    Frameless Illuminated Motion Sensitive SmartMirror
    framelessilluminatedlightmirrormotion-sensorpir
    11 Posts 5 Posters 16.2k Views 4 Watching
      bhepler Module Developer @pascal456
      @pascal456 That looks awesome! Do you have a build log? Or pictures of the back? What are you using to attach the mirror to the monitor?
      Reply Quote 3
      • pascal456P
        pascal456
        Hi and thanks!!
        I actually do not have something like a build log. But I will post some more pics here.
        B 1 Reply Last reply
          @pascal456 Thank you. I find your build process intriguing.
          Do you have any concerns about the adhesion of the glass and the tape? I suppose I don’t know much about frameless mirrors. I have no idea how commercial mirrors are constructed.
          • V
            vincem92
            Very nice! I’m also a bit concerned about how well the tape would hold the glass. Aren’t you afraid that it might fall at some point? Or does it seam really solid?
            • pascal456P
              pascal456
              After I put the mirror glas onto the frame, I turned it around, took it by the frame and shook it as hard as it was possible. Nothing happened :D
              Like you can see in the video in the product description (unfortunately it is in german) of the tape that i used, they fixed more than a 10kg weight to a wall. Actually the mirror glas has a relatively minor weight of about 6.5kg ;) AND I used about 20 times as much of the tape, like they did in the video.
              I was more worried about the screws that i used to fix the mounting of the frame. :D
              Reply Quote 2
              • cowboysdudeC
                Very nicely done!
                pascal456P 1 Reply Last reply
                  PtrBld Module Developer
                  Hi @pascal456,
                  this looks really great! Could you tell me where you got your mirror from?
                  • pascal456P
                    pascal456 @cowboysdude
                    @cowboysdude Thank You!
                    • pascal456P
                      pascal456 @PtrBld
                      @PtrBld Hi and thanks!
                      I will update the original post regarding that information!
                        PtrBld Module Developer @pascal456
                        @pascal456 Thank you!
