s going to eat a ton of room ;)
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            can you give me your monitor dimensions so i can adjust?
              I have a 24" monitor rotated 90 degrees so the basically tipped up so length wise it’s up and down…
              max resolution for 24" monitor … 1920 x 1080 resolution
                d3r
                @Eunanibus Can you make it smaller. I am using x-small on my main mirror, an 15.6 laptop screen rotated 90 degrees but it’s not rendering. The module does render when I visit the website from my phone or my laptop.
                Aside from that, the module looks great.
                • E Offline
                  No problem. I’ll try and add improved rendering sizes this evening and release an update. What resolution are you using?
                    d3r
                    I’m using 768x1366
                    • bheplerB Offline
                      bhepler Module Developer
                      This module is awesome. I have it up & running at the office and it looks fantastic.
                      Question: I added a bunch of custom locations, which is great. But they don’t seem to be replacing the default locations. So I’m getting my locations and the ones that came pre-loaded. Is this by design?
                      • E Offline
                        @d3r Thanks for your feedback. I’ve made those adjustments and pushed the latest code. Give this a try and get back to me. The X-Small/Small/Medium sizes etc should show a sufficient difference between sizes now.
                        @bhepler
                        I’m really glad you’re enjoying it. If you could take a picture of your mirror with it in action, it would really be something (I don’t have a mirror of my own and it’s really motivational to see a picture of something I wrote on someone’s wall)
                        In response to your question - No, once you’ve entered custom locations, the default locations are not added.
                        As an example - Here is an example config entry:
                        alt text
                        And here is the resulting globe produced:
                        alt text
                        It’s a little odd you’re getting that behaviour, and I may need you to send me your config file so I can debug accordingly. Try pulling the latest version (1.1 just uploaded) and see if that helps. I may add a further config option to exlude/include default Locations as a specification.
                        Thanks everyone for the feedback.
                        bheplerB 1 Reply Last reply Reply Quote 1
                        • 11
                        • 12
                        • 1 / 12
