Frameless Illuminated Motion Sensitive SmartMirror
framelessilluminatedlightmirrormotion-sensorpir
11 Posts 5 Posters 13.0k Views 4 Watching
    pascal456
    Hey
    I want to show you my smartmirror powered by Magic Mirror.
    I made a Video to show it to you in action.
    Video
    Let me know what you think!
    Some more Details:
    front of mirror turned on picture 1
    front of mirror turned on picture 2
    The mirror’s measurements are 80cm x 55cm. While the ones of the frame are 70cm x 45cm. So that the mirror glas juts out the frame by 5cm on each side. It has a thickness of 6mm.
    I got the mirror from a glazier around my town. Unfortunately it is a german contact. On the delivery note it was mentioned as ESG Mirastar-Spionspiegel (Spionspiegel = “two way mirror”).
    I built the “frame” by myself. Actually it is rather a box than a frame. When standing in front of the mirror you won’t be able to see it.
    early stage mirror frame front
    early stage mirror frame back
    I attached the 21" monitor to the frame.
    The frame is attached to the mirror.
    I used a special double-sided tape to fix the mirror to the frame.
    attaching monitor 1
    In the picture below you can see that the tape is transparent.
    I chose that one, because if it was a white one it could reflect light and it may be seen when you stand in front of the mirror. Therefore the box is also painted black.
    attaching monitor 2
    B 1 Reply Last reply Jul 7, 2017, 12:14 AM Reply Quote 5
      bhepler Module Developer @pascal456
      @pascal456 That looks awesome! Do you have a build log? Or pictures of the back? What are you using to attach the mirror to the monitor?
        pascal456
        Hi and thanks!!
        I actually do not have something like a build log. But I will post some more pics here.
        B 1 Reply Last reply Jul 10, 2017, 12:19 PM Reply Quote 0
          @pascal456 Thank you. I find your build process intriguing.
          Do you have any concerns about the adhesion of the glass and the tape? I suppose I don’t know much about frameless mirrors. I have no idea how commercial mirrors are constructed.
          • V Offline
            vincem92
            Very nice! I’m also a bit concerned about how well the tape would hold the glass. Aren’t you afraid that it might fall at some point? Or does it seam really solid?
              pascal456
              After I put the mirror glas onto the frame, I turned it around, took it by the frame and shook it as hard as it was possible. Nothing happened :D
              Like you can see in the video in the product description (unfortunately it is in german) of the tape that i used, they fixed more than a 10kg weight to a wall. Actually the mirror glas has a relatively minor weight of about 6.5kg ;) AND I used about 20 times as much of the tape, like they did in the video.
              I was more worried about the screws that i used to fix the mounting of the frame. :D
                Very nicely done!
                P 1 Reply Last reply Jul 11, 2017, 11:47 AM Reply Quote 1
                  PtrBld Module Developer
                  Hi @pascal456,
                  this looks really great! Could you tell me where you got your mirror from?
                  P 1 Reply Last reply Jul 11, 2017, 11:50 AM Reply Quote 1
                    pascal456 @cowboysdude
                    @cowboysdude Thank You!
                      pascal456 @PtrBld
                      @PtrBld Hi and thanks!
                      I will update the original post regarding that information!
                      P 1 Reply Last reply Jul 11, 2017, 2:10 PM Reply Quote 0
