MMM-SL how to trigger update?
8 Posts 3 Posters 3.6k Views 3 Watching
    Baxer
    On the Module MMM-SL’s github it says
    “updateNotification The notification to listen for. If received then will trigger update of departure times.”
    and
    “I recommend that you don’t update it with a timer, otherwise you will see that after a while you will get an error message instead. The recommended way is to trigger the update either with a button or similiar.”
    but i have no idea how to actually trigger the update and i havent found any guidance on how to do it on the modules github,
    if anyone got the answer it would be to great help
    M 1 Reply Last reply Jul 19, 2017, 11:31 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Baxer
      @Baxer
      I don’t know if this will help you but it’s worth looking into I think.
      https://forum.magicmirror.builders/topic/1575/mmm-buttons-connect-multiple-buttons-to-send-configurable-notifications
      Perhaps @Jopyth can be of some help in that topic
      B 1 Reply Last reply Jul 19, 2017, 11:57 PM Reply Quote 1
        Baxer @Mykle1
        @Mykle1 thanks for the tips unfortunately i dont have a button to test this with.
        J 1 Reply Last reply Jul 20, 2017, 8:05 AM Reply Quote 0
          Jopyth Moderator @Baxer
          @Mykle1 Thanks for mentioning. :)
          @Baxer If you do not have a button, you could use a custom URL together with the Remote-Control (you need to install and configure the module though, do not forget to adapt your IP whitelist). Then you can send a notification request via an URL by accessing a custom URL.
          In your case the URL would probably look like this:
          http://192.168.xxx.xxx:8080/remote?notification=UPDATE_SL&action=NOTIFICATION
          Or you could change the module to use a timer, but I assume the author of the module had a good reason for not doing that.
          M B 3 Replies Last reply Jul 20, 2017, 11:12 AM Reply Quote 2
            Mykle1 Project Sponsor Module Developer @Jopyth
            @Jopyth
            You’re awesome!
              Baxer @Jopyth
              @Jopyth Holy shit it works, thanks man
              the reason the author doesnt think the timer is a good idea its because the API have an maximum amount of calls you can make in a month which is 30 000, but if i wanted to go against his advice and make it update every 5 minute or so, how would i do that
              M 1 Reply Last reply Jul 20, 2017, 6:32 PM Reply Quote 0
                Baxer @Jopyth
                @Jopyth I figured it out myself but thanks for the help, i used MMM-ModuleScheduler and put this
                        module: 'MMM-ModuleScheduler',
                            notification_schedule: {
                                notification: 'UPDATE_SL',
                                schedule: '*/5 * * * *',
                                payload: {
                                    type: "UPDATE_SL",
                                    title: 'sl!',
                                    action: "notification"
                to make it update every 5 minutes
                  @Baxer said in MMM-SL how to trigger update?:
                  I told you he was awesome!
