    MMM-Globe
    118 Posts 32 Posters 172.8k Views 37 Watching
      d3r
      That module looks sick. I’ll try it this evening.
      • cowboysdudeC Offline
        cowboysdude Module Developer @Eunanibus
        @Eunanibus The sizes may be an issue… even the xsmall is quite big. I’m thinking on some smaller mirrors it’s going to eat a ton of room ;)
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          Eunanibus Module Developer
          can you give me your monitor dimensions so i can adjust?
            I have a 24" monitor rotated 90 degrees so the basically tipped up so length wise it’s up and down…
            max resolution for 24" monitor … 1920 x 1080 resolution
              d3r
              @Eunanibus Can you make it smaller. I am using x-small on my main mirror, an 15.6 laptop screen rotated 90 degrees but it’s not rendering. The module does render when I visit the website from my phone or my laptop.
              Aside from that, the module looks great.
              • E Offline
                No problem. I’ll try and add improved rendering sizes this evening and release an update. What resolution are you using?
                  d3r
                  I’m using 768x1366
                  • bheplerB Offline
                    bhepler Module Developer
                    This module is awesome. I have it up & running at the office and it looks fantastic.
                    Question: I added a bunch of custom locations, which is great. But they don’t seem to be replacing the default locations. So I’m getting my locations and the ones that came pre-loaded. Is this by design?
                    • E Offline
                      @d3r Thanks for your feedback. I’ve made those adjustments and pushed the latest code. Give this a try and get back to me. The X-Small/Small/Medium sizes etc should show a sufficient difference between sizes now.
                      @bhepler
                      I’m really glad you’re enjoying it. If you could take a picture of your mirror with it in action, it would really be something (I don’t have a mirror of my own and it’s really motivational to see a picture of something I wrote on someone’s wall)
                      In response to your question - No, once you’ve entered custom locations, the default locations are not added.
                      As an example - Here is an example config entry:
                      alt text
                      And here is the resulting globe produced:
                      alt text
                      It’s a little odd you’re getting that behaviour, and I may need you to send me your config file so I can debug accordingly. Try pulling the latest version (1.1 just uploaded) and see if that helps. I may add a further config option to exlude/include default Locations as a specification.
                      Thanks everyone for the feedback.
                      bheplerB 1 Reply Last reply Reply Quote 1
                      • E Offline
                        Eunanibus Module Developer @cowboysdude
                        @cowboysdude
                        Made some size adjustments now. Can you give this a try?
                        • 11
                        • 12
                        • 1 / 12
