    Magic Mirror on the Raspberry Pi 1, agonizingly difficult
    Scheduled Pinned Locked Moved Unsolved Tutorials
    magic mirrorraspberry piraspberry pi 1problems running mmserveronly
    33 Posts 8 Posters 28.0k Views 7 Watching
      @cowboysdude said in Magic Mirror on the Raspberry Pi 1, agonizingly difficult:
      IF you have a working config before you make ANY changes to it copy it to config.bak that way you’ll always have a GOOD working config file…
      This is excellent advice!
        MMRPi1 @cowboysdude
        @cowboysdude Thanks.
        This is the situation:
        The default config file is working (I have it backed up) though when I run it in server only the clock and weather work fine, but all the other modules say “Loading…”.
        I did try to customise it, but got the “No config file”, so either I have syntax errors or the sources aren’t right…
        Talking of, does anyone know of a list of compatible news feeds and the like?
        Thanks again
        ? 1 Reply Last reply Reply Quote 1
          A Former User @MMRPi1
          @MMRPi1
          Can you show your config.js here? It makes easier.
          If you got “no config file” however you have a confidence for config.js existence, you might make some syntax error in your config.js.
          you can find newsfeed rss in most news sites.
          If some site has links of “RSS”(or small orange squared antenna icon), you can use that url to your newsfeed.
          By example, If you want to get news from “The Washington Post”, google “washington post rss”. Then the result pages direct you to WP rss page. get a link what you want, apply that to your news-feed module config.
          Most of the RSS could be compatible with that module. Even RSS of personal blogs also.
          Some browsers(Firefox, IE7…) support finding RSS on current page. You can see RSS mark in addressbar if current page has valid RSS link.
          You can check the reference. (I doubt there are some missing links.)
          https://www.repeatserver.com/RSSFeedList.aspx
          http://www.uen.org/feeds/lists.shtml
            MMRPi1
            Good news!
            The config file is (mostly) working (it needed a reboot) and I’ll configure it until I’m satisfied at which point I need to figure out how to keep it fullscreen, disable screen timeout and do the autostart and all that…
            In the meantime, thanks to everyone for their help :-D
            • cowboysdudeC Offline
              cowboysdude Module Developer @MMRPi1
              @MMRPi1 said in Magic Mirror on the Raspberry Pi 1, agonizingly difficult:
              Good news!
              You’re very welcome. :) Enjoy!
                MMRPi1
                Now the software is working I have a few more questions:
                (Btw I’m running MM in serveronly mode in Chromium.)
                1. How do I make MM auto run when the Pi turns on, disable screensaver and make it fullscreen?
                2. Should I be concerned that the RPi gets quite hot in operation, especially as it will be in a frame and in constant operation.
                3. Is it advisable to turn the raspberry pi off (and turn off the magic mirror) by switching it off at the mains, and if not how would I turn it off and on?
                ? Mykle1M 2 Replies Last reply Reply Quote 0
                  MMRPi1
                  Also, how do you rotate the screen??
                    @MMRPi1
                    For autostart, read this
                    Don’t worry about heat unless overclocking. However you can add small pan and ventilatoin holes on your frame.
                    You can use cron for scheduly shutdown or reboot. But you cannot turn on RPI automatically. You need additional hardware for that. You can consider timer switch or outlet.
                    For display rotating, edit /boot/config.txt
                    Add
                    display_rotate=1
                      Mykle1 Project Sponsor Module Developer @MMRPi1
                      https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
                        First, shutdown the Pi correctly. Once you’ve shutdown the Pi correctly you can pull the power cord, OR you can install some sort of power switch.
                        In my case, I simply used a mini power strip inside the mirror itself. Once I’ve shut down my Pi correctly, I simply reach under my mirror and hit the power switch on the mini power strip. This also powers down the fan that I have sitting on the Pi. When you’re ready to start your mirror again, you simply hit the power switch on the mini power strip again and everything comes back on.
                          ROMSY
                            MMRPi1
                            Hi again…
                            Everything works fine but I can’t get the mirror to auto run (in server only mode) at boot.
                            Any help would be appreciated…
                            (BTW I tried configuring the LXDE and boot files and all that)
                              bhepler Module Developer @MMRPi1
                              @MMRPi1 Did you try the pm2 route from the Auto Starting Magic Mirror? @Sean gave you the link a few days ago.
                              In your case, you’ll want to change the mm.sh script to start in server-only mode and then launch your web browser. If you really want to bulletproof your installation, you can create a separate script for the mirror in server-only mode and another for keeping the browser up & pointed at the correct location. Let PM2 manage both as separate processes.
                                MMRPi1 @bhepler
                                @bhepler Thanks, but since I’m really clueless I’m not quite sure what to do…
                                The contents of mm.sh
                                DISPLAY=:0 npm start
                                node serveronly
                                chromium-browser --noerrdialogs --disable-session-crashed-bubble -incognito --kiosk http://localhost:8080
                                I’'ve also got the following at the end of the LXDE autostart file
                                @pm2 start mm.sh
                                BTW: when I run pm2 start mm.sh from the terminal the mirror starts up just fine, so I don’t know why it doesn’t autostart properly…
                                  No problem. It’s confusing at first for just about everybody.
                                  node serveronly
                                  Your script is attempting to start the Magic Mirror twice. DISPLAY=:0 npm start will start the mirror via electron. That line would normally blank the Pi’s screen, start up the MM process and display the interface. You probably want to remove this line.
                                  The line node serveronly starts up the MM process as well, but only to provide the interface to web browsers. And your final line opens the web browser.
                                  So. Try deleting the DISPLAY=:0 npm start line and then testing your script.
                                  cd ~
                                  ./mm.sh
                                  That should start the MM process and open up your web browser to the interface. Let us know how it goes!
                                  @pm2 start mm.sh
                                  Yeah, delete that line.
                                  Oh. Easy enough to fix. Do just what you said, run pm2 start mm.sh. Once the browser is up, switch to the terminal on the pi and tell PM2 to save the current state. pm2 save. One you do that, PM2 should start with the pi and then start the MM process and your browser.
                                  Edited to add: Did you run the pm2 startup and then copy & paste the command it gave as per the instructions?
                                    MMRPi1
                                    It worked!!!
                                    Turns out I didn’t run pm2 startup (feeling a bit stupid)
                                    Thank you so much to everyone, I couldn’t have done it without you XD
                                      MMRPi1
                                      Hi again…
                                      My mirror seems to be a bit sluggish… (I installed a third party stock ticker)
                                      Apart from decreasing animation time is there any way to improve this??
                                      • T Offline
                                        teitlebot
                                        for some reason im having the same problem and it wont load the browser from the shell script. not sure why
