    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 159.2k Views 23 Watching
    • T Offline
      tosti007 Module Developer @Binog
      Hello @Binog,
      First of all kinda unfortunate that it doesn’t work. I have a vague idea of what might be wrong but will have to do a small test by myself. I will test it tomorrow and let you know once I have more info or fixed the problem :)
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        Blackmirror
        thanks for the modul,
        but when I start this module my magic mirror get blank.
             module: 'MMM-Buttons',
            minShortPressTime: 10,
                     buttons: [
                     pin: 10,
                     longPress: {
                              notification: "PROFILE_SWITCH",
                            payload: {action: "Radio_OFF"}},
                     shortPress: {
                            payload: {action: "Radio"}}},
                    pin: 11,
                    longPress: undefined,
                   shortPress: {
                      notification: "BUTTON_PRESSED"
                     //   payload: {action: "SHUTDOWN"}
            module: 'MMM-ProfileSwitcher',
            module: 'MMM-RadioDe',
            classes: 'Radio',
            position: 'bottom_left', // This can be any of the regions.
                                            // See 'Configuration options' for more$
                                            station: "hr3",
                                            // can be obtained in embed section of $
                                            api_key: 'XXX',
                                            //optional,
                                            height:"92", // in pixel
                                            width:"360", // in pixel
        • cowboysdudeC Offline
          @Blackmirror said in MMM-ProfileSwitcher, A Profile/User/Layout Switching Module:
          module: ‘MMM-ProfileSwitcher’,
          That part doesn’t look right to me…
          You don’t have anything set in the config options brackets… see the readme here
          https://github.com/tosti007/MMM-ProfileSwitcher
          At the bottom are the config options ;)
          • T Offline
            tosti007 Module Developer @Blackmirror
            @Blackmirror That’s because when the magicmirror starts it goes to the default profile, which in your case contains no modules. So you would have to either set the defaultClass value to "Radio" or change "Radio" to "default"
            @cowboysdude ty for answering aswell
            • T Offline
              @Binog Sorry for the late reply, unfortunately I wasn’t able to find any problems with the code you submitted. Could you maybe launch your mm in servermode (node serveronly) and check the your browser’s console for any errors?
                Blackmirror
                ‘default everyone’ has work
                But I can not start the MMM-Radio modul with profil-switch, but that was my idea.
                So, I switch to Profile Radio and the MMM-Radio module will work, all other module are default for everyone.
                Here the MMM-Button Module
                                    classes: 'default everyone',
                         buttons: [
                         pin: 10,
                         longPress: {
                                payload: {action: "default"}},
                         shortPress: {
                        pin: 11,
                       shortPress: {
                • T Offline
                  @Blackmirror try doing it like this:
                      longPress: {
                        notification: "CURRENT_PROFILE",
                        payload: "default"
                      shortPress: {
                        payload: "Radio"
                    Blackmirror
                    No, will not work. :-(
                      Blackmirror
                      Will work, I have the Current_profile not read. Thanks
                        Binog
                        @tosti007
                        The only error is located with to TouchNacigations:
                        The log says
                        Cannot GET /modules/MMM-TouchNavigations//MMM-TouchNavigations.js
                        Where does the double // comes from? (Between …Navigations and MMM-Touch…)
                        I don’t find it in the config of TouchNavigations…
                        Any ideas?
                          Binog
                          missed something:
                          undefined is not an object (evaluating ‘modules[i].name’)
                          I cannot really interpret the output of the console: here it is:
                            Binog
                            OK, this should be relevant:
                            If I press on one of my bottom “you” this is what comes up in the console:
                            [Error] TypeError: undefined is not an object (evaluating 'modules[i].name')
                            	(anonyme Funktion) (MMM-Modulebar.js:83)
                            this is at this line:
                            if (modules[i].name === data.module) {
                            and this is what the bottoms look like:
                            ```buttons: {
                            		"1": {
                            		     module: "MMM-MotionEye",
                            		     text: "door",
                            		     showUrl: "http://ip:8081/motioneye/1",
                            		     hideUrl: "http://ip:8081/motioneye/1/hide",
                                            "2": {
                            		    module: "MMM-Remote-Control",
                                                symbol: "refresh",
                                                showUrl: "http://ip:8080/remote?action=REFRESH",
                                            "3": {
                                                symbol: "globe",
                                                showUrl: "http://ip:8080/remote?action=UPDATE",
                                            "4": {
                                                module: "MMM-ProfileSwitcher",
                                                //Ignium: 1,
                                                //text: "me",
                                                //showUrl: "this.sendNotification('CURRENT_PROFILE', 'me');",
                                                img: "url.jpg",
                                                showUrl: "http://localhost:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&payload=%22me%22",
                                                 width: 30,
                            		     height: 40,
                            		     //profilename: "me",
                                            "5": {
                                                //text: "You",
                                                img: "url.jpg",
                            		    showUrl: "http://ip:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&payload=%22default%22",
                                                width: 30,
                            		    height: 40,
                            		    //profilename: "You",
                            of course, ip has a relevant IP-adress. Interestingly button 1-3 work, except for 4 and 5. Any one could help?
                            • T Offline
                              @Binog To be honest I have no clue why there would be an additional /, try pulling all the new updates from the magicmirror framework (perhaps it was a bug?). The config looks fine for me except the url looks a bit strange NOTIFICATION¬ification that part especially. Does it work when you go to the link manually?
                                Binog
                                so the Notification,.,. is a compiling-error of this board. as mentioned above or elsewhere it does look correct in the config file.
                                Actually I am a bit further, and ruled out some errors,.none the less I am not able to switch profiles!
                                If I press one of my - not working - bottoms, I get these errors:
                                konsole:
                                source-code:
                                  Binog @Blackmirror
                                  @Blackmirror
                                  Where to You let Current_profile been read?
                                    Blackmirror @Binog
                                    @Binog
                                    I understand your question not really.
                                    I send the current_profile with MMM-Buttons and use it with MMM-RadioDE,
                                    with
                                    classes: ‘Radio’
                                    under the module name
                                      paul.calladine
                                      My mirror is just about finished, I have the MMM-PIRSensor working and MMM-Buttons working which both allow me to wake/sleep the monitor working fine.
                                      However i’d like to use MMM-Buttons as a toggle switch to enable me to essentially enable or disable the PIR sensor module:
                                      i.e.
                                      Profile 1 - PIRSensor wakes and turns off the monitor as normal
                                      Profile 2 - PIRSensor doesn’t do anything on motion being detected and the screen stays off
                                      I was thinking of modifying the code to do this but does anyone know if this module will allow me to achieve the results? Essentially having two profiles the same but profile 1 includes the PIRSensor module?
                                      • jdfraserJ Offline
                                        jdfraser
                                        Hello and thanks for creating this module! I have experimenting with creating a photo frame and hope that your ProfileSwitcher will get me the rest of the way there.
                                        I am having an issue with MMM-ProfileSwitcher and using it with MMM-RandomBackground or MMM-RandomPhoto. I have tried some simple troubleshooting steps, but am not sure how to proceed further and hope you could help.
                                        I have simplified my config.js to try and eliminate other sources as being the issue. Currently I am experimenting using only the clock module, MMM-RandomBackground and MMM-ProfileSwitcher. I have 3 profiles ‘TestA’, ‘TestB’ and default. I ideally like to be able to show a random photo on my frame and alternate having overlays of weather / time / news / etc. based on the profile.
                                        My idea is to have a class that shows the random photo at a reduced opacity that can have some overlay infomation (clock, weather, news, etc.). And another class that only shows the photo at full opacity.
                                        The problem I have is that if my config.js has more than one entry for MMM-RandomBackground, it ignores more than the one entry. I am sure I have configured it correctly and have included my config.js below, but I only see a background photo for “TestA” Profile.
                                        			header: 'Profile',
                                        				defaultTime: 10000,
                                        				defaultClass: 'default',
                                        				everyoneClass: 'everyone',
                                        				useLockStrings: true,
                                        				leaveMessages: false,
                                        				enterMessages: false,
                                        				timers: {
                                        					// when TestA is selected swap to the defaultClass after the defaultTime
                                        					"TestA": {},
                                        				        // When TestB is selected swap to TestA after 20 seconds
                                        				        "TestB": {
                                        						profile: "TestA",
                                        					    //	time: 20 * 1000
                                        					"default": {
                                        						profile: "TestB"
                                        			module: 'alert',
                                        			displayTime: 10000
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			disabled: false,
                                        			classes: "TestA",
                                        			position: "bottom_left",
                                        				timeFormat: 12,
                                        				displaySeconds: false,
                                        				showPeriod: false,
                                        				clockBold: false,
                                        				dateFormat: "MMMM Do"
                                        			module: "clock",
                                        			disabled: false,
                                        			classes: "default",
                                        				timeFormat: 12,
                                        				showPeriod: false,
                                        				clockBold: false,
                                        			module: "clock",
                                        			disabled: false,
                                        			classes: "TestB",
                                        				timeFormat: 12,
                                        				showPeriod: false,
                                        				clockBold: false,
                                        			module : 'MMM-RandomBackground',
                                        			disabled: false,
                                        			classes: "TestA",
                                        			position : 'fullscreen_below', // Any region but this one makes the most sense
                                        			config : {
                                        				animationSpeed : 2000,
                                        				updateInterval : 50000,
                                        				opacity : 1
                                        			disabled: false,
                                        			classes: "TestB",
                                        			config : {
                                        				opacity : 0.5
                                        If you are able to offer any insight as to why this might be happening or further troubleshooting I could do, I would greatly appreciate it.
                                        *** Full disclosure ***
                                        I originally posted this help request under another topic, but thought there would be a better chance that I might get more timely help with my issue in this topic. Sorry for the cross-post. :)
                                          Cyberdyne
                                          Is it possible to include a BT detection to switch profiles? RPi3 has a build BT which is not used (at least in my configuration) by the MagicMirror. It would be great if personal stuff like the calender could be switched depending on the BT device (Smartphone, Smartwatch, Fitnesstracker, …) which is near by.
                                          I was searching for identification via BT on the RPi and this is what I have found so far:
                                          “…present/absent can be done with very little power consumption on rPi and iPhone. Install bluetooth dongle on rPi as: (sudo aptitude install bluetooth bluez-utils bluez-compat). Figure out mac of your phone device by making it searchable and then do (hcitool scan) on rPi. Then connect to your device (make sure its searchable) as: sudo bluez-simple-agent hci0 mac_of_your_device and say yes on both sides. Then sudo bluez-test-device trusted mac_of_your_device. Now they both “know” each other. Then do sudo hcitool name mac_of_your_device in your favourite script to figure out if the iphone is nearby. This will not create a connection - but just say hi to it. If it returns a name, phone is nearby. If it returns nothing - phone is not nearby or bluetooth is switched off. Compared to creating connections or other distance computation methods out there - this method conserves battery on both sides and keeps airwave pollution to a minimum.” (found here)
                                          and this would be even better with distance sensing:
                                          https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=47466
                                          F 1 Reply Last reply Reply Quote 1
                                          • F Offline
                                            fcornelius @Cyberdyne
                                            @cyberdyne I had the same idea two days ago and did some research on it. I also asked /r/smartmirrors for some advice on it and got pretty good tips. The bottom line is, if you want to have a solid, non hacky solution supporting both iOS/android go the other way round with the use of beacons.
                                            Thread is here
                                            • 4 / 5
