    Screen capture on a Raspberry Pi
    tips and tricks
    5 Posts 5 Posters 4.5k Views 4 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      I had to look this one up myself today. For those of you wanting to do a screen capture on your MM2 on the raspberry pi, you can install the scrot package (sudo apt-get install scrot) and use it to do that. Simply issuing the scrot command from a terminal will take a screen capture of what’s being displayed and saves a PNG file in the current folder. You can also tell it where to put the file by issuing scrot /path/to/file.png - note you must put in a file name as well for this to work.
      Now obviously you can’t do that when MM2 is running, but you can do it through an SSH login to the raspberry pi. You will have to tell it which display to use: DISPLAY=:0 scrot /path/to/file.png.
      Because I develop from a remote machine (through SSH), the above command comes in handy because I can drop the file onto a shared folder and access it from my remote system.
      Using scrot beats taking a picture of the screen whenever you want to show something on your MM installation.
      • MichMichM Offline
        MichMich
        Thanks! Good to know. I usually use VNC, but this could be helpful too.
          devinpaul
          If you are interested in using screen capture you can try techsmith.
            steveray
            Thanks for the information.
            • delightedCrowD Offline
              delightedCrow Project Sponsor Module Developer
              Really helpful, thanks!
