    I only have a white command line after following the tutorial
    12 Posts 3 Posters 6.7k Views 3 Watching
      jgrossrieder
      After having followed the tutorial and restarted the raspberry, I only have a while command line on the top left corner, nothing else.
      I didn’t see any error. Does someone has an idea of what could I’ve done wrong? Or where I can look to better understand my issue?
      • cowboysdudeC Offline
        cowboysdude Module Developer @jgrossrieder
        @jgrossrieder said in I only have a white command line after following the tutorial:
        Which tutorial, there are many ;)
          jgrossrieder @cowboysdude
          @cowboysdude said in I only have a white command line after following the tutorial:
          This one, since I’m installing on my Raspberry pi: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
            Is this regular Pi or a piZero?
            There are a ton of steps in that tutorial. I found that when I started out doing this I would ‘think’ I’d followed all the steps but missed a ‘few’ LOL That was ME, not saying that’s what you’re doing but it does happen.
            Now if you are using a regular PI why not just install noobs and follow this tutorial here:
            Much easier :)
              Much easier :)
              The regular Pi 3 ;).
              Why? Because it was the officials steps, but I will try with your tutorial
                @jgrossrieder There is an installer script you can use
                bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                J 3 Replies Last reply Reply Quote 0
                  I executed this one, now I’ve some display! But there is a lot of things that the other did that this one didnt, like rotating the screen, or hiding the cursor, any idea how to do this?
                    also, I rebooted the Pi, and the mirror didn’t restart :(
                    cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
                      And disable the screesaver?
                        @jgrossrieder Do a forum search for ‘automatically starting mirror’ or something similar :)
                          Mykle1 Project Sponsor Module Developer @jgrossrieder
                          Easiest way:
                          https://forum.magicmirror.builders/topic/1503/how-to-disable-screensaver/8
                            Here it is:
                            https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
