    MMM-MyCommute
    286 Posts 80 Posters 732.7k Views 77 Watching
      BlackTalon @Fonfon
      @Fonfon I agree that would make this Module perfect!
        j.e.f.f Project Sponsor Module Developer @Fonfon
        @Fonfon @BlackTalon I’ve made an update that adds this capability, plus a whole lot more:
        • added the config showSummary to toggle a brief route summary. For transit, this gives you the route names (bus, streetcar, subway numbers, etc).
        • added the config colorCodeTravelTime to colour the travel red, yellow or green depending on traffic conditions. Only works for mode : 'driving'.
        • added two configs moderateTimeThreshold and poorTimeThreshold to adjust the threshold for red (i.e.: poor) and yellow (i.e.: moderate) traffic. Defaults to 1.1 and 1.3 respectively for 10% and 30% time delays.
        • for destinations where mode : 'transit', you can specify an additional config transitMode to instruct which transit modes you would like Google to use when calculating your route. Can be bus, subway, train, tram, or rail. Multiple choices allowed, separated by the | character (e.g.: transitMode : 'bus|subway'). Specifying rail is equivalent to specifying subway|train|tram.
        • added more icons to support the various modes of transit.
        It’s still possible to use the old compact mode, by specifying showSummary : false. e.g.:
        J B 2 Replies Last reply Reply Quote 1
          Johnson22 @j.e.f.f
          @j.e.f.f This update is fantastic! Thank you very much!
          • joela85J
            joela85
            Do you need to do anything special with the google api key?
            I can’t get this module to show up on my MM. Doesn’t look like it is picking any info up through the API key.
              j.e.f.f Project Sponsor Module Developer @joela85
              @joela85 When you say nothing shows up, do you mean the module just doesn’t appear at all? Or you can get the module to show but the travel times never fill in (i.e.: you see the spinning circle forever?)
              Can you post your config? Hide your API key of course.
              • joela85J
                joela85
                The module doesn’t show up at all, looks like it doesn’t load the module. I’ll post config file when I get home tonight or tomorrow. Module doesn’t load even with standard commute config part.
                Not sure if it has something to do with my other modules (remote module maybe)
                  bhepler Module Developer
                  I saw the updates this morning at the office and updated. Looks great! Thanks for the work.
                  • joela85J
                    joela85
                    I re-installed the module and it works fine now.
                      @joela85 good to hear you got it working.!
                      • F
                        Fonfon
                        Very good job j.e.f.f !!! nice update ! thanks !
                          beck0r
                          Hey there,
                          very nice looking module! I only have a very little issue with my train icon.
                          When the MM loads for the first time I can see the train icon but only as long as the driving time is being retrieved from google, then it disappears…
                          Before
                          0_1495808995559_upload-478cdab7-c23e-423b-8599-00022c06b7ed
                          After
                          0_1495809045044_upload-5ca0c570-9c7e-48d2-ac3f-47ed05620364
                          I have already switched the order of the destinations to check that out, but it only concentrates on the train icon.
                          Can you support me on that?
                          Thank you Kind Regards
                            j.e.f.f Project Sponsor Module Developer @beck0r
                            @beck0r Sure. Can you provide your config? Hide your API key, of course.
                              beck0r @j.e.f.f
                              @j.e.f.f
                              Of course… here it comes
                                				module: 'MMM-MyCommute',
                                				position: 'top_left',
                                  					showHeader: true,
                                  					headerText: 'Verkehr',
                                 					apikey: '...',
                                  					origin: '...',
                                  					startTime: '05:00',
                                  					endTime: '17:00',
                                  					destinations: [
                                      						destination: '...',
                                     	 						label: 'Auto zur Arbeit',
                                      						mode: 'driving',
                                      						color: '#82E5AA'
                                      						destination: '...',
                                      						label: 'Fahrrad zur Arbeit',
                                      						mode: 'bicycling',
                              							color: '#FFB444'
                                      						destination: '...',
                                      						label: 'RMV zur Arbeit',
                                      						mode: 'transit'
                                @beck0r Can you try doing a git pull in your MMM-MyCommute directory and restarting your mirror? I think I found your issue – I didn’t have an icon definition for High-speed rail.
                                EDIT Maybe not… I need to add definitions for all sorts of possible transit vehicle types. Stay tuned…
                                EDIT OK fixed for real this time. I added definitions for all of the transit modes listed here: https://developers.google.com/maps/documentation/directions/intro#VehicleType
                                Note: You’ll see the tram icon while the route is loading, as that is the default icon used when no transitMode is specified. But you’ll see it change to the train icon after your travel times are retrieved.
                                  BlackTalon @j.e.f.f
                                  @j.e.f.f This is perfect! Thank you so much!
                                    beck0r
                                    once again for everybody with the same issue. It’s working now! Thumbs up for j.e.f.f, thank you!
                                    • joela85J
                                      joela85
                                      One more question. I want to make a route going via different roads, can that be done in this config file?
                                      For example:
                                      Destination: X
                                      Via: A1
                                      Destination: X
                                      Via: A2
                                      J 3 Replies Last reply Reply Quote -1
                                        @joela85 so the google API doesn’t allow that specifically, but there are a couple of ways we could accomplish something similar:
                                        1. I can have Google return alternative routes, and they can be listed out. No garantee you’re going to get any of the routes you’re interested, but they will be the fastest.
                                        2. you can provide a list of waypoints and Google will return your route passing through those specific places. So if you put specific landmark addresses that are on the highways you’re interested in then you would more or less get the result you’re looking for.
                                        Both of these options seem fairly straightforward to add so I might just do both :)
                                          @joela85 I added the first of the above two options. You can specify alternatives:true for any of your destinations to get alternative routes. showSummary must be set to true for this to work.
                                          Will be working on the second option soon.
                                            @joela85 I’ve added the second option too. You can now specify a waypoints parameter for any of the destinations to influence the route Google will find.
                                            • 14
                                            • 15
                                            • 1 / 15
