    MMM-MyCommute
    286 Posts 80 Posters 716.7k Views 77 Watching
    • joela85J Offline
      joela85
      I just went back into my config and noticed on one of the times I used a semicolon instead of the colon. I must have looked at that 20 times and not noticed it. Maybe just needed some fresh eyes on it. Hopefully that will sort it. I only have one instance of this module.
        j.e.f.f Project Sponsor Module Developer @joela85
        @joela85 ha! I should have thought to ask for your config. In any case, I’ve pushed an update that fixes the support for multiple instances of the module.
        Of note is that you now configure the header in the standard way instead using the “headerText” and “showHeader” configurations. I thought I needed to do it this way when showing and hiding, but it turned out not be the case. So if your config looked like this before:
              module: 'MMM-MyCommute',
              position: 'top_left',
              classes: 'default everyone',
                showHeader: true,
                headerText: 'Traffic',
        change it to this:
              header: 'Traffic',
        If you don’t want a header, then just omit it.
        Will be working on configs for limiting to Mon-Fri and windowing for individual destinations next.
          MMM-MyCommute has been updated with some new configuration options
          • You can now specify hideDays with a list of days during which the module is hidden. You specify an array of numbers, 0=Sunday, 6=Saturday. To hide it on weekends, for example, specify hideDays: [0,6].
          • startTime, endTime, and hideDays parameters are now available as options for each individual destination. It should be noted that these parameters are superseded by the same ones specified in the main config. That means that if the main config parameters cause the module to be hidden as a whole, none of the destinations will be listed, regardless of their window settings.
          Thanks for all your suggestions! This has evolved into a very robust module and I’ve learned quite a bit in the process.
          Enjoy!
          -Jeff
          B 1 Reply Last reply Reply Quote 5
            bhepler Module Developer @j.e.f.f
            @j.e.f.f said in MMM-MyCommute:
            Aha. Very nice. If you get the chance, please update the README with this information. It changed on me and I couldn’t figure it out for a while.
              Blackmirror @j.e.f.f
              @j.e.f.f Nice, I will test it at the weekend.
                alberttwong
                Why isn’t this in the master list of modules at https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules
                  j.e.f.f Project Sponsor Module Developer @alberttwong
                  @alberttwong There are many MANY modules that aren’t in that list… just browse the Modules section of this forum and you’ll find lots.
                  I’m assuming the “master” list needs to be maintained by the author of MagicMirror, while any of us can post to the forum.
                  Does anyone know if the “master” list is even maintained anymore, and how we get it updated with the missing modules?
                  • Y Offline
                    yawns Moderator
                    Just open the list, click on edit and add your modules to the list.
                    Amazing work with the commute module! Oh, I added the module developer badge to your profile
                      j.e.f.f Project Sponsor Module Developer @yawns
                      @yawns Thanks! I’ll add my modules to the list.
                      • L Offline
                        lucallmon
                        @j.e.f.f - loving the module. However, I’m trying to add a single trip with multiple stops and multiple methods of transportation. Here’s the situation:
                        I live in MD; I want to drive from my home to the nearest DC metro station, get on the metro to my work in downtown DC.
                        This uses driving first, then subway. The module sets a global ‘origin’ with multiple potential destinations. Essentially, how I see it, I need to change origins for each stop, thus, creating multiple module instances.
                        Is there a way to create multiple stops with differing origins?
                          j.e.f.f Project Sponsor Module Developer @lucallmon
                          @lucallmon the Google API supports waypoints, but I think all stops on the route need to be the same mode of transportation. I’m not even sure you can do what you want just using regular google maps.
                          I think using multiple instances is your only option here…
                          • brandongomezB Offline
                            brandongomez
                            Hi all. New to the forum and the world of magic mirror. It’s awesome! Came across this module and have been trying to implement but think I’m getting stuck on the API key.
                            When I go to Google, I have web and web service. I am assuming this is web and not web service. Then when I choose web, I get more options; Maps JavaScript API, Maps Embed API, Street View, Static Maps, Places API JavaScript Library. I believe it’s Maps JavaScript API. Can anyone confirm that?
                            The module is not coming up on my board so I think my API might be wrong? Any help is appreciated. Thanks!
                            Update: I re-installed the module and it now loads but just shows the locations with a red “Error” next to each of them. My code is posted below if that helps. It also isn’t showing the “Traffic” header which is odd.
                            Another Update: Working now! I found the log files and it was the API. Got that fixed and now it’s working. Only thing that isn’t working is the title. For some reason the header doesn’t show. Any ideas?
                                                    position: 'top_right',
                                                            showHeader: true,
                                                            apikey: 'xxxxxxxxx',
                                                            origin: '.........',
                                                            startTime: '00:00',
                                                            endTime: '23:59',
                                                            hideDays: [0,6],
                                                            destinations: [
        destination: '..........',
        label: 'Emerson Parkside Academy',
        mode: 'driving',
        color: '#82E5AA'
        destination: 'Yosemite, CA',
        label: 'Yosemite',
        mode: 'driving',
        color: '#82E5AA'
        destination: '1313 Disneyland Dr, Anaheim, CA 92802',
        label: 'Disneyland',
        mode: 'driving',
        color: '#82E5AA'
                              j.e.f.f Project Sponsor Module Developer @brandongomez
                              @brandongomez The header is not configured that way anymore. Use the standard way, like so:
                                  header: 'Traffic',      //-------- here
                              otherwise, glad to hear you got it working.
                              -Jeff
                              brandongomezB L 2 Replies Last reply Reply Quote 0
                                brandongomez @j.e.f.f
                                @j.e.f.f Awesome, thanks for the quick reply and help!
                                • L Offline
                                  Looking @j.e.f.f
                                  Question. I have posted the above config in my config.js file but MM does not showing anything additional regarding TRAFFIC.
                                  J L 2 Replies Last reply Reply Quote 0
                                    j.e.f.f Project Sponsor Module Developer @Looking
                                    @Looking not sure I’m following… can you post your confit here? Hide your API key.
                                    • L Offline
                                      Looking @Looking
                                      Here is what I pasted… I am sure it is something real goofy. I did get an API KEY from Google. Maybe there was addition code I needed to put else where. This is my first time project with MM. Really cool.
                                      CODE:
                                      module: ‘MMM-MyCommute’,
                                      header: ‘Trafic’,
                                      position: ‘top_right’,
                                      showHeader: true,
                                      //------ headerText: ‘Traffic’,
                                      apikey: ‘PUT IN GOOGLE API’,
                                      origin: ‘PUT MY ADDRESS. 123 ST, TOWN, ST ZIPCODE’,
                                      startTime: ‘00:00’,
                                      endTime: ‘23:59’,
                                      hideDays: [0,6],
                                      destinations: [
                                      destination: ‘PUT IN WORK ADDRESS’,
                                      label: ‘Emerson Parkside Academy’,
                                      mode: ‘driving’,
                                      color: ‘#82E5AA’
                                      Your help would be greatly appreciated. Thank you!
                                      • L Offline
                                        Looking @j.e.f.f
                                        Hey j.e.f.f,
                                        CODE:
                                        	header: 'Trafic',
                                        		showHeader: true,
                                        		//------ headerText: 'Traffic',
                                        		apikey: 'PUT IN GOOGLE API',
                                        		origin: 'PUT MY ADDRESS. 123 ST, TOWN, ST ZIPCODE',
                                        		startTime: '00:00',
                                        		endTime: '23:59',
                                        		hideDays: [0,6],
                                        		destinations: [
                                        			destination: 'PUT IN WORK ADDRESS',
                                        			mode: 'driving',
                                        			color: '#82E5AA'
                                        • L Offline
                                          Looking @Looking
                                          @Looking
                                          Should I have something within the MODULES directory to correspond to this cool MMM-MyCommute module?
                                          • L Offline
                                            Looking @Looking
                                            Hey there j.e.f.f.
                                            I figured out that I missed the whole part about installing the actual MMM-MyCommute module, https://github.com/jclarke0000/MMM-MyCommute . I am letting it run in MM but under the header TRAFFIC on MM it just says Loading… I rechecked my API key and made sure I did not mistype. Any thoughts?
                                            • 14
                                            • 15
                                            • 3 / 15
