    MMM-Globe
    118 Posts 32 Posters 199.1k Views 37 Watching
    • E
      Eunanibus Module Developer
      I actually don’t have a Magic Mirror of my own, I’d love for anyone to install this and let me know how it runs for them. Any pictures would be great also, I’d love to see this in use on someone’s mirror ;)
      • cowboysdudeC
        It actually works quite well… I just changed the two examples of location you had in there…
        • E
          Awesome! How are the sizes for you?
            d3r
            That module looks sick. I’ll try it this evening.
            • cowboysdudeC
              cowboysdude Module Developer @Eunanibus
              @Eunanibus The sizes may be an issue… even the xsmall is quite big. I’m thinking on some smaller mirrors it’s going to eat a ton of room ;)
              E 1 Reply Last reply
              • E
                can you give me your monitor dimensions so i can adjust?
                • cowboysdudeC
                  I have a 24" monitor rotated 90 degrees so the basically tipped up so length wise it’s up and down…
                  max resolution for 24" monitor … 1920 x 1080 resolution
                    d3r
                    @Eunanibus Can you make it smaller. I am using x-small on my main mirror, an 15.6 laptop screen rotated 90 degrees but it’s not rendering. The module does render when I visit the website from my phone or my laptop.
                    Aside from that, the module looks great.
                    • E
                      No problem. I’ll try and add improved rendering sizes this evening and release an update. What resolution are you using?
                        d3r
                        I’m using 768x1366
                        • bheplerB
                          bhepler Module Developer
                          This module is awesome. I have it up & running at the office and it looks fantastic.
                          Question: I added a bunch of custom locations, which is great. But they don’t seem to be replacing the default locations. So I’m getting my locations and the ones that came pre-loaded. Is this by design?
                          • E
                            @d3r Thanks for your feedback. I’ve made those adjustments and pushed the latest code. Give this a try and get back to me. The X-Small/Small/Medium sizes etc should show a sufficient difference between sizes now.
                            @bhepler
                            I’m really glad you’re enjoying it. If you could take a picture of your mirror with it in action, it would really be something (I don’t have a mirror of my own and it’s really motivational to see a picture of something I wrote on someone’s wall)
                            In response to your question - No, once you’ve entered custom locations, the default locations are not added.
                            As an example - Here is an example config entry:
                            alt text
                            And here is the resulting globe produced:
                            alt text
                            It’s a little odd you’re getting that behaviour, and I may need you to send me your config file so I can debug accordingly. Try pulling the latest version (1.1 just uploaded) and see if that helps. I may add a further config option to exlude/include default Locations as a specification.
                            Thanks everyone for the feedback.
                            bheplerB 1 Reply Last reply
                            • E
                              Eunanibus Module Developer @cowboysdude
                              @cowboysdude
                              Made some size adjustments now. Can you give this a try?
                              • bheplerB
                                bhepler Module Developer @Eunanibus
                                @Eunanibus Whatever change you made solved most of my problem. Now when I add locations, only the locations I add are being labeled.
                                I’m still seeing a bunch of nameless pins all over the globe. I’m going to have to turn those off.
                                • E
                                  @bhepler - Glad that fixed it. The nameless pins are just there for aesthetic and appearance. If you want those removed, you can change the content of data.js to the following:
                                  data = []
                                  That should remove the nameless pins without needing to change or affect any of the remaining application.
                                  • bheplerB
                                    @Eunanibus That it did. Thank you.
                                    I’ll get it up on the mirror in the office today and send you a picture.
                                    • cowboysdudeC
                                      Fantastic job on the module @Eunanibus !
                                      • cowboysdudeC
                                        @Eunanibus said in MMM-Globe:
                                        @cowboysdude
                                        PERFECT! :) HUGE Thanks!
                                        • E
                                          @cowboysdude
                                          Great. Glad it’s working for you! Thanks for the early feedback. I’m not sure if I’ve posted this in the right place but I hope everyone sees it or gets to use it.
                                          • bheplerB
                                            Now this is curious… It works great on my Windows 10 box (Chrome or Firefox). It works great on my Ubuntu 16.04 box at work (Chrome or Firefox). It works fantastic in Chrome or Firefox no matter the platform.
                                            But when I run npm start it doesn’t render anything to the screen. This is on an Ubuntu 16.04 microPC. Fascinating.
                                            D 1 Reply Last reply
                                            • 1 / 6
