    The 32" Inch Mirror
    60 Posts 13 Posters 72.4k Views 16 Watching
    • L Offline
      l8kerjuan @strawberry 3.141
      @strawberry-3.141 just ordered my usb mic. will be in touch cause im sure im gonna need some help with voice control… super pumped…
      strawberry 3.141S cowboysdudeC 2 Replies Last reply Reply Quote 1
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @l8kerjuan
        @l8kerjuan did you read this first https://github.com/fewieden/MMM-voice#information?
        • L Offline
          @strawberry-3.141 will take a look. thanks
          • cowboysdudeC Offline
            cowboysdude Module Developer @l8kerjuan
            @l8kerjuan said in The 32" Inch Mirror:
            It installs quite easily! You’ll be surprised :)
              Progress on the 32" SO far I have the hardware working quite well. It’s quite fast… Yeah I know this is an RPI project but I wanted it for more…
              Touchscreen is working awesomely!!
              Here’s a sneak peek… [the red box around the humidity is like an alert …it flashes if over a certain number as does the temp]… The extended forecast on the right actually rotates through 7 days of upcoming weather…
              Mykle1M S 2 Replies Last reply Reply Quote 2
                @cowboysdude
                This makes me want to call you names, like . . .
                GURU or GENIUS
                  shashank @cowboysdude
                  @cowboysdude
                  hi, May i know the type of touch screen you are using and where can i get one for my project
                    cowboysdude Module Developer @shashank
                    @shashank said in The 32" Inch Mirror:
                    @cowboysdude
                    I ordered mine from here:
                    https://cjtouch.en.alibaba.com/?spm=a2700.8443308.0.0.Vezj8j
                    Just a 6 pts of touch 32" IR Frame. They are nice people. If you have questions they will answer you :)
                      @cowboysdude
                      Thanks for your reply, may i know have you purchased with or without mirror
                        @cowboysdude
                        OH I’m sorry… This will not be a mirror. It’s just a touch screen with glass and it’s more like a ‘command center’ for my house. BUT I used clear glass on top of the TV then the touch frame on top of the glass. Can’t be sure if a mirror would give the same response because the actual thickness of a real glass mirror is much more than a regular piece of glass.
                        • 1 / 6
